Folders — Parallax Forums
Folders
mhm21mhm21 Posts: 14
edited 2014-02-01 21:41 in Propeller 1
I apologize as I am sure this question has been asked 1e6 times. Are there any complilers/IDEs that support accessing objects in a folder outside of where the main code resides? Something akin to a #includes sort of thing is what I am after. I was tidying up some old code and realized I have ~10 different versions of basic_i2c and servo32v 1-9. It would be nice to link to a standard set of objects regardless of what directory I am working out of.
  • JonnyMacJonnyMac Posts: 9,835
    edited 2014-02-01 13:44
    Move common objects to the Propeller Tool Library folder -- on my system the path is:
    C:\Program Files\Parallax Inc\Propeller Tool v1.3.2\Library
    You don't have to do it manually; use File\Save To...\Propeller Library
    Be sure to remove redundant copies of your common objects; I believe the Propeller Tool looks in the local folder first.
  • mhm21mhm21 Posts: 14
    edited 2014-02-01 14:04
    Thanks! Quick and easy solution.
    edited 2014-02-01 20:11
    Are there any other options for using remote repos instead of the default libraries directory?
    edited 2014-02-01 20:19
    Sadly, no -- at least not with the Propeller Tool.
  • jazzedjazzed Posts: 11,803
    edited 2014-02-01 21:12
    Funny how Propeller-Tool gets "sadly" and SimpleIDE gets thrown under the bus.
    SimpleIDE allows setting a library path.
    'Not sure what that has to do with this particular inquiry, but whatever...
    In any event, I'm glad to see at least one Spin-supporting IDE with some flexibility in this regard. My preference would still be to see subdirectory references allowed in the OBJ section, as well, but that's a compiler issue, not an IDE issue.
