XBee and altimater
Hello
I was asking my self if it's possible to plug the http://www.parallax.com/product/29124 Altimeter to the http://www.parallax.com/product/32411 XBee 900HP module whiteout passing by a propeller ?
I want to send the altimeter data to the xbee and then receive it by another xbee module and print the data on a screen whit a propeller is that possible ?
Thank you
Thank you
I'm pretty sure you'd need a microcontroller to read the altimeter. It looks like the altimeter needs to have the data clocked out.
I think the XBees can be used directly with sensors that output asynchronous serial and I think it's also possible to use them with sensor that have an analog output but I'm pretty sure I2C and SPI communication requires a microcontroller. I think the altimeter uses an I2C type protocol.
http://tymkrs.tumblr.com/post/28769360469/making-the-altimeter-module-wireless-w-xbee
The only question I have is for the XBee base and remote.
Can you tell me what is the configuration for these ? Are they in AT or API mode? I think they are in AT but I just want to be sure :-)
Thank again !
Ok thank you !
