GPS BS2 Code issues — Parallax Forums
GPS BS2 Code issues
spjapple31spjapple31 Posts: 9
edited 2014-02-14 06:01 in BASIC Stamp
Finished testing only appear:
singnal Valid:
Local Time:
Local Date:
Latitude:
Longitude:
Altitude:
Speed:
I ask the Code issues Error??
(BS2)
' -----[ Title ]-----------------------------------------------------------
'   File...... Easy GPS V1.0.bsp
'   Purpose... Easy GPS Interface
'   Author.... Parallax, Inc.
'   E-mail.... [EMAIL="support@parallax.com"]support@parallax.com[/EMAIL]
'   Started... 02-26-2010
'   Updated...
'   {$STAMP BS2}
'   {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' Connect the Yellow Wire from your Parallax GPS Receiver to P0.  The Black
' wire goes to VSS and the Red wire goes to VDD.  All others wires should
' not be connected (I plugged mine into empty isolated breadboard slots)
' Reads NMEA data string from GPS receiver and parses data.  GPS string is
' buffered into scratchpad RAM with SPSTR modifier.  Once in SPRAM, data is
' parsed out based on its position.
' $GPRMC,POS_UTC,POS_STAT,LAT,LAT_D,LON,LON_D,SPD,HDG,DATE,MAG_VAR,MAG_REF,*CC
'  POS_UTC  - UTC of position. Hours, minutes and seconds. (hhmmss)
'  POS_STAT - Position status. (A = Data valid, V = Data invalid)
'  LAT      - Latitude (ddmm.ffff)
'  LAT_D    - Latitude direction. (N = North, S = South)
'  LON      - Longitude (dddmm.ffff)
'  LON_D    - Longitude direction (E = East, W = West)
'  SPD      - Speed over ground. (knots) (0.0 - 999.9)
'  HDG      - Heading/track made good (degrees True) (x.x)
'  DATE     - Date (ddmmyy)
'  MAG_VAR  - Magnetic variation (degrees) (x.x)
'  MAG_REF  - Magnetic variation (E = East, W = West)
'  *CC      - Checksum
' -----[ Revision History ]------------------------------------------------
' -----[ I/O Definitions ]-------------------------------------------------
GPSpin          PIN     0               ' GPS serial input
' -----[ Constants ]-------------------------------------------------------
T4800           CON     188             ' Baud rate for GPS (typical)
MoveTo          CON     2               ' DEBUG positioning command
ClrRt           CON     11              ' Clear line right of cursor
EST             CON     -5              ' Eastern Standard Time
CST             CON     -6              ' Central Standard Time
MST             CON     -7              ' Mountain Standard Time
PST             CON     -8              ' Pacific Standard Time
EDT             CON     -4              ' Eastern Daylight Time
CDT             CON     -5              ' Central Daylight Time
MDT             CON     -6              ' Mountain Daylight Time
PDT             CON     -7              ' Pacific Daylight Time
UTCfix          CON     PST             ' For Rocklin, CA
Comma           CON     ","             ' Comma
DegSym          CON     176             ' Degrees symbol for report
MinSym          CON      39             ' Minutes symbol
SecSym          CON      34             ' Seconds symbol
' -----[ Variables ]-------------------------------------------------------
index           VAR     Byte            ' Index into GPS data in SPRAM
flags           VAR     Byte            ' Holds bit values
valid           VAR     Flags.BIT3      ' Is data valid?
numSats         VAR     Byte            ' Number of satellites
tmHrs           VAR     Byte            ' Time fields
tmMins          VAR     Byte
tmSecs          VAR     Byte
latDeg          VAR     Byte            ' Latitude
latMin          VAR     Byte
latSec          VAR     Word
latNS           VAR     flags.BIT0      ' 0 = N
longDeg         VAR     Byte            ' Longitude
longMin         VAR     Byte
longSec         VAR     Word
longEW          VAR     flags.BIT1      ' 0 = E
speed           VAR     Word            ' In tenths of mph***************
altitude        VAR     Word            ' In feet************************
day             VAR     Byte            ' Day of month, 1 - 31
month           VAR     flags.NIB1      ' Month, 1 - 12
year            VAR     Byte            ' Year, 00 - 99
char            VAR     Byte            ' Byte pulled from SPRAM
workVal         VAR     Word            ' For numeric conversions
eeAddr          VAR     workVal         ' Pointer to EE data
field           VAR     Nib             ' Field #
fldWidth        VAR     field           ' Width of field
' -----[ EEPROM Data ]-----------------------------------------------------
NotValid        DATA    "No", 0
IsValid         DATA    "Yes", 0
DaysInMon       DATA    31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31
MonNames        DATA    "JAN",0,"FEB",0,"MAR",0,"APR",0,"MAY",0,"JUN",0
                DATA    "JUL",0,"AUG",0,"SEP",0,"OCT",0,"NOV",0,"DEC",0
' -----[ Initialization ]--------------------------------------------------
Initialize:
  PAUSE 250                             ' Let DEBUG open
  DEBUG CLS                             ' Clear the screen
  DEBUG "Easy GPS Interface V1.0", CR
  DEBUG "======================="
Draw_Ruler:
  FOR index = 0 TO 65
    IF (index = 0) THEN Print_Ones
    IF (index // 10) > 0 THEN Print_Ones
    DEBUG MoveTo, (7 + index), 3, DEC1 (index / 10)
  Print_Ones:
    DEBUG MoveTo, (7 + index), 4, DEC1 (index // 10)
  Print_Ticks:
    IF (index // 10) > 0 THEN Next_Digit
    DEBUG MoveTo, (7 + index), 5, "|"
  Next_Digit:
  NEXT
Draw_Data_Labels:
  DEBUG MoveTo, 0,  9, "Signal Valid: "
  DEBUG MoveTo, 0, 11, "  Local Time: "
  DEBUG MoveTo, 0, 12, "  Local Date: "
  DEBUG MoveTo, 0, 14, "    Latitude: "
  DEBUG MoveTo, 0, 15, "   Longitude: "
  DEBUG MoveTo, 0, 16, "    Altitude: "
  DEBUG MoveTo, 0, 17, "       Speed: "
' -----[ Program Code ]----------------------------------------------------
Main:
  ' Wait for $GPRMC string and store data in SPRAM
  SERIN GPSpin, T4800, 2000, No_GPS_Data, [WAIT("GPRMC,"), SKIP 65]
  GOSUB Parse_GPS_Data                  ' Extract data from SPRAM
Show_GPMRC_String:
  DEBUG MoveTo, 0, 6, "$GPRMC,"         ' Print header
  index = 0                             ' Start at position UTC
Print_GPRMC_Char:                       ' Print the $GPRMC data string
  READ index, char                       ' Get char from SPRAM
  DEBUG char                            ' Display it
  IF char = "*" THEN Print_Checksum     ' Look for checksum indicator
  index = index + 1                     ' Point to next char
  GOTO Print_GPRMC_Char
Print_Checksum:
  READ (index + 1), char                 ' Get first checksum char
  READ (index + 2), char                 ' Get second checksum char
  DEBUG char, ClrRt                     ' Display, clear to end of line
Show_Report:
  DEBUG MoveTo, 14, 9                   ' Was the signal valid?
  LOOKUP valid, [NotValid, IsValid], eeAddr' Get answer from EE
  GOSUB Print_Z_String                  ' Print it
  DEBUG " (", DEC numSats, " Satellites)"
  DEBUG ClrRt                           ' Clear end of line
  IF (valid = 0) THEN Signal_Not_Valid
Get_Altitude:
  SERIN GPSpin, T4800, 2000, Signal_Is_Valid, [WAIT("GPGGA,"), SKIP 75]
  index = 45                            ' Altitude
  GOSUB Mixed_To_Tenths                 ' Convert "xxx.x" To number
  altitude = workVal
  index = 38 : fldWidth = 2             ' Number of sats
  GOSUB String_To_Value
  numSats = workVal
Show_GPGGA_String:
  DEBUG MoveTo, 0, 7, "$GPGGA,"         ' Print header
Print_GPGGA_Char:                       ' Print the $GPRMC data string
  IF char = "*" THEN Print_Chexum       ' Look for checksum indicator
  GOTO Print_GPGGA_Char
Print_Chexum:
Signal_Is_Valid:
  DEBUG MoveTo, 14, 11, DEC2 tmHrs, ":", DEC2 tmMins, ":", DEC2 tmSecs
  DEBUG MoveTo, 14, 12, DEC2 day, " "
  eeAddr = (month - 1) * 4 + MonNames           ' get address of month name
  GOSUB Print_Z_String                          ' print it
  DEBUG " 20", DEC2 year
  DEBUG MoveTo, 14, 14, " ", DEC2 latDeg, DegSym, " ", DEC2 latMin, MinSym, " "
  DEBUG DEC2 (latSec / 10), ".", DEC1 (latSec // 10), SecSym, " "
  DEBUG "N" + (latNS * 5)
  DEBUG MoveTo, 14, 15, DEC3 longDeg, DegSym, " ", DEC2 longMin, MinSym, " "
  DEBUG DEC2 (longSec / 10), ".", DEC1 (longSec // 10), SecSym, " "
  DEBUG "E" + (longEW * 18)
  DEBUG MoveTo, 14, 16, DEC (altitude / 10), ".", DEC1 (altitude //10), " Meters", ClrRt
  DEBUG MoveTo, 14, 17, DEC (speed / 10), ".", DEC1 (speed // 10), " MPH "
  GOTO Main
Signal_Not_Valid:
  DEBUG MoveTo, 14, 11, "?", ClrRt      ' Clear all fields
  DEBUG MoveTo, 14, 12, "?", ClrRt
  DEBUG MoveTo, 14, 14, "?", ClrRt
  DEBUG MoveTo, 14, 15, "?", ClrRt
  DEBUG MoveTo, 14, 16, "?", ClrRt
  DEBUG MoveTo, 14, 17, "?", ClrRt
  GOTO Main
' -----[ Subroutines ]-----------------------------------------------------
No_GPS_Data:
  DEBUG CLS, "Error: No GPS data detected"
  PAUSE 2500
  GOTO Initialize                       ' Try again
Parse_GPS_Data:
  index = 0 : fldWidth = 2              ' UTC hours
  tmHrs = workVal
  index = 2 : fldWidth = 2              ' UTC minutes
  tmMins = workVal
  index = 4 : fldWidth = 2              ' UTC seconds
  tmSecs = workVal
  index = 13 : fldWidth = 2             ' Latitude degrees
  latDeg = workVal
  index = 15 : fldWidth = 2             ' Latitude minutes
  latMin = workVal
  index = 18 : fldWidth = 4             ' Latitude fractional minutes
  latSec = workVal ** $0F5C             ' x 0.06 --> tenths of seconds
  index = 25 : fldWidth = 3             ' Longitude degrees
  longDeg = workVal
  index = 28 : fldWidth = 2             ' Longitude minutes
  longMin = workVal
  index = 31 : fldWidth = 4             ' Longitude fractional minutes
  longSec = workVal ** $0F5C            ' x 0.06 --> tenths of seconds
  ' Get non-numeric data
Get_Valid:
  READ 11, char
  valid = 1                             ' Assume valid
  IF (char = "A") THEN Get_Lat_Dir      ' It is, so skip
  valid = 0                             ' Set to 0 if not valid
Get_Lat_Dir:
  latNS = 0                             ' Assume North
  READ 19, char                          ' Check it
  IF (char = "N") THEN Get_Long_Dir     ' Confirm
  latNS = 1                             ' Set to 1 if South
Get_Long_Dir:
  longEW = 0                            ' Assume East
  READ 33, char                          ' Check it
  IF (char = "E") THEN Get_Speed        ' Confirm
  longEW = 1                            ' Set to 1 if West
  ' Get variable length data
Get_Speed:
  index = 38
  ' speed = workVal                     ' Speed in knots (tenths)
  speed = workVal + (workVal ** $2699)  ' x 1.1507771555 for mph
  ' Get date
  ' -- past variable data, so we need to use field search
Get_Date:
  field = 8                             ' Set field to find
  GOSUB Move_To_Field                   ' Go get position
  READ 125, index                        ' Save date position
  fldWidth = 2
  day = workVal                         ' UTC day, 1 - 31
  READ 125, index                        ' Get stored position
  index = index + 2 : fldWidth = 2
  month = workVal                       ' UTC month, 1 - 12
  index = index + 4 : fldWidth = 2
  year = workVal                        ' UTC year, 0 - 99
  ' Adjust date for local position
Correct_Local_Time_Date:
  workVal = tmHrs + UTCfix              ' Add UTC offset
  IF (workVal < 24) THEN Adjust_Time    ' Midnight crossed?
  workVal = UTCfix                      ' Yes, so adjust date
  BRANCH workVal.BIT15, [Location_Leads, Location_Lags]
Location_Leads:                         ' East of Greenwich
  day = day + 1                         ' No, move to next day
  eeAddr = DaysInMon * (month - 1)      ' Get days in month
  READ eeAddr, char
  IF (day <= char) THEN Adjust_Time     ' In same month?
  month = month + 1                     ' No, move to next month
  day = 1                               ' First day
  IF (month < 13) THEN Adjust_Time      ' In same year?
  month = 1                             ' No, set to January
  year = year + 1 // 100                ' Add one to year
  GOTO Adjust_Time
Location_Lags:                          ' West of Greenwich
  day = day - 1                         ' Adjust day
  IF (day > 0) THEN Adjust_Time         ' Same month?
  month = month - 1
  IF (month > 0) THEN Adjust_Time       ' Same year?
  READ eeAddr, day                      ' Get new day
  year = year + 99 // 100               ' Set to previous year
Adjust_Time:
  tmHrs = tmHrs + (24 + UTCfix) // 24   ' Localize hours
  RETURN
' Convert string data (nnnn) to numeric value
' -- index    - location of first digit in data
' -- fldWidth - width of data field (1 to 5)
' -- workVal  - returns numeric value of field
String_To_Value:
  workVal = 0
  IF (fldWidth = 0) OR (fldWidth > 5) THEN String_To_Value_Done
Get_Field_Digit:
  READ index, char                       ' Get digit from field
  workVal = workVal + (char - "0")      ' Convert, add into value
  fldWidth = fldWidth - 1               ' Decrement field width
  IF (fldWidth = 0) THEN String_To_Value_Done
  workVal = workVal * 10                ' Shift result digits left
  index = index + 1                     ' Point to next digit
  GOTO Get_Field_Digit
String_To_Value_Done:
  RETURN
' Convert string data (nnn.n) to numeric value (tenths)
Mixed_To_Tenths:
  workVal = 0
Get_Mixed_Digit:
  READ index, char                       ' Read digit from speed field
  IF (char = ".") THEN Get_Mixed_Last   ' Skip decimal point
  workVal = (workVal + (char - "0")) * 10' Add digit, move data left
  GOTO Get_Mixed_Digit
Get_Mixed_Last:
  workVal = workVal + (char - "0")      ' Speed in knots
  RETURN
' Find field location after variable-length data (i.e., speed)
' -- field - field number
' -- index - returns position of first digit in field
Move_To_Field:
  index = 0
  IF (field = 0) THEN Move_To_Field_Done' If zero, we're there
Get_Char:
  IF (char = Comma) THEN Found_Comma    ' Is it a comma?
  index = index + 1                     ' No, move to next char
  GOTO Get_Char
Found_Comma:
  field = field - 1                     ' Was comma, dec field coutner
  IF (field = 0) THEN Move_To_Field_Done' If field = 0, we're there
  GOTO Get_Char
Move_To_Field_Done:
  RETURN
' Print Zero-terminated string stored in EEPROM
' -- eeAddr - starting character of string
Print_Z_String:
  READ eeAddr, char                     ' Get char from EE
  IF (char = 0) THEN Print_Z_String_Done' If zero, we're done
  DEBUG char                            ' Print the char
  eeAddr = eeAddr + 1                   ' Point to the next one
  GOTO Print_Z_String
Print_Z_String_Done:
  RETURN
  • Hal AlbachHal Albach Posts: 747
    edited 2014-02-10 19:51
    This code is intended for a BS2P, not a BS2. BS2 does not have SPRAM.
  • spjapple31spjapple31 Posts: 9
    edited 2014-02-10 20:10
    You can modify it?
    (I have modified the change but did not comment)
    I was using BS2P sample program modified to BS2
    edited 2014-02-10 20:37
    I doubt that the required changes would fit in the BS2. As the program is, there are a little over 300 bytes left in the EEPROM and you have 2 bytes and 1 nibble left in the register space.
    For the price of a BS2P you can buy two USB Propeller Project Boards. The propeller has many more resources than the BS2 or BS2P, more memory, faster, and can perform 8 simultaneous tasks. Plus you have quite a few options for programming, SPIN, PASM, BASIC, C, C++, several FORTH's. (I wonder if anyone is looking into COBOL?)
    edited 2014-02-10 20:58
    That success you have the opportunity to amend?
    edited 2014-02-11 08:15
    In MAIN the original input statement
    SERIN GPSpin, T4800, 3000, No_GPS_Data, [WAIT("GPRMC,"), SPSTR 65]
    waits for the string "GPRMC" and then stores the next 65 characters in Scratchpad Ram ( SPSTR 65).
    You changed it to
    which also waits for string "GPRMC" but then SKIPs the next 65 characters, period. Nothing was stored , just skipped.
    Just about the same for the SERIN... statement under "Get_Altitude:".
    The BS2P has a 128 byte Scratchpad ram memory, the BS2 does not. This program requires the BS2P because it has the Scratchpad.
    The BS2 has NOWHERE to put 65 or 75 incoming characters except possibly in EEPROM, which would wear out rather quickly in this application.
    In short, changing various statements in order to compile for a BS2 does not alter the fact that the BS2 does not have the resources that this program needs.
  • GenetixGenetix Posts: 1,775
    edited 2014-02-11 13:13
    Which Parallax GPS module are you using?
    edited 2014-02-11 16:56
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    LatDeg VAR Byte
    LatMin VAR Byte
    LatMinD VAR Word
    LatSign VAR Byte
    LatDir VAR Byte
    LonDeg VAR Byte
    LonMin VAR Byte
    LonMinD VAR Word
    LonSign VAR Byte
    LonDir VAR Byte
    wVal VAR Word
    'Baud rates (non-inverted):
    n4800 CON 188
    n9600 CON 84
    Main:
    'Get GPSRMC statement from pin 0
    SERIN 0, n4800, [WAIT("RMC,"),SKIP 13,
    DEC2 LatDeg, DEC2 LatMin, SKIP 1, DEC LatMinD, SKIP 1, LatSign,
    DEC3 LonDeg, DEC2 LonMin, SKIP 1, DEC LonMinD, SKIP 1, LonSign]
    GOSUB AddSign
    PAUSE 760
    wVal = (LatMin * 1000 / 6) + (LatMinD / 60) 'convert to min/seconds
    SEROUT 16, n9600, [REP "-"\LatDir, DEC LatDeg, ".", DEC4 wVal, ", "]
    wVal = (LonMin * 1000 / 6) + (LonMinD / 60) 'convert to min/seconds
    SEROUT 16, n9600, [REP "-"\LonDir, DEC LonDeg, ".", DEC4 wVal, CR]
    GOTO Main
    DEBUG CR ' Show empty debug window if GPS does not respond
    AddSign:
    IF LatSign = "S" THEN
    LatDir = 1
    ELSE
    LatDir = 0
    ENDIF
    IF LonSign = "W" THEN
    LonDir = 1
    ELSE
    LonDir = 0
    ENDIF
    RETURN
    Debug Terminal ?
    edited 2014-02-11 18:02
    And your question is?
    edited 2014-02-11 18:21
    Debug Terminal ??
    Why not show the numerical?
    1024 x 576 - 35K
    D T.jpg 35.2K
    edited 2014-02-11 20:07
    You are using the wrong comm settings when using SEROUT 16.....
    Page 169 of the current Stamp manual states that
    DEBUG "Hello"
    is the same as
    SEROUT 16, $4054, ["Hello"]
    $4054 is Hex for 16468. The signal has to be inverted since it goes through an RS232 level driver which is an inverter.
    Change the constant declaration from n9600 CON 84 to ​i9600 CON 16468. Don't forget to change all the SEROUT statements. You could leave the name as n9600 but the n denotes non-inverted and could cause confusion later on.
    Also you need to correct the following error;
    [COLOR=#3E3E3E]GOTO Main[/COLOR]
    [COLOR=#3E3E3E]DEBUG CR ' Show empty debug window if GPS does not respond[/COLOR]
    Any statement following a GOTO... statement must have a label which is used in another part of the program or else the statement is unreachable.
    You did a marvelous job in reducing the BS2P program to work in a BS2. Let us know if it works out.
    edited 2014-02-11 20:34
    That we should be how to modify??
    I do not understand what you mean.
    We tried to modify it still does not show the latitude and longitude.
    This is stuff we use.
    edited 2014-02-11 21:30
    I wish there was not such a big language barrier between us...!
    Can you please re-post your code with your latest changes?
    Just get rid of the DEBUG CR statement that follows the GOTO..., it will never execute. More important, your SERIN statement in MAIN: is missing the timeout parameter. Without it, your program will stall, waiting for the GPS to send the "RMC" string. You need to add the timeout parameters as was done in the BS2P version. " SERIN GPSpin, T4800, 2000, No_GPS_Data, [WAIT("GPRMC,"), SKIP 65] ". You need to add those two items into the SERIN statement and then write a small block of code labelled No_GPS_Data​ to handle the error in case the GPS stops working. Something similar from the earlier program...
    [COLOR=#3E3E3E][FONT=Parallax]No_GPS_Data:
    [/FONT][/COLOR][COLOR=#3E3E3E][FONT=Parallax]DEBUG CLS, "Error: No GPS data detected"
    [/FONT][/COLOR][COLOR=#3E3E3E][FONT=Parallax]PAUSE 2500
    [/FONT][/COLOR][COLOR=#3E3E3E][FONT=Parallax]GOTO MAIN                       ' Try again[/FONT][/COLOR]
    Good luck
    Hal
    edited 2014-02-12 11:55
    Please disregard all the above.
    Go to the following web site, it has everything you need for your particular GPS module. I found it by Google searching GPS modules by image, and came across the one you picture, and its web site. It also has a BS2 demo program. One thing that stood out is that with the RAW pin unconnected the GPS is in command mode where you have to send a command out to receive anything from the receiver.
    http://www.grandideastudio.com/portfolio/gps-receiver/
    edited 2014-02-12 12:19
    I have been using these modules for years, and I just noticed I can not find the Parallax part number on the part or any documentation that I have.
    I can see where the OP had problems getting the code.
    It could have been gotten off of classic.parallax.com, but now that is in the ether.
    edited 2014-02-12 12:25
    Per the site:
    Parallax, Inc. was the exclusive manufacturer of the GPS Receiver Module. The module has been discontinued as of December 15, 2011.
    From the pictures on the site, the site link is printed on the back of the module. OP could have saved himself a lot of work by simply looking at the board.
    edited 2014-02-12 12:49
    Hal Albach wrote: »
    Per the site:
    Yes, but they had full documentation on the old Parallax site while it was being sold, and when it was discontinued.
    I tried to back up the old Parallax site, but could not. The Wayback Machiche can not access the old site because of robot.txt.
    edited 2014-02-12 22:21
    One thing that stood out is that with the RAW pin unconnected the GPS is in command mode where you have to send a command out to receive anything from the receiver. ??
    edited 2014-02-13 05:42
    spjapple31 wrote: »
    Connect the pin labelled /RAW to Vss (GND).
    edited 2014-02-13 07:28
    Please go to the link I gave you in post #14. The site has all the information available INCLUDING a complete demo program for the BS2. Open the demo program and the notes at the beginning FULLY explains the use of the RAW input. OK?
    edited 2014-02-13 21:43
    OK .However, only two orientations should I go to increase
    1024 x 576 - 44K
    I am not sure what you mean by only two orientations. The screen image shows data for all fields except extended altitude. By the way, according to the coordinates, it puts you in Changhua City, Taiwan, near a University structure with a large domed roof and a swimming pool. Very beautiful!
