Coming from PBASIC to Prop C: LookUp, LookDown
Does this seem right? It works but is there a better technique?
PBASIC
Prop C
Lookup: refer to the [element#] in the array
Lookdown: start with a value and get the index of the match in the array
PBASIC
LOOKUP IndexNumberIn,[item1,item2,item3], VarToReceiveValue LOOKDOWN ValueIn,[item1,item2,item3], VarToReceiveIndexNumber if item list is strings then: [item1,item2,item3]
Prop C
char myResultHolder; int myLookUpNumber = 2; char myArrayOfLetters1[] = "abcd"; myResultHolder = myArrayOfLetters1[myLookUpNumber]; print("myLookUpNumber = 2 returned %c",myResultHolder);
char myArrayOfLetters2[] = "wxyz"; char myLookUpValue = 'y'; int myResultIndexNumber; int myArrayCounter; for (myArrayCounter=0; myArrayCounter<sizeof(myArrayOfLetters2); myArrayCounter++){ if (myArrayOfLetters2[myArrayCounter] == myLookUpValue){ myResultIndexNumber=myArrayCounter;} //found } // loop thorugh all members of array print("myLookUpValue of 'y' returned index number of %d",myResultIndexNumber);
Lookdown: yes, a linear search. One small optimization is adding a "break;" if the item is found.
For the particular case of finding a letter in a string you can use the strchr function: http://www.cplusplus.com/reference/cstring/strchr/
