MIcro USB "charger" cables
Peter Jakacki
I use micro USB connectors and cables a lot in my projects but a lot of times they are also used to power the device and in this respect there doesn't seem to be any standards. I have boxes of cables that are useless for this purpose, if you strip them back you find that the "wire" is in fact a single sub-millimetre wide foil that is wrapped around the flex thread, a bit like earphone cable.
So in my determination to find out which ones were good and which ones were bad I just devised a standard test of plugging them into one of my little "Proplink" compatible plugs and since I have the USB 5V on the end connector I used a 22R resistor for a load of around 230ma at the charger reference of 5.25V.
I have a short thick cable that came with my Nexus 7 I think and if I plug that in I still read 5.2V at the load end. Another good cable read 5.05V etc. Most of the cables however read 4.37V and that would be at less current of course. These ones I have thrown in the bin, there are a lot of them. Though I could use them for signal cables it is too confusing to have them around.
Now the trouble with purchasing cables esp. on Ebay is that there is no reference figure that's used to describe their conductance. I'm using the voltage under the 22R load as my figure, it's conservative but indicative enough for my purposes. Does anyone know of any good "charger" style cables that I can purchase in bulk at a good price? I normally just use 1M cables.
There is always Bekin that claims to be a branded premium quality, but I am not so sure.
You can also ask the seller if the cable is USB-IF compliant which is highly reliable and built on standards.
I have just found a new business. They have sold 392 of these!
http://www.kogan.com/au/buy/4-port-usb-rapid-wall-charger/
Its hard to get 5v supplies with plenty of current for driving lots of WS2812 LEDs. Biggest wall wart I have easy access to here does 4A, then you have to jump across to laptop style bricks.
But, this one looks interesting at 5 amps, and universal (so you don't have to twist those prongs with pliers )
http://www.amazon.com/Fone-Stuff-Interchangeable-Worldwide-International-Adaptors/dp/B00I2Y111I/ref=sr_1_22?ie=UTF8&qid=1392938612&sr=8-22&keywords=usb+mains+adapter
edit: this one is cheaper but still 5A too
http://www.amazon.com/EasyAcc-Portable-Smartphones-Bluetooth-Headphones/dp/B00E95OT6I/ref=sr_1_10?ie=UTF8&qid=1392939280&sr=8-10&keywords=4+usb+port
Thanks for helping me spend my money, Tubular!!
