Sound Impact Sensors TDOA code - help!
I thought I was writing some very simple code, but I can't make it work and I can't see why...
I have three (genuine Parallax) Sound Impact Sensors arranged on a breadboard. The sensors are about 3 inches apart. 5V and GND are connected to each sensor, and sensor signal pins are connected to Prop pins 26, 27 and 28. What I am trying to do is record the time (system counter) at which each sensor hears a noise (so pin high), and then the delay between each sensor (the sensors are arranged so that the farthest sensor is 6 inches further away from the sound source (my hands clapping) than the closest). I thought this would be reasonably simple...
I've reproduced my code below. I have pared down the code to as simple as I can. I am using a separate cog for each sensor. I know I could do this with one cog, and that's how I started, but I used a cog per sensor to make the code as simple as possible in a so far futile effort to see where I am going wrong. I still can't see it, and staring at it longer just isn't helping.
First, the Spin code:
And the PASM code:
I'm using the TEST and JMP pairs to test for pin high/low (rather than waitpeq/pne) so that I can implement a timeout - if I ever get it working.
The output I get from this is:
Ready
sensor[0], status = 1, cnt[sound] = 502E7996, cnt[silence] = 506AFE22, duration = 3966092
sensor[1], status = 1, cnt[sound] = 502EC528, cnt[silence] = 506D6BBC, duration = 4105876, delay = 19346
sensor[2], status = 1, cnt[sound] = 502FFFC2, cnt[silence] = 50711FC6, duration = 4268036, delay = 99884
sensor[0], status = 1, cnt[sound] = 5EA27C7A, cnt[silence] = 5EDF08D6, duration = 3968092
sensor[1], status = 1, cnt[sound] = 5EA2DDC4, cnt[silence] = 5EE18690, duration = 4106444, delay = 24906
sensor[2], status = 1, cnt[sound] = 5EA3AD26, cnt[silence] = 5EE4CA6A, duration = 4267332, delay = 77996
sensor[0], status = 1, cnt[sound] = 66A47A4A, cnt[silence] = 66E0FC7E, duration = 3965492
sensor[1], status = 1, cnt[sound] = 66A4C66C, cnt[silence] = 66E36A08, duration = 4105116, delay = 19490
sensor[2], status = 1, cnt[sound] = 66A6845E, cnt[silence] = 66E79982, duration = 4265252, delay = 133652
sensor[0], status = 1, cnt[sound] = 6D96E29A, cnt[silence] = 6DD35F16, duration = 3964028
sensor[1], status = 1, cnt[sound] = 720340C4, cnt[silence] = 7241ED68, duration = 4107428, delay = 74210858
sensor[2], status = 1, cnt[sound] = 72050E96, cnt[silence] = 72462282, duration = 4264940, delay = 74329084
sensor[0], status = 1, cnt[sound] = 801E31EA, cnt[silence] = 805AB986, duration = 3966876
sensor[1], status = 1, cnt[sound] = 801E79DC, cnt[silence] = 805D21D8, duration = 4106236, delay = 18418
sensor[2], status = 1, cnt[sound] = 802034F6, cnt[silence] = 80615122, duration = 4267052, delay = 131852
sensor[0], status = 1, cnt[sound] = 87DD565A, cnt[silence] = 8819D326, duration = 3964108
sensor[1], status = 1, cnt[sound] = 8A64D244, cnt[silence] = 8AA37518, duration = 4104916, delay = 42433514
sensor[2], status = 1, cnt[sound] = 8F17ECEE, cnt[silence] = 8F59078A, duration = 4266652, delay = 121280148
sensor[0], status = 1, cnt[sound] = 953294B2, cnt[silence] = 956F1A76, duration = 3966404
sensor[1], status = 1, cnt[sound] = 9532DFA4, cnt[silence] = 95718818, duration = 4106356, delay = 19186
sensor[2], status = 1, cnt[sound] = 9533C936, cnt[silence] = 9574E68A, duration = 4267348, delay = 78980
sensor[0], status = 1, cnt[sound] = 9A5A9D8A, cnt[silence] = 9A711A0E, duration = 1473668
sensor[1], status = 1, cnt[sound] = 9A5A9BEC, cnt[silence] = 9A737D08, duration = 1630492, delay = 414
sensor[2], status = 1, cnt[sound] = 9A5A9A0E, cnt[silence] = 9A763572, duration = 1809252, delay = 892
sensor[0], status = 1, cnt[sound] = A537752A, cnt[silence] = A573FB4E, duration = 3966500
sensor[1], status = 1, cnt[sound] = A537BFBC, cnt[silence] = A57668B0, duration = 4106484, delay = 19090
sensor[2], status = 1, cnt[sound] = A5398B4E, cnt[silence] = A57AA312, duration = 4265924, delay = 136740
sensor[0], status = 1, cnt[sound] = AD74DC62, cnt[silence] = ADB15D86, duration = 3965220
sensor[1], status = 1, cnt[sound] = AD76DEB4, cnt[silence] = ADB58238, duration = 4105092, delay = 131666
sensor[2], status = 1, cnt[sound] = B18C50B6, cnt[silence] = B1CD6792, duration = 4265692, delay = 68645972
Where each group of three lines is the result of a handclap. The output follows a handclap immediately - so I don't understand some of the delays being close to (or more than) a second, or some of them being extremely small. I also don't understand how the sound seems to be heard at the middle sensor first in at least one case. The durations seem to be consistent (except for one instance), but the delays are all over the place - which makes no sense because the sensors are stationary, and my hands are (within a few millimetres) the same distance from the sensors for each of the handclaps.
I thought what I was doing was pretty straight forward, but I just cannot see my mistake.
Any ideas anyone?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long sound[3]
long silence[3]
long status[3]
OBJ
dbg : "FullDuplexSerial"
sis[3] : "listen"
DAT
pin long 24, 25, 26
PUB Main | s, cog, ready
cog := dbg.Start(31,30,0,250_000)
waitcnt(clkfreq + cnt)
dbg.str(string("Ready", 13))
' start listening on all three sound impact sensors
repeat s from 0 to 2
cog := sis[s].Start(pin[s], @sound[s], @silence[s], @status[s])
if (cog < 0)
return
waitcnt(clkfreq*3+cnt) ' wait for all 3 cogs to start
' by now, all 3 sound impact sensors should be waiting on sound
repeat
' wait until all 3 sensors have signaled sample is ready
repeat while ((ready := status[0] + status[1] + status[2]) <> 3)
' to get here, all 3 sensors have signaled sample is ready
dbg.tx(13)
dbg.str(string("sensor["))
dbg.dec(s)
dbg.str(string("], status = "))
dbg.dec(status[s])
dbg.str(string(", cnt[sound] = "))
dbg.hex(sound[s], 8)
dbg.str(string(", cnt[silence] = "))
dbg.hex(silence[s], 8)
dbg.str(string(", duration = "))
dbg.dec(||(silence[s] - sound[s]))
if (s > 0)
dbg.str(string(", delay = "))
dbg.dec(||(sound[s] - sound[0])) ' delay from sound at sensor 0
dbg.tx(13)
waitcnt(clkfreq+cnt)
' all sensors should be waiting to be signaled to sample again
' signal sample again
status[0] := status[1] := status[2] := 0
And the PASM code:
CON
VAR
long _pin, _sound, _silence, _status
PUB Start(sensorPin, soundPtr, silencePtr, statusPtr) | cog
_pin := sensorPin
_sound := soundPtr
_silence := silencePtr
_status := statusPtr
cog := cognew(@listen, @_pin)
return cog
DAT
org
listen mov arg, par ' arg pointer
rdlong scr, arg ' sensor signal pin
shl mask, scr ' mask
andn dira, mask ' make pin an input
add arg, #4 ' next arg
rdlong sound, arg ' pointer to sound counter
rdlong silence, arg ' pointer to silence counter
rdlong status, arg ' pointer to status
mov scr, #0 ' sample not ready
wrlong scr, status ' set sample status to not ready
:waitForSound test mask, ina wz ' wait for pin to go high - sound
if_z jmp #$-1 ' keep listening
mov t1, cnt ' record clock
test mask, ina wz ' wait for pin to go low - silence
if_nz jmp #$-1 ' keep listening
mov t2, cnt ' record clock
wrlong t1, sound ' clock when sound heard
wrlong t2, silence ' clock when silence heard (if one can hear silence...)
mov scr, #1 ' sample ready
wrlong scr, status ' set sample status to ready
rdlong scr, status ' get sample status
tjnz scr, #$-1 ' wait for signal to sample again (status = 0)
jmp #:waitForSound ' sample again
mask long 1 ' sensor pin mask
arg res 1 ' arg pointer
sound res 1 ' pointer to sound counter
silence res 1 ' pointer to silence counter
status res 1 ' pointer to sample status
scr res 1 ' scratch register
t1 res 1 ' time sound heard
t2 res 1 ' time silence heard
Ready
Any ideas anyone?
Now I just have to code the fix and see if I'm right. Later - work beckons.
