How to check that USB driver was installed?
John Kauffman
I'm starting a short course introducing the Prop, following the on-line Learn C pages,
Students are supposed to arrive in class with their Windows laptops set up as per http://learn.parallax.com/propeller-c-set-simpleide/windows
I don't want them to plug in board if they goofed and the USB was not installed.
How can I check their Windows PC to see if the USB was installed?
I looked in device manager but did not see an entry for FTDI (although works fine on this machine)
driverquery /v|find "ftdi"
from the command line to see the drivers...
The installation works fine. If I check my installation with the command driverquery /v|find "ftdi"
I get
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\cardoen>driverquery /v|find "ftdi"
FTDIBUS USB Serial Converter D USB Serial Converter D Kernel Manual
Stopped OK FALSE FALSE 896 58.368 0
13/04/2012 12:05:13 C:\windows\system32\drivers\ftdibus.sys 2.816
Is it normal that I have status Stopped?
I ask this question because each time a connect my propeller board I get the following message
Device driver software was bot successfully installed
Kris
I get this with USB plugged in or unplugged. When plugged in the code has loaded and works
C:\Users\John Kauffman>driverquery /v|find "ftdi"
Stopped OK FALSE FALSE 896 62,208 0
7/12/2013 9:29:07 AM C:\Windows\system32\drivers\ftdibus.sys 2,816
Module Name Display Name Description Driver Type Start Mode State Status Accept Stop Ac
cept Pause Paged Pool Code(bytes BSS(by Link Date Path Init(byt
es
FTDIBUS USB Serial Converter D USB Serial Converter D Kernel Manual Stopped OK FALSE FA
LSE 800.00 36,128.00 0.00 5/18/2006 4:48:49 AM C:\WINDOWS\system32\drivers\ftdibus.sys 2,176.00
Ftdisk Volume Manager Driver Volume Manager Driver Kernel Boot Running OK TRUE FA
LSE 102,400.00 5,888.00 0.00 8/17/2001 4:52:41 PM C:\WINDOWS\system32\DRIVERS\ftdisk.sys 4,096.00
If you leave out the "/v" (verbose) you get less info but it is easier to read (filter on "USB")
driverquery|find "USB"
FTDIBUS USB Serial Converter D Kernel 5/18/2006 4:48:49 AM
FTSER2K USB Serial Port Driver Kernel 5/18/2006 4:49:00 AM
Icam4USB Intel PC Camera Pro Kernel 8/17/2001 5:05:55 PM
U2SP USB to Serial Converte Kernel 8/26/2002 5:29:40 AM
usbaudio USB Audio Driver (WDM) Kernel 7/16/2013 8:58:02 PM
usbccgp Microsoft USB Generic Kernel 8/8/2013 8:55:07 PM
usbehci Microsoft USB 2.0 Enha Kernel 3/18/2009 7:02:22 AM
usbhub Microsoft USB Standard Kernel 4/13/2008 2:45:36 PM
usbprint Microsoft USB PRINTER Kernel 4/13/2008 2:47:37 PM
usbscan USB Scanner Driver Kernel 7/2/2013 9:59:02 PM
USBSTOR USB Mass Storage Drive Kernel 4/13/2008 2:45:37 PM
usbuhci Microsoft USB Universa Kernel 4/13/2008 2:45:34 PM
VNUSB VN Series Device Kernel 4/7/2006 4:06:36 AM
wceusbsh Windows CE USB Serial Kernel 10/27/2006 12:14:42 PM
WinUSB Android USB Driver Kernel 11/2/2006 4:55:05 AM
I always hear a "dong-ding" when I plug in a device, and a "ding-dong" after unplugging.
In a near future version of SimpleIDE, USB ports will automatically be added/removed from the port list when attached/detached.
This is the output I get
C:\Users\cardoen>driverquery|find "USB"
BrFiltLo Brother USB Mass-Stora Kernel 7/08/2006 3:51:06
BrFiltUp Brother USB Mass-Stora Kernel 7/08/2006 3:51:02
BrUsbMdm Brother MFC USB Fax On Kernel 7/08/2006 3:51:00
BrUsbSer Brother MFC USB Serial Kernel 9/08/2006 14:11:02
BTHUSB Bluetooth Radio USB Dr Kernel 28/04/2011 5:54:56
btwampfl Bluetooth AMP USB Filt Kernel 13/07/2010 3:41:18
dg_ssudbus SAMSUNG Mobile USB Com Kernel 14/08/2013 8:47:42
FTDIBUS USB Serial Converter D Kernel 13/04/2012 12:05:13
FTSER2K USB Serial Port Driver Kernel 13/04/2012 12:04:59
ssudmdm SAMSUNG Mobile USB Mo Kernel 14/08/2013 8:47:50
tsusbhub Remote Deskotop USB Hu Kernel 20/11/2010 12:07:10
usbaudio USB Audio Driver (WDM) Kernel 12/07/2013 12:40:58
usbccgp Microsoft USB Generic Kernel 4/09/2013 14:11:49
usbehci Microsoft USB 2.0 Enha Kernel 4/09/2013 14:11:43
usbhub Microsoft USB Standard Kernel 4/09/2013 14:12:10
usbohci Microsoft USB Open Hos Kernel 4/09/2013 14:11:42
usbprint Microsoft USB PRINTER Kernel 14/07/2009 2:38:18
usbscan USB Scanner Driver Kernel 3/07/2013 6:40:12
USBSTOR USB Mass Storage Drive Kernel 20/11/2010 11:44:05
usbuhci Microsoft USB Universa Kernel 4/09/2013 14:11:42
WinUSB WinUSB Service Kernel 20/11/2010 11:43:56
Are there other checks I can perform, because I still get problems when connecting the device
:frown:
The drivers I highlighted in red in your list are FTDI drivers.
Can you be more specific when you say you "get problems when connecting the device"?
Exactly what device, what error or messages are you getting? Do you always get the error or is it sporadic?
You can allow Device Manager to display "hidden devices" (at least under XP)
- right-click "My Computer"
- click "Properties" to bring up the "System Properties" dialog box
- click the "Advanced" tab
- click the "Environment variables" button toward the bottom
- under the "System variables" list click the "New" button
- enter "devmgr_show_nonpresent_devices" for the variable name and "1" for the value and click "OK"
Now when you open Device Manager, click "View" and "Show hidden devices".Under the "Ports" treeview entry you should all the ports - even those not currently in use...
EDIT: To change the assigned port number for a particular port in Device Manager
I was just using regedit
Thanks.
I really doubt that but hopefully it will be helpful. Not sure if it applies to Windows 7 or 8...
I'm sure people have been frustrated trying to view hidden devices.
It doesn't work unless you set the environment variable - what was Microsoft's thinking there?!?
- Ron
