BOE Board and LI-Po battery board
Buck Rogers
Hello!
I have here the #28986 board with the suggested batteries in it. It's also wearing the suggest spacers on it. It does fit perfectly under the BOE Board I am using at the moment.
However I am planning on assembling a BOE-Bot soon so I am wondering if the #28986 board is the one that the company suggests for powering a bot using that power source. However the video supplied with the page http://www.parallax.com/product/28986 shows the duo putting the widget under the bot's chassis.
And is there more then one battery board for using LI-Po batteries?
As it happens I've got one of them here, and I checked and it will just barely fit. But the servos may not allow it.
Does this one get placed under the BOE and then both get bolted to the top of the chassis?
Chassis shown here http://www.parallax.com/product/700-00022
So I'm I bit confused about all of that.
Oh and what does the tail ball use for mounting?
I used the Li-Ion board with my PropBOE-Bot.
Hello!
Okay good then. That makes much better sense. It seems to me that the BOE Bot using this battery board, is using it as a base for its processor over the chassis.
Hello!
Even better. Good example there.
Say? Where are you located in the state? I've actually been there, twice.
Southeast area of the state. We're just north of Pocatello and about an hours drive north of Utah. Pocatello and Chubbuck are located at the junction of I-15 and I-86.
Hello!
That's what I thought. Right by the Mountain Home Airforce base. (It's a big one that is or was used to train fighter pilots for a certain family of birds.)
We were traveling via the end that abuts the state of Washington.
