Brad Campell BST on MacOS 10.6.8, no source window — Parallax Forums
Bart FoxBart Fox Posts: 3
edited 2014-01-26 11:59 in Propeller 1
Hi all,
I want to programm my Parallax Propeller with MacOS.
I recently found the BST Propeller Suite from Brad Campell.
I downloaded bst-0.19.3.osx.zip, unzip and run the application. But if I select a spin file for open, no source window appears.
There is only the menu bar visible.
Is there a trick to use bst on 10.6.8?
I also tried the following versions:
bst-0.19.2-Pre1.osx.zip
bst-0.19.4-pre12.osx.zip
bst-0.19.4-pre13.osx.zip
bst-0.19.4-pre14.osx.zip
But no success at all.
Thank you for every hint!
regards,
Bart
  • T ChapT Chap Posts: 4,249
    edited 2014-01-26 03:36
    It should work. When you hit load file, you get a blank window with no text appearing? Can you make a screen shot? Which mac?
  • Bart FoxBart Fox Posts: 3
    edited 2014-01-26 04:04
    T Chap wrote: »
    No. I get no window.
    I also get no window on most menu items, e.g. "Compile -> Compile Information"
    BST seem to update the window list, but I can't see the windows, see screenshot.
    The Computer is an Intel-Mac (MacBook Pro, 2009 with MacOS X 10.6.8)
    regards,
    Bart
    326 x 272 - 41K
    bst.png 40.8K
    edited 2014-01-26 08:49
    Bart Fox,
    Welcome to the forum. I'm sorry to hear you are having problems with BST. It is a very nice tool and one that I used for a long time.
    Sadly Brad Campell is not supporting BST any more. For a long time now. As BST is a closed source program there is not much anyone can do to support it.
    There is an alternative now a days: SimpleIDE. You can get it from here: http://learn.parallax.com/node/640
    Don't be misled by all the talk of programming in C on those pages, SimpleIDE also supports programming in Spin.
    edited 2014-01-26 11:49
    Heater. wrote: »
    It was not quite obvious that SimpleIDE also works with Spin. It looks great and run out-of-the-box.
    Thank you!
    Best regards,
    Bart
    Bart,
    You are right. It's not obvious at all. I wonder why not.
