Not getting data from PMB-648 SIRF using Arduino
I am trying to use a Parallax GPS with an Arduino Nano, and I am not receiving any data from it when running the test program on the Parallax site.
I have the red wire connected to 5V, the black wire connected to GND, and the yellow wire connected to D6. The program runs properly, but it hangs at "Reading GPS" and does not display any data after that.
Does anyone know what might be the issue? I tried waiting to plug in the yellow wire after upload to ensure that there were no serial conflicts, but with the same results.
Are you trying to use this inside? Normally it has to be close to a window or outside to acquire enough satellites to give an output.
Is there a blinking LED?
I'll try moving to a location with windows and see if I get GPS data there.
Is this kind of delay normal?
I really don't think it's a matter of windows, but roof.
How does it go outside?
I have a PMB688 that acquires in the house "in no time".
The other GPS units I have can lock onto satellites much faster as long as I don't use a switching regulator with it. Switching regulators can cause all sorts of interference.
I'd suggest going outside for 15 minutes with a quite regulator to make sure there's really a problem. Though it think it could be argued even if you do get a lock after more than 5 minutes in the open, you may have a problem anyway.
