BS2 OEM dead
Hi Guys,
I have a BS2 OEM that has quit working (the software reports "No Basic Stamps found"). I spent some time debugging and suspect the resonator.
I have a bunch of crystal oscillators and I was wondering if I could desolder the resonator and put a CO in its place, just for debugging purposes.
What do you think?
thanks,
Mr Sparkle
What do you think?
thanks,
Mr Sparkle
If you're referring to 4-pin powered oscillator, you might be able to do this by connecting the output to the XIN pin on the interpreter. If you mean a 2-lead crystal, this probably won't work as the internal drive is set up for the resonator. With the oscillator drive isn't an issue, though you should remove the feedback resistor which is connected in parallel with the resonator. The problem is I think it is built into one of the SIP resistor packs if memory serves.
Just as a note the resonator of often the last thing I would suspect on the BASIC Stamp Module to just stop working. May I ask how you came to that determination?
You didn't post what you see in the Identify window, which would give clues as to the nature of the problem.
Have you measured the BS2 power supply?
I have included a screenshot of the results of Identify (F6). Vin is 9V and the module draws 0.09A, the regulator is putting out a solid 5V.
thanks,
MrS
I am not using a USB to serial adapter. My serial cable connects directly between the BS2 OEM and the serial port on the PC. I have another BS2 OEM I could try if you think that would help, but I have a BS2p40 that I can talk to fine with this serial cable.
What should I try next?
Mr. S
By CO he means a Crystal Oscillator and you already answered his question about it.
Genetix is right, by CO I just meant crystal oscillator, that is, a 4-pin powered oscillator (or "square wave in a can"). I just couldn't think of what else could be wrong and using a CO in place of the resonator seemed like an easy thing to try.
I hope to get back to this problem in a few days.
thanks,
MrS
I see no activity on SDA or SCL on power up, with the scope.
MrS
I have been on the receiving end of the generosity of people on this forum and from Parallax many time so it would be an honor to "pay it forward."
Doc
Unbelieveable yet typical Parallax customer service. Mr. Gracey grants grace!
BTW, the definition of grace is literally unwarranted favor.
Keep that positive reinforcement coming, erco. We'll do whatever you guys want...even finish P2!
mrsparkle, my offer still stands. Just PM me. (I'll cover postage and everything.)
Doc
Thanks for your help, you can close this thread now, I have my answers.
To Ken and doggiedoc, thanks very much for your kind offers. Debugging is something I enjoy, and that was the only reason for this posting.
I've had only positive experiences with Parallax and their user community in the past, and this is just another example of that spirit.
Thanks again,
Mr Sparkle
Pray tell? I've used BS2 OEMs and have been watching this thread.
Also, you're able to mark this thread as "solved" by editing the first post in advanced mode and changing the prefix.
