GPS module - Serial Voltage?
I want to connect the GPS Module PMB-648-SiRF to my Raspberry Pi. The Raspberry Pi can only receive signals at a max of 3.3 volts. From what I gathered about this module, the GPS module uses a UART TTL serial port, and I have read that UART TTL sends signals at 0 and 5 volts. Can you confirm whether the GPS module is transmitting at 5 volts or 3.3 volts? I don't want to damage my Raspberry Pi board.
Thanks.
Thanks.
The info page "Details" indicate 3.3V or 5V operation.... meaning that if you power it with 3.3V then the Serial voltage will only be 3.3V
http://www.parallax.com/product/28501
