Weird servo behavior, can't find it in my code
                    I've got a modified version of the SumoWrestler code from the Applied Robotics pack. It's been modified to use 2 Ping sensors. They are working just fine, but for some reason, the right servo seems to be freaking out randomly (most typically in a CurveRight or RotateRight maneuver). Below is the code in its entirety. Any help would be appreciated:
                            ' -----[ Title ]--------------------------------------------------------------' Applied Robotics with the SumoBot - SumoWrestler.bs2
' SumoWrestler.bs2 modified so that each state is contained by a
' subroutine.
' {$STAMP BS2}                               ' Target = BASIC Stamp 2
' {$PBASIC 2.5}                              ' Language = PBASIC 2.5
' -----[ I/O Definitions ]---------------------------------------------------
ServoLeft      PIN     13                    ' Left servo connected to P13
ServoRight     PIN     12                    ' Right servo connected to P12
qtiPwrLeft     PIN     10                    ' Left QTI on/off pin P10
qtiSigLeft     PIN     9                     ' Left QTI signal pin P9
qtiPwrRight    PIN     7                     ' Right QTI on/off pin P7
qtiSigRight    PIN     8                     ' Right QTI signal pin P8
DummyPin       PIN     6                     ' I/O pin for pulse-decay P6
PingPin        PIN     15                    ' Left Ping Sensor SIG Pin
PingPin2       PIN     14                    ' Right Ping Sensor SIG Pin
PingLedLeft    PIN     1                     ' Debug LED for Left Ping Status
PingLedRight   PIN     0                     ' Debug LED for Right Ping Status
QTILeftLed     PIN     3                     ' Debug LED for Left QTI Status
QTIRightLed    PIN     2                     ' Debug LED for Right QTI Status
' -----[ Constants ]----------------------------------------------------------
InConstant  CON   890                        ' Constant for converting Ping echo time to distance
inDistance  VAR   Word                       ' Distance for left Ping
inDistance2 VAR   Word                       ' Distance for right Ping
time        VAR   Word                       ' Stores ping echo time
' SumoBot maneuvers
Forward        CON     0                     ' Forward
Backward       CON     1                     ' Backward
RotateLeft     CON     2                     ' RotateLeft
RotateRight    CON     3                     ' RotateRight
PivotLeft      CON     4                     ' Pivot to the left
PivotRight     CON     5                     ' Pivot to the right
CurveLeft      CON     6                     ' Curve to the left
CurveRight     CON     7                     ' Curve to the right
' Servo pulse width rotations
FS_CCW         CON     850                   ' Full speed counterclockwise
FS_CW          CON     650                   ' Full speed clockwise
NO_ROT         CON     750                   ' No rotation
LS_CCW         CON     770                   ' Low speed counterclockwise
LS_CW          CON     730                   ' Low speed clockwise
' IR object detectors
IrFreq         CON     38500                 ' IR LED frequency
' -----[ Variables ]----------------------------------------------------------
temp           VAR     Word                  ' Temporary variable
multi          VAR     Word                  ' Multipurpose variable
counter        VAR     Byte                  ' Loop counting variable.
maneuver       VAR     Nib                   ' SumoBot travel maneuver
sensors        VAR     Byte                  ' Sensor flags byte
qtiLF          VAR     sensors.BIT5          ' Stores snapshot of QtiSigLeft
qtiRF          VAR     sensors.BIT4          ' Stores snapshot of QtiSigRight
irLS           VAR     sensors.BIT3          ' State of Left Side IR
irLF           VAR     sensors.BIT2          ' State of Left Front IR
irRF           VAR     sensors.BIT1          ' State of Right Front IR
irRS           VAR     sensors.BIT0          ' State of Right Side IR
' -----[ EEPROM Data ]--------------------------------------------------------
RunStatus      DATA    0                     ' Run status EEPROM byte
QtiThresh      DATA    Word 0                ' Word for QTI threshold time
' -----[ Initialization ]-----------------------------------------------------
GOSUB Reset                                  ' 5 Second delay
GOSUB Calibrate_Qtis                         ' Determine b/w threshold
GOSUB Look_About                             ' Was Goto Look_About
' -----[ Main Routine ]-------------------------------------------------------
DO
  IF qtiLF = 1 THEN                         ' Left qti sees line?
    GOSUB Avoid_Tawara_Left                  ' State = avoid left tawara
  ELSEIF qtiRF = 1 THEN                     ' Right qti sees line?
    GOSUB Avoid_Tawara_Right                 ' State = avoid right tawara
  ELSEIF irLF = 1 AND irRF = 1 THEN          ' Both? Lunge forward
    GOSUB Go_Forward                         ' State = Go forward
  ELSEIF irLF = 1 THEN                       ' Just left?
    GOSUB Track_Front_Left_Object            ' State = Track front left obj.
  ELSEIF irRF = 1 THEN                       ' Just right?
    GOSUB Track_Front_Right_Object           ' State = Track front right obj.
  ELSE                                       ' Nothing sensed?
    GOSUB Search_Pattern                     ' State = Search pattern
  ENDIF
LOOP
' -----[ Subroutine - Reset ]-------------------------------------------------
Reset:
  READ RunStatus, temp                       ' Byte @RunStatus -> temp
  temp = temp + 1                            ' Increment temp
  WRITE RunStatus, temp                      ' Store new value for next time
  IF (temp.BIT0 = 1) THEN                    ' Examine temp.BIT0
    DEBUG CLS, "Press/release Reset", CR,    ' 1 -> end, 0 -> keep going
               "button..."
    END
  ELSE
    DEBUG CR, "Program running..."
  ENDIF
  RETURN
' -----[ Subroutine - Calibrate_Qtis ]----------------------------------------
Calibrate_Qtis:
  HIGH qtiPwrLeft                            ' Turn left QTI on
  HIGH qtiSigLeft                            ' Discharge capacitor
  PAUSE 1
  RCTIME qtiSigLeft, 1, temp                 ' Measure charge time
  LOW qtiPwrLeft                             ' Turn left QTI off
  multi = temp                               ' Free temp for another RCTIME
  HIGH qtiPwrRight                           ' Turn right QTI on
  HIGH qtiSigRight                           ' Discharge capacitor
  PAUSE 1
  RCTIME qtiSigRight, 1, temp                ' Measure charge time
  multi = (multi + temp) / 2                 ' Calculate average
  multi = multi / 4                          ' Take 1/4 average
  IF multi > 220 THEN                        ' Account for code overhead
    multi = multi - 220
  ELSE
    multi = 0
  ENDIF
  WRITE QtiThresh, Word multi                ' Threshold to EEPROM
  RETURN
' -----[ Subroutine - Servos_And_Sensors ]------------------------------------
Servos_And_Sensors:
  GOSUB Pulse_Servos                         ' Call Pulse_Servos subroutine
  ' Call sensor subroutine(s).
  sensors = 0                                ' Clear previous sensor values
  GOSUB Read_Object_Detectors                ' Call Read_Object_Detectors
  GOSUB Read_Line_Sensors                    ' Look for lines
  RETURN
' -----[ Subroutine - Pulse_Servos ]------------------------------------------
Pulse_Servos:
  ' Pulse to left servo
  LOOKUP maneuver, [ FS_CCW, FS_CW, FS_CW, FS_CCW,
                     NO_ROT, FS_CCW, LS_CCW, FS_CCW ], temp
  PULSOUT ServoLeft, temp
  ' Pulse to right servo
  LOOKUP maneuver, [ FS_CW, FS_CCW, FS_CW, FS_CCW,
                     FS_CW, NO_ROT, FS_CW, LS_CW ], temp
  PULSOUT ServoRight, temp
  RETURN
' -----[ Subroutine - Read_Object_Detectors ]---------------------------------
Read_Object_Detectors:
  PULSOUT PingPin, 5              ' Send short pulse to Ping
  PULSIN PingPin, 1, time         ' Wait for echo
  inDistance = inConstant ** time
  GOSUB Pulse_Servos              ' Called to avoid pausing/stuttering on servos
  IF inDistance < 12 THEN
    irLF = 1
    HIGH PingLedLeft
  ELSE
    irLF = 0
    LOW PingLedLeft
  ENDIF
  PULSOUT PingPin2, 5              ' Send short pulse to Ping
  PULSIN PingPin2, 1, time         ' Wait for echo
  inDistance2 = inConstant ** time
  GOSUB Pulse_Servos
  IF inDistance2 < 12 THEN
    irRF = 1
    HIGH PingLedRight
  ELSE
    irRF = 0
    LOW PingLedRight
  ENDIF
  RETURN
' -----[ Subroutine - Read_Line_Sensors ]-------------------------------------
Read_Line_Sensors:
  HIGH qtiPwrLeft                            ' Turn on QTIs
  HIGH qtiPwrRight
  HIGH qtiSigLeft                            ' Push signal voltages to 5 V
  HIGH qtiSigRight
  PAUSE 1                                    ' Wait 1 ms for capacitors
  READ QtiThresh, Word temp                  ' Get threshold time
  INPUT qtiSigLeft                           ' Start the decays
  INPUT qtiSigRight
  PULSOUT DummyPin, temp                     ' Wait threshold time
  qtiLF  = ~qtiSigLeft                       ' Snapshot of QTI signal states
  qtiRF = ~qtiSigRight
  IF qtiLF = 1 THEN
  HIGH QTILeftLed
  ELSE
  LOW QTILeftLed
  ENDIF
  IF qtiRF = 1 THEN
  HIGH QTIRightLed
  ELSE
  LOW QTIRightLed
  ENDIF
  LOW qtiPwrLeft                             ' Turn off QTIS
  LOW qtiPwrRight
  RETURN
' -----[ Subroutine - Avoid_Tawara_Left ]-------------------------------------
Avoid_Tawara_Left:
  FOR counter = 1 TO 7                      ' Back up
    maneuver = Backward
    GOSUB Servos_And_Sensors
  NEXT
  FOR counter = 1 TO 7                      ' Turn right
    maneuver = RotateRight
  NEXT
  RETURN
' -----[ Subroutine - Avoid_Tawara_Right ]------------------------------------
Avoid_Tawara_Right:
    maneuver = Backward
  NEXT
  FOR counter = 1 TO 7                      ' Turn left
    maneuver = RotateLeft
  NEXT
  RETURN
' -----[ Subroutine - Go_Forward ]--------------------------------------------
Go_Forward:
  maneuver = Forward                         ' 1 forward pulse
  RETURN
' -----[ Subroutine - Track_Front_Left_Object ]-------------------------------
Track_Front_Left_Object:
  counter = 0
  DO UNTIL (irLF = 1 AND irRF = 1) OR counter > 7
    maneuver = CurveLeft                     ' Curve left 15
    counter = counter + 1
  LOOP
  DO UNTIL (irLF = 1 AND irRF = 1) OR counter > 15
    maneuver = RotateLeft                    ' Rotate left 30
  LOOP
  RETURN
' -----[ Subroutine - Track_Front_Right_Object ]------------------------------
Track_Front_Right_Object:
  counter = 0
    maneuver = CurveRight                    ' Curve right 15
  LOOP
    maneuver = RotateRight                   ' Rotate right 30
  LOOP
  RETURN
' -----[ Subroutine - Track_Side_Left_Object ]--------------------------------
Track_Side_Left_Object:
  DO UNTIL irRF = 1 OR irLF = 1              ' Rotate left
  LOOP
  RETURN
' -----[ Subroutine - Track_Side_Right_Object ]-------------------------------
Track_Side_Right_Object:
  DO UNTIL irRF = 1 OR irLF = 1              ' Rotate right
  LOOP
  RETURN
' -----[ Subroutine - Search_Pattern ]----------------------------------------
Search_Pattern:
  FOR counter = 1 TO 20                      ' and watch all sensors
    maneuver = Forward                       ' Forward
    IF sensors <> 0 THEN GOTO Next_State
  NEXT
  Look_About:
  FOR counter = 1 TO 6                      ' Look right
  NEXT
  FOR counter = 1 TO 12                      ' Look left
  NEXT
  FOR counter = 1 TO 6                      ' Re-align to forward
  NEXT
  Next_State:                                ' Exit point of search pattern
  RETURN
Try swapping sensors to see if the problem is with one of the sensors.
