PASM code not working
Hello All,
The following code is intended for recording the CNT of the positive edge of 18 pulses. The first 12 pulses are 39 kHz , the following phase continious 6 pulses are 41 kHz . The purpose is to determine the CNT of the frequency change point. The code starts but PHSA counter never becomes 1 and it is stuck in the loop.
The pulses are there, verified by osciloscope and also the following PASM code counts them:
Alternatively I have written the following code using INA register instead of the CTRA counter and it works fine.
But what is the problem with the first code.
I am also attaching the spin object.
Thank you
O.A.Ardali
DAT
ORG 0
'---------------------------------Receive_CTRA--------------------------------------------
'Records cnt of the positive edge of 18 pulses
Receive_CTRA mov ctra, CTRArx_ ' set up counter, pos edge trigger
mov frqa, #1 ' 1 count/trigger
mov p4, par
add p4, #16 ' initilize p4 --> T[4}
mov idx, last
:repeat add p4, #4 ' increment p4
mov phsa, #0 ' clear phsa - holds accumulated count
:loop mov timeP, cnt ' renew time_
tjz phsa, #:loop ' repeat until pulse received
wrlong timeP, p4 ' write cnt for pulse idx to T[idx+4]
mov phsa, #0
sub idx, #1 WZ ' Z flag is set if valee = 0
if_NZ jmp #:repeat ' repeat until idx = 0
:exit wrlong last, par
mov ctra, #0
cogid cog_rx
cogstop cog_rx ' stop the cog
CTRArx_ long (%01010 << 26 ) | (0 << 9) | (pin)
RXpin long |< pin
last long 18
idx res 1
timeP res 1
cog_rx res 1
DAT
ORG 0
{---------------------------------CountPulse----------------------------------------
Counts pulses by using CTRA on pin for 1 milisecs and stops the cog
Count mov ctra, CTRArx ' set up counter, pos edge trigger
mov wait2, cnt ' Set cnt0
add wait2, dur_
waitcnt wait2, #0 ' wait for 1 milisec
mov value, phsa
mov p2, par
add p2, #20
wrlong value, p2 ' write value to T[5]
mov ctrb, #0
wrlong last, par
cogid cog_
cogstop cog_ ' stop the cog
CTRArx long (%01010 << 26 ) | (0 << 9) | (pin)
dur_ long 80_000
last long 19
p2 res 1
wait2 res 1
value res 1
cog_ res 1
DAT
ORG 0
'---------------------------------Receive--------------------------------------------
'Records cnt for the positive edge of 18 pulses
Receive_INA
mov p3, par
add p3, #16 ' initilize p3 --> T[4]
mov idx, last_
:repeat add p3, #4 ' increment p3
:loop mov time_, cnt ' renew time_
test RXpin, ina WC ' C flag is set if ina is high (1)
if_NC jmp #:loop
wrlong time_, p3 ' write cnt for pulse idx to T[idx+4]
waitpeq null_, RXpin ' Wait for low signal
sub idx, #1 WZ ' Z flag is set if value = 0
:exit wrlong last_, par
cogid cog_rx
RXpin long |< pin
last_ long 18
null_ long 0
p3 res 1
idx res 1
time_ res 1
cog_rx res 1
Thank you
O.A.Ardali
spin
11K
When phsa is read as a destination register, its shadow register is used instead which, in your case was set to zero when you initialized phsa. The solution is to mov phsa into another register with a wz, then jump on the zero-flag condition.
I suspected tjz statement is the problem but I didn't know the reason.
Thanks again.
O.A.Ardali
