"resolution" of parallax ultrasonic sensors?
Hello.
I want to do the following thing: take the ultrasonic sensors, mount them on a plate, which will be rotated around it's axis by servo. The idea is, to "scan" the area with sensors and find a way to go there. So the question is. Say, two persons are standing 4 feet away from sensor, with distance of 2 feet between them. Will sensor be able distinguish persons and space between them?
http://forums.parallax.com/showthread.php/86110-Ping)))Dar-a-Radar-Style-Display
The reading one gets are typically a set of ranges, ranging from the furthest detectable point to the nearest detectablbe point.
E have to get pretty fancy to dtermine which set of readings belong to different targets, when multiple targets may be presented.
