LCD/VFD panel bezels? — Parallax Forums
xanatosxanatos Posts: 1,120
edited 2014-02-18 21:54 in General Discussion
I'm trying to find what I thought should be easy - a simple, slim, bezel with clear window for the LCD & VFDs I use. NHD sends you to some place called Elmwood, but their bezels have a virtual parking lot of plastic around the actual display opening... No idea why.
Does anyone have a good source for bezels that have a display window of 3 to 3.25" wide x 1 to 1.25" high, and another around 4" wide x 1" high?
Digikey only seems to have 1.8" or 2.5" wide, or 10" plus. Ebay is so littered with bezels for iPhones, laptops, Androids... that I can't even find a simple panel bezel. Jameco, Newark, Mouser don't seem to have any selection to speak of...
This should be easy...
    edited 2014-02-17 14:34
    Scott Edwards sells mounting kits and lexan faceplates.
    They are geared toward displays sold there but can be used for other brands
    http://www.seetron.com/mounting.html
  • RDL2004RDL2004 Posts: 2,554
    A couple of years ago I looked all over for bezels and couldn't find anything I liked. I ended up just cutting a hole in the box to fit. Datel used to sell matching bezels for their panel meters that were adaptable to other uses, they were around $5 each. The sizes you need seem to be a bit larger than most standard panel meters. These days would it be possible to get one custom made? Laser cut or 3D printed maybe?
  • KMyersKMyers Posts: 433
    edited 2014-02-17 14:58
    Ada Fruit has one for 2x20 I believe for around $5.
  • TCTC Posts: 1,019
    edited 2014-02-17 17:59
    Just an idea.
    I was going to use Front Panel Express for my reflow oven. Since I don't have all my fabrication tools where I live, I don't want to try cutting the plastic lid with basic hand tools.
  • Too_Many_ToolsToo_Many_Tools Posts: 765
    edited 2014-02-17 18:27
    xanatos wrote: »
    LOL..yes it should be easy but it won't be...no standards and everyone with a heartbeat will try to sell you something.
    FWIW...over the years I have kept a box of surplus bezels just because they are a pain to source for a hobbyist.
    edited 2014-02-17 18:29
    FWIW..if you have a good framing shop nearby, they can get you anything small to fit your needs.
  • T ChapT Chap Posts: 4,223
    edited 2014-02-17 18:39
    I use 1/8" acrylic with a matte surface on the exposed side. Double sided tape holds in on the CNC, mill the outer dimension, then the cutout for the LCD, then pocket a little area for the LCD to sit inside so it sits square. I had a rear box made with a lid that is injection molded. This is the NHD with touch.
    640 x 478 - 106K
    184 x 349 - 15K
    edited 2014-02-17 20:19
    Any nearby adverts/banners/etc making company will do, they have various vinyl/acryl/etc cutters.
  • xanatosxanatos Posts: 1,120
    edited 2014-02-18 13:19
    T Chap wrote: »
    That's sort of what I'm doing now - but hiring a shop to do it. They mill the case and the polycarbonate lens with a flange that is really cool - but they charge about $200 each time. I just thought that I could source about 100 bezels and saw a few simple rectangles into the boxes myself for the bezels to slip into, and save a bunch over a run. Alas... it looks like I'm stuck with the machine shop. For now, anyway, until I get my first 3D printer (anyone feeling generous?)
    edited 2014-02-18 13:41
    Have you ever tried to contact the manufacturer of you box to see what they would charge for a custom rectangular cut out? A full on custom box would probably be way too expensive and you'd probably have to buy a thousand, but a simple mod to an existing mold might be more reasonable.
    edited 2014-02-18 13:47
    RDL2004 wrote: »
    That actually may be a possibility. I get the boxes from L-Com - and I do think I recall something about them modding them. http://www.l-com.com/nema-enclosures-12x10x5-inch-weatherproof-nema-4x-enclosure-with-blank-aluminum-mounting-plate
    Take a look in the craft stores. I have used small plastic picture frames they sell for a couple of projects. Not sure you will find any as small as 3" x 1" though. I think the smallest on I found was 2" x 3".
