DC Motors with BOE-BOT or BS2
Hi all,
I want to know if I can use a DC motor with BOE-BOT or BS2
How can I do?
thanks
Thomas
How can I do?
thanks
Thomas
Depending on voltages required, and whether you want it to run only one way, or both ways, you may be able to get away with using a transistor and a couple of resistors to drive it.
In other Words; details!
Voltage: 12V (i can use a different battery to supply the Motors)
Current: 440mA
i want to drive the Motors in both ways
http://www.adafruit.com/products/807
You can even make it easier if you have some servos with damaged electronics. Use the motors in those and attach an H-bridge to replace the PWM control.
where can I find a board?
I need to control 4 DC motors
thanks in advance
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_1341966_-1
Or here is a kit
http://www.rkonlinestore.co.uk/l293d-h-bridge-motor-driver-pcb-self-build-kit-588-p.asp
But there is also the L298 which is better and has complete kits.
https://www.sparkfun.com/products/9670
