Coming from PBASIC to Prop C: Select Case / switch
John Kauffman
Does this seem right? It works but is there a better technique?
PBASIC
[/code]
myDiscountCode VAR Nib
myPrice VAR Byte
myDiscountCode = 1
SELECT myDiscountCode
CASE 1 'member discount
myPrice = 6
CASE 2,3 'senior and student
myPrice = 8
CASE 4 TO 7 'local resident
myPrice = 9
CASE ELSE 'full price
myPrice = 10
ENDSELECT
DEBUG myPrice
[/code]
Prop C
Use Switch instead of Select Case. All the cases go in one {} of the Switch.
Each case must end with a break (One cases code does not automatic stop when next case starts; it will run through.)
Case lines end in colon. As usual, semicolon at end of each line of code within the Case
default instead of ENDSELECT
For a range, there is no TO so change from switch to if()
[/code]
int myDiscountCode;
int myPrice;
myDiscountCode = 7; // hard code, set before run
switch(myDiscountCode) {
case 1: //member discount
myPrice = 6;
break;
case 2: //n.b. no break so flows to case 3
case 3: //n.b. covers student and senior
myPrice = 8;
break;
// no "TO" syntax. Use listing (n.b. no commas) or if()
case 4: case 5: case 6: case 7:
myPrice = 9;
break;
default: //full price
myPrice = 10;
break;
} //switch
print("myDiscountCode = %d.\nmyPrice = %d.",myDiscountCode,myPrice);
[/code]
PBASIC
[/code]
myPrice VAR Byte
myDiscountCode = 1
myPrice = 6
myPrice = 8
myPrice = 9
myPrice = 10
ENDSELECT
DEBUG myPrice
[/code]
Prop C
[/code]
int myDiscountCode;
int myPrice;
myPrice = 6;
break;
myPrice = 8;
break;
myPrice = 9;
break;
myPrice = 10;
break;
} //switch
[/code]
