school project
I have a 74hc595n IC shift register chip which i am trying to use to control an 7segment display, my problem is that i have found little documentation on how to communicate between the chip and the boe bot. i know that i should probably be using a 74xx47 IC but due to time constraints i don't have time to order one.
I used '595 shift registers in my 7-segment clock (controlled with a Propeller).
You might be able to find a better example using Rich's forum search page.
BTW, Welcome to the forum. I hope you let us know how your project turns out.
