How to divide a clock input?
entry 'mov ctra, ctra_ 'REQD establish mode and start counter
movs ctra,#27 'apin ' count external clock p27
movd ctra,#16 'bpin 'carry out on B
movs ctrb,#16 'count p16
movi ctra,#%01011_000 'init ctra pos edge det with carry to Bpin p16
movi ctrb,#%01010_000 'init ctra count only pin p16
mov frqa, freq '$8000_0000 same as dividing clock at p27 by 2
mov frqb, #1
or dira, LEDMASK
or dira, bclkMSK
mov phsa, phsrst
andn outa, ledmask
andn outa, bclkMSK
:loop mov new, phsb 'set counter to 0
cmp new, count1 wz, wc 'REQD change val for LED blinking debug
if_ae or outa, bclkMSK 'ON
if_ae mov temp, cnt
if_ae add temp, Waitlen
if_ae waitcnt temp, temp
if_ae andn outa, bclkMSK 'OFF
if_ae mov phsa, phsrst
if_ae mov phsb, phsrst
jmp #:loop 'REQD
This isn't working but I was hoping someone had a better idea to accomplish this.
_clkmode = xtal1 + pll8x
_xinfreq = 12_288_000
A clock is into p27 at a rate of 384 x 44100 = 16,934,400.
I want to derive another clock from that input that is 384/48 = 8 cycles long, so 4 clocks is high and 4 clocks is low. I have tried setting a counter in posedge mode that counts up 4 clocks, then compare phsa with a value of 4. This is close but I cannot get it as close as I'd like. So the goal instead of counting up to 4 is to let the counter flip a pin every 4 clocks, and then just do something when the pin goes high. The example above is the idea but doesn't work. Any other ideas to accomplish this?
One part of the problem seems to be that in PASM I can't reset phsa, it just keeps counting. The spin equivalent does allow resetting phsa and starting over. The manual states it is a read write register, but also alludes to not being able to write to it.
( Hopefully P2 counters will allow both, as well as HW edge capture.)
ctra,#%01011_000 ' says POSEDGE detector w/ feedback Pin : !A1
ie that is just a delayed copy of the Fi.
On the modes where Counter output is possible :
%00100
%00101
%00110
%00111
there is no GATE or external Fi support.
entry 'mov ctra, ctra_ 'REQD establish mode and start counter movi ctra,#%01010 movs ctra,#apin 'apin count external clock p27 mov frqa, freq '$4000_0000 same as dividing clock at p27 by 2 or dira, LEDMASK or dira, bclkMSK mov new, phsa 'or outa, ledmask 'test the LED :test1 mov temp, phsa ' check bit32 in phsa for a 1 and temp, phsamask wz, wc 'and bit32 to phsa to check for true if_c mov outa, ledmask :loop 'mov phsa, #0 jmp #:test1Another idea(not working yet in this mode) that watches phsa and AND's the carry bit to phsamask (phsamask LONG | <32), check for c flag and turn on an LED which the LED represents the new clock.
Edit: This is looking like a possibility:
:test1 mov temp, phsa ' check bit32 in phsa for a 1 and temp, phsamask wz, wc 'and bit32 to phsa to check for true if_c mov outa, ledmask :loop if_c mov phsa, #0 if_c andn outa, ledmask jmp #:test1 mov new, phsb [/code freq long $4000_0000entry 'mov ctra, ctra_ 'REQD establish mode and start counter movi ctra,#%01010 movs ctra,#apin 'apin count external clock p27 'movd ctra,#bpin 'bpin carry out on B 'movs ctrb,#16 'count p16 'movi ctra,#%01011_000 'init ctra pos edge det with carry to Bpin p16 'movi ctrb,#%01010_000 'init ctra count only pin p16 mov frqa, freq '$4000_0000 same as dividing clock at p27 by 2 'mov frqb, #1 or dira, LEDMASK or dira, bclkMSK or LEDMASK, bclkMSK 'merge for debug using LED and bitclock p15 mov new, phsa 'or outa, ledmask :test1 mov temp, phsa ' check bit32 in phsa for a 1 and temp, phsamask wz, wc 'and bit32 to phsa to check for true if_c mov outa, ledmask nop nop nop nop :loop if_c mov phsa, #0 if_c andn outa, ledmask nop nop jmp #:test1I want a high cycle of .2363 and period of .4724. You can get either larger or smaller times, but the increments are just too big to nail it. This will get by.
74HC6323 Can't find that at my supplier, though digikey stock it, the common ripple counter is the
74HC393 (2 4-bit counters which can be chained) and its dirt cheap and may be more widely available.
Oops, I meant the 4040.
It's a nice part that includes the Xtal OSC buffer, and comes in a smaller SO8, but seems to have never hit critical mass.
It is very easy to apply, and small, even if a bit expensive for what it is*
There is a surprising lack of a simple/cheap logic device that has Xtal Osc and simple dividers.
Torex do some, but they are laser-programmed so are semi custom.
* For a more complex part, but a better price/performance point, look at the SI5351A-B-GT
This is $1.30/1+, and can generate pretty much ANY frequency you want 10KHz~160MHz, just add a std 25/27MHz Xtal
I also like the Si504, easier to configure than SI5351A-B-GT, and includes the OSC element for $3.07/1+ @ Digikey,
