MSIE reports invalid security certificate for this site — Parallax Forums
trookstrooks Posts: 228
edited 2014-02-24 08:47 in General Discussion
Dear Parallax,
When I type Parallax.com in MS IE using private mode I continue to get a warning not to go to this site.
IE reports that the security certificate given was issued for another site address.
Would you please get your security certificate updated. It makes me very nervous having to get this message. It also means you could be loosing potential customers if they are very sensitive to internet security.
If the problem is not with your site then I suggest you get in touch with Microsoft to see why they have red flagged your site.
An uneasy customer,
Tim
  • xanatosxanatos Posts: 1,120
    edited 2014-02-21 14:48
    Hi Tim,
    It sounds like you're entering https: instead of http:
    https://parallax.com/
    will give an error because parallax.com's main site has no need to be a secure site and probably doesn't even HAVE a security certificate - they aren't cheap. Their ordering site DOES have a valid certificate, however, and that works fine - for me anyway.
    http://parallax.com/
    will work perfectly. Try it and let me know.
    Dave
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-02-21 15:00
    I think only the log in page and then final check out (if you place an order) will have certificates
  • trookstrooks Posts: 228
    edited 2014-02-21 15:54
    Double check on this end found I was using parallax.com/user/login to go straight to login.
    When I go to parallax.com I do not get the warning but it does not take my username and password when I try to log in from there.
    I can then go to the forums screen and log in with my username and password fine from there. -???
    The problem I reported is the reason I always type in a site name from another window instead of using links. Once I get to a site I then burrow down to whatever I was looking for. It is what I get for ignoring my own rule I suppose.
    Winders are a pane but it is the devil I know.
    (Note to self - ask doctor about changing pain meds on next visit)
    Tim
    edited 2014-02-21 16:10
    trooks,
    ...I suggest you get in touch with Microsoft...
    There may or may not be a problem with security on the Parallax web site. This has nothing at all to do with Microsoft.
    Edit. This morning I realized my initial response was unnecessarily over over the top so I removed most of it. My apologies to trooks if you read that.
  • xanaduxanadu Posts: 3,347
    edited 2014-02-21 16:17
    There is no requirement to encrypt a public forum. It's actually in their best effort to not afford you any guarantee it is encrypted. The best thing to do is redirect the https traffic to http to avoid a mismatch. Or blow a bunch of money on a wildcard cert :)
    edited 2014-02-22 06:07
    trooks,
    Sorry, my reply above was bad form and uncalled for.
    Thinking about this again this morning I decided to ask Chrome what it thought about Parallax security.
    On visiting https://parallax.com we get this warning:
    This is probably not the site that you are looking for!
    You attempted to reach parallax.com, but instead you actually reached a server identifying itself as www.parallax.com. This may be caused by a misconfiguration on the server or by something more serious. An attacker on your network could be trying to get you to visit a fake (and potentially harmful) version of parallax.com.
    Sure enough if you download the certificate from Parallax and read it you find the Common Name is "www.parallax.com"
    openssl s_client -connect parallax.com:443
    But the cert itself seems OK: "Verify return code: 0 (ok)"
    So the first problem is that the certificate is not issued for "forums.parallax.com" or "parallax.com"
    The question might be why isn't the forum using https?
    At least passwords are not sent as plain text but they do seem to be the same string every time you log in !
  • GenetixGenetix Posts: 1,775
    edited 2014-02-22 14:06
    Run Windows Update, choose Custom.
    Root Certificates is an optional update so check it to install it.
    edited 2014-02-22 14:13
    How can that help. The certificate from Parallax does not match the forum URL or the "parallax.com"
    As far as I can see there is no way to get to the forum over https.
    edited 2014-02-22 14:31
    Many sites use a wildcard for their SSL cert, so it can accept www and non-www forms, plus other subdomains, without requiring separate certificates. The certificate is issued to *.parallax.com.
    Parallax's site could also do a rewrite to force the preferred canonical version to www.parallax.com, but they have to be careful to indicate what they're doing in the response code so that search engines like Google don't think the site is playing hanky panky.
    But this is a good catch. People may enter parallax.com/login... and get the warning. The IT staff might want to think about replacing the cert with one that allows wildcards, do a redirect (which may or may not work), or get a second certificate for the non-www URL.
    edited 2014-02-23 00:06
    Google... worried about hanky panky???
    <ROFLMAO>
    I had little use for my computer except for email and doing an occasional search for friends or relatives. Once you get a rep as being able to find about anything or find out why something is no longer available the people just keep pouring in.
    I did something against my better judgment and tried Google for a while. The first time I noticed HD activity on my PC while I was just sitting there eating a sandwich I purged it as best I could from my system.
    I now use MS IE Private Mode and wonder why I ever wasted time with Google. No matter how I tried to focus my search in Google I could still get over 100,000 hits.
    Using MS IE I went from 60,000+ on my initial query down to 60 hits on my third set of filters. I was trying to track the source of some components and not a single one of the hits I got were in English. It seems that making components and modules has become a global cottage industry. It is strictly caveat emptor out there(here?) in the ether though.
    Aaaahh... the NET!
    - - - Entertainment... and... Diversions...!
    - - For all Persuasions.... and... Perversions...!!
    Tim
    "Beer is proof that God wants us to be happy" - Thomas Jefferson
    edited 2014-02-23 00:46
    Congratulations for jumping from the fire into the frying pan. I'm sure your world is better for it.
    It is doubtful that "HD activity on my PC while I was just sitting there" is caused by any malicious activity by Google, despite their evil nature. Probably this is caused by the operating system.
    Microsoft Windows is well known for this. It simply will not leave the disk alone. Until you start using a file system analysis tool, and spend many, many hours watching exactly what is happening while starting and stopping the dozens of "services" running on a PC, it is difficult to know exactly what is actually using the disk, and even then it's hard to be certain.
    edited 2014-02-23 10:30
    As Rick sez, the disk activity is probably background Windows activity, common when the machine sits idle for a time. On the later OS's in particular, the idle time may be used for automatic disk compression tasks, security scans, folder indexing (if you've selected that option), and lots of other things.
    If by "tried Google" you mean Chrome, that browser does a ton of background tasks, including keeping itself updated on a fairly regular basis. To my knowledge, MSIE does not do background updates, but waits for the overall Windows system updates. If you don't have those on, or don't manually apply them, IE gets very outdated very fast.
    edited 2014-02-23 14:14
    Trooks - There are plenty of ways out there to see what is accessing your hard drive, is that how you determined Chrome was accessing your disk?
    The reason I ask is I have seen Chrome take up a lot of space on systems with unmanaged cache, but don't see it accessing the drive often, so I have always wondered. I should probably Google it lol.
    Have you tried private mode aka incognito browsing on Chrome? If it's your cache, that will shut it up, and I guarantee you'll have better results than IE, especially when it comes to HTML5.
  • SRLMSRLM Posts: 5,045
    edited 2014-02-23 14:20
    To be fair, there are issues with Chrome (Chromium) accessing the disk. For example, issue 52663 has been active for over 3 years: https://code.google.com/p/chromium/issues/detail?id=52663
    edited 2014-02-23 19:08
    xanadu wrote: »
    I open one window at a time. Cookies are forbidden. My friends do not bother to send me email with attachments. If strangers send email with attachments my systems routes it to the Spam folder.
    There is nothing on my computer that requires updating except at my instigation.
    When I run an application that has timed backups they all go to the CDRW.
    Sometimes I will sit for a while with a web page open in the browser - like when I have to take a while to compose and type a forum entry.
    In the months since I dropped Chrome not once has there been any unexpected HD activity.
    Where do I look to find if a keystroke tracker is running on my computer?
    edited 2014-02-23 19:51
    You know, if you're happy with your browser, whatever it is then keep it as is. I use a combination of browsers but I connect to over 10 years of embedded webserver that do not update like the rest of the internet.
    If you really wanted to try Chrome again can you try using Incognito Mode?
    It sounds like you want security at the browser. Here is some information on computer forensics when it comes to the two browsers in question. You're going to want to do a lot of reading about this to start to get an idea of how deep it can get - http://www.magnetforensics.com/how-does-chromes-incognito-mode-affect-digital-forensics/
    That article is very good because it compares what you're saying works better than what actually does work better. That leads me to believe there is more to your problem than we'll be able to discover. Here is a snippet- " The result with using Chrome’s incognito is far fewer artifacts ever hitting the disk and ultimately going into unallocated space."
    So that means that your best bet for least disk usage is usually Chrome.
    I do gateway security so I'm not up to date on keylogger detection. I get annoyed that stuff like that can get through the gateway and start going down the list of all the gateway security solutions and how nobody uses them, etc etc..
    edited 2014-02-23 21:31
    If security is the main concern you could look at IronKey, they have a customized version of Firefox that run's only from an encrypted external HDD or flash drive (not cheap though), or possibly the Tor browser, which is also a customized version of Firefox.
    http://www.ironkey.com/
    https://www.torproject.org/
    RDL2004 wrote: »
    RDL2004, Thank You for the two pointers to additional information.
    For now I am satisfied with the fact that as far as I can tell the mysterious HD activity has ended.
    As I said earlier the stuff that I most want to keep to myself goes directly from whichever app I am using to removable media. Even screen prints of stuff I want to come back to later are written to removable media. That is something I learned back when the company I was working for was among the first to be authorized to install and maintain IBM PCs.
    I am far too busy at this time to switch over to UNIX. I have a couple of friends that swear by Firefox.
    I once worked with Unix on equipment handling T-1 and Frac-T1 communications links. The processors on those systems were the ones the government would not let us sell to the Russians. Big Blue could still sell whatever they wanted to sell to anybody they wanted to sell it to. We also had the world champion chess playing computer at that time.
