Powering laptop from 12V supply
So I just got an old laptop from a friend with some really good specs, and I plan on putting it on my Eddie platform as a permanent addition. The laptop came with a battery but it didn't come with a charger. I modified an old charger with the same voltage and current, and made it fit in the laptop. Sadly, the BIOS prevents the battery from being charged because it does not detect the correct charger. I was thinking, since the HDD, fans, and other components run at 12v, and all the system parts run at less, the only thing that could be using the 19V output from the charger would be the battery charging circuit, which is being shut off by software. Would I be able to power the laptop directly from Eddie's 12v batteries?
How about at least telling us what it is? And the info from the battery itself would be useful.
It's going to be trial and error. I don't think the laptop is going to accept much less than what it was designed for because lipo charging, as I myself am constantly reminded, is very picky as a safety.
The worst thing I can think of is it "seems" to work, when in fact it isn't working properly. Then Eddie rolls off a cliff and gets damaged. That would be bad.
Also, the laptop battery probably isn't going to hold a charge, so even if you did get a charger you may end up having to get a battery. In that case I'd look for something that runs on 12v, like pico or mini-ITX.
http://www.ebay.com/itm/DC-Power-Adaptor-Auto-Battery-Charger-for-Dell-Inspiron-1720-700M-E1705-Notebook-/231132325494?pt=Laptop_Adapters_Chargers&hash=item35d08f6676
This is what I am using for a couple larger robots.
Robert
http://www.ebay.com/itm/90W-AC-Adapter-Power-Supply-for-Dell-Inspiron-1150-14R-1564-1570-17R-E1705-N4010-/390781300478
(assuming the battery is still good)
The external PS/charger has a cable that plugs into the external monitor jack.
Tim
Nevermind, just saw that you said it does power it.
inside the dell ac power adapter - a mystery revealed
"A new DS2501 can be soldered and programmed, with a "1-wire" programming kit and a PC with an ole RS232 jack. This is described in the Dallas Semiconductor application note 177. For electronics enthusiasts that's just a bit of fun with a soldering iron and a few low cost components.
When the programming kit is ready, next is to read the identification data from a working DELL AC Power adapter and clone it into a new DS2501 chip, already soldered into the DELL AC Power adapter."
http://www.laptop-junction.com/toast/content/inside-dell-ac-power-adapter-mystery-revealed
There are just so many ways to get this wrong and have the BIOS lock you out.
BTW, there are hacks that do add something significant. This just isn't one of them. It might be easier to move on to an early EEEpc with solid-state disk storage and Linux. The power supply is a simple wallwart. You might locate one with a broken screen for very cheap.
messing with the BRICKS chips is not going to make a PC just give up and not work. worse that can happen is that the clone cant worrk and his system is not gonna like the home brew charger .
Bomber what PC specs do you Need .....
BTW a VERY easy way to get a off the rack 12V computer is to use a 90 W DC DC boost on a macmini s they are X86 and take 19 ish Volts to run . shove Any OS on it and volla sweet mini computer and it is still smaller then a micro ATX total system .
If that is the case, BIOS will just continue to reject anything that doesn't conform. The six wire input is part of making the charger unique. You have to sort out which wires do what as well.
A lot of the options you guys have mentioned are preferable to what I am doing now, and I would be doing those if I had access to any sort of budget. I'm 13 years old and I'm not in the wealthiest of families, so you can see why I wouldn't be able to just buy a micro ATX system or mac mini just for use on Eddie. I got the laptop from a friend who was going to throw it out and I was able to get Eddie only because of the prize money from the MicroMedic contest.
Another cheap alternative is to borrow a power supply that does properly work and to download the 512 byte code on the 1-wire chip.
A BasicStamp or a Propeller can easily download the 1-wire chip data, and can write a new one with the same. After than, any power supply that you create will work if the 1-wire chip is included where it belongs.
Of course, the trick is to get that 512 byte code. Dell seems to want you to buy a power supply only from them. Others may claim to work (due to the right voltages) but fail.
