Running More Than One Sensor at a Time
Hello,
I have been having issues merging programs for different sensors so that they may run simultaneously. A general question for you out there; Is it even possible to run multiple sensors at once? If it's possible, does anyone have advice about how to achieve this. For example, I am trying to run ColorPAL and a PING sensor. I have individual programs for each sensor. Is it possible to merge these into one so that I may run them at the same time?
Appreciating the help,
LT@HindsCC
LT@HindsCC
P.S. ...and even if you're using a single core device, you can take the measurements with such a small time between that it doesn't typically matter that they are not taken simultaneously. More generally many application programs monitor numerous sensors.
