Question about TTL serial inverted versus non-inverted — Parallax Forums
Don MDon M Posts: 1,654
edited 2014-02-06 16:33 in General Discussion
Does the non-inverted serial sit high when idle?
    edited 2014-02-06 14:35
    Yes, it idles high ("mark" state).
  • Don MDon M Posts: 1,654
    edited 2014-02-06 14:41
    Ok then what I'm looking at is an inverted signal. It sits low when idle.
    So how simple of a circuit can be made to invert the signal? I assume I can just use a transistor? I'm trying to sniff some serial data at 9600 baud. I have available 3.3V and ground. The serial data I'm sniffing is 5V level but I want to invert it and feed it into 3.3V sniffer. The sniffer is a Logomatic V2.
    Can someone offer a simple schematic drawing to accomplish this?
    edited 2014-02-06 14:53
    Would this work?
    And if so what would be some values for the resistors?
    454 x 344 - 13K
    edited 2014-02-06 15:54
    Somewhere in the neighborhood of 10K for R1 and 1K for R2 should work just fine.
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    Hi Don;
    Don M wrote: »
    Would this work?
    Yes it would.
    10KΩ for both would work nicely.
    You should add a diode across the base and emitter. Anode to the emitter and cathode, banded end, to the base.
    I know you you are running on only 5V, (which would not require the diode),
    but
    you might want connect to a full spec RS-232 input which can have + - 25V levels.
    This would then breakdown the emitter base junction. Some transistors don't take kindly to this.
    The diode protects this junction.
    Duane J
