Turn and Travel Command for Eddie Not Working
I posted a similar post a few months back and was able to resolve the issue. However a similar issue has shown up again and what I did last time is not resolving it this time.
When I use the Propeller Serial Terminal to issue a Turn fef1 4b command the Eddie should rotate 271 degrees. However it turns less then 180 degrees. It seems that no matter what value I put in for the angle of the turn command, the eddie turns the same amount every time. I am using firmware 1.3, and the encoders are correctly hooked up.
