SERIN with uLCD-32PTU — Parallax Forums
Henry005Henry005 Posts: 4
edited 2014-02-10 08:30 in BASIC Stamp
Hi All,
I'm communicating between a uLCD-32PTU display module (4D systems) via serial with a bs2p24.
The issue I'm having is when zero's are part of the incoming serial data stream; they are not recognized or skipped over and thus my SERIN command times out.
For example:
SEROUT LCD_Tx, 240, [$FF,$37] 'touch get
SEROUT LCD_Tx, 240, [$00,$01] 'get x value
SERIN LCD_Rx, 240, 2000, timeout, [ack, x1, x2]
The x value returned is word size, so x1 (the high byte of x) will be 00 unless the users finger is on the far side of the screen (length of screen is 320 or 1,64).
How do I get SERIN to fill the x1 variable even if the incoming data are zeros? I have tried various input formatters to no avail.
Thanks for the help.
Henry
  • Hal AlbachHal Albach Posts: 747
    edited 2014-01-29 09:18
    Perhaps trying the HEX formatter may help, ie., SERIN LCD_Rx, 240, 2000, timeout, [HEX3 ack, x1, x2]
  • Henry005Henry005 Posts: 4
    edited 2014-02-05 17:34
    No luck. Hmmmm noticed that ack = 16 when x < 256 and ack = 80 when x >= 256. I added this line of code:
    IF ack = 80 THEN
    x = x + 256
    ENDIF
    And the correct x value can now be used from here. This is just a way around this but something is clearly going wrong here with how I'm using SERIN (ack should always be 06).
    Any help is greatly appreciated.
    edited 2014-02-06 12:10
    If you have a word variable named x that you are receiving serially as high byte then low byte the easiest way to do this is:
    [COLOR=#333333]SERIN LCD_Rx, 240, 2000, timeout, [ack, x.HIGHBYTE, x.LOWBYTE] [/COLOR]
    This will in effect, automatically combine the two byte into the word variable 'x'.
    edited 2014-02-06 13:54
    It would help if we could see more of your code.
    I'm curious if you have tried using the "Serial Commander - Picaso" as a debug tool as an interactive way to see the commands?
    Here are some notes used when writing code for the Propeller and this display...
    Enable Touch Screen:
    Command BYTEs: $FF $38 {mode}  ... return ACK (BYTE)
    ** Note: mode is sent as a WORD variable (2 BYTEs) **
    mode = 0 : Enable Touch Screen
      Enables and initializes Touch Screen hardware
    mode = 1 : Disable Touch Screen
      Disables the Touch Screen.
        Note: Touch Screen task runs in the background and disabling
              it when not in use will free up extra resources for 4DGL CPU cycles.
    mode = 2 : Default Touch Region
      This will reset the current active region to default which is the full screen area
    Define Touch area:
    Command BYTEs: $FF $39 {x1 y1 x2 y2}  ... return ACK (BYTE)
    ** Note: x1,y1,x2,y2 are sent as a WORD variables (2 BYTEs each ; 8 BYTES total) **
    Specifies a new touch detect region on the screen. This setting will filter out any touch
    activity outside the region and only touch activity within that region will be reported by the
    status poll touch_Get(0); function.
    Get touch:
    Command BYTEs: $FF $37 {mode}  ... return ACK (BYTE) + 2 BYTES (1 WORD)
    mode = 0
      Returns the various states of the touch screen
      0 = INVALID/NOTOUCH
      1 = PRESS
      2 = RELEASE
      3 = MOVING
    mode = 1 :
      Returns the X coordinates of the touch
    mode = 2 :
      Returns the Y coordinates of the touch
    edited 2014-02-08 06:10
    touch_test.txt
    I've attached my code above.
    Chris - the above code uses x as a word variable and x.HIGHBYTE, x.LOWBYTE in the SERIN command. The SERIN command times out, even if the touch is in the x>256 area. I still this something fishy is going on with the ack (first byte received) - why would it change from 16 to 80?
    Beau - I have used the serial commander and the display responds as expected. My code initializes the touch hardware (mode = 0), resets the touch area to be the full screen (mode = 2), then goes in to a loop that grabs the x value if a touch is detected.
    Henry
    Henry,
    Not sure why that would happen. The most likely causes are that you're not getting three bytes back or that the baud rate parameters are incorrect. Are other command working (doing what you command)? ou indicated earlier that your ack byte seemed to change from one value to another. I'll have to look at the documentation and see what you should be expecting.
