hey everyone
greetings
i am first year student of electronics at ned khi and i am asked t make a proximity circuit using LDR
can any one help me make a simple circuit .... there are bonus mrks for smallest circuit ... i can not find a schematic
The boe bot kit contains the breadboard, resistors, jumper wires(you can use this without the BOE BOT, (which has power built in) you can have it portable with a 9v battery, or 3 AA's(you supply)
(the boe bot shows you how to make a proximity circuit and intelligent proximity decisions for the "future classes", HINT HINT.
The LDR circuit above can be built on the breadboard, (no need to include the breadboard circuitry into the circuitry of the LDR project. you are just using it as a power supply, and breadboard. (you will use the boe bot and other parts later in school, and for fun)
If you still have trouble with the preset resistor and led resistor values, let us know.
And ...Considering its your first year....
Step 1: Purchase a BOE bot kit.
http://www.parallax.com/product/28832
Step 2: purchase 5 transistors(in case you kill some, really you only need 2) http://www.parallax.com/product/500-00001
Step 3: purchase an LDR. http://www.parallax.com/product/350-00009
Step 3: look at this circuit.
http://forums.parallax.com/showthread.php/141426-Daylight-Sensor?highlight=photoresistor
http://forums.parallax.com/showthread.php/128920-Photoresistor-controlled-light-switch?highlight=photoresistor
http://forums.parallax.com/showthread.php/140672-Photo-Resistor-Resistor-value?highlight=photoresistor
