Board from optical mouse
Not sure if it is my imagination, but at one time did Parallax sell the guts from an optical mouse? Working on a project to detect movement and this seems easier than using an accelerometer. I have eviscerated many mice, but would like to find a commercial source.
Thanks in advance,
Todd
Thanks in advance,
Todd
http://store.3drobotics.com/products/px4flow
You might still be able to find that part number used in the original product.
It is a good fit. In many ways it is a lot easier and cheaper than building a rotary encoder of high accuracy from scratch. You can use a 3 inch CD disk for a surface that is attached to the wheel or the bigger 5.5 inch if you have the room.
There are sources..
http://www.amazon.com/Logitech-Wireless-Mouse-Circuit-910-002416/dp/B007CWD3IK
http://www.a-power.com/product-27298
http://www.alibaba.com/showroom/mouse-pcb-board.html
https://classic.parallax.com/Store/Accessories/HumanInterfaceDevices/tabid/822/ProductID/677/List/1/Default.aspx?SortField=ProductName,ProductName
which is too bad because I have one and it's neat and easy to interface to a microcontroller.
https://www.sparkfun.com/products/retired/10105
I wanted to use it to monitor the movement of standard fabric cloth. X-Y doesn't matter it is simply the velocity of the cloth.
Anyway, thanks again for the info.
Todd
http://diydrones.com/profiles/blogs/adns3080-optical-flow-sensor-now-available-in-the-diydrones-store
The part number is ADNS3080
You might take a look at these:
http://www.digikey.com/product-search/en/sensors-transducers/optical-sensors-mouse/1966634
For years I've heard how accelerometers could be used to do some kind of robot location, or mouse positioning as you mentioned. I personally haven't seen this done yet, so I'm interested in where you're headed.
Yesterday I came across a very interesting use of an optical mouse board of horizontal collision avoidance of a quad-copter flying outdoors in bright daylight. It was a You-Tube video and really a very useful feature if you are flying in an obstacle prone area.
Here is a downward looking video of a flight demo.
http://www.youtube.com/watch?v=RDuq6y9siOE
Here is the horizontal positioning.
And the hacking into a mouse.
http://www.youtube.com/watch?v=bbS1N--bT0w
http://www.bidouille.org/hack/mousecam
Todd
