Add-on boards for Propeller Project Board USB
Is there any chance that Parallax can be talked into making a Quickstart Proto Board that would have a larger SMD area than is currently available on the Project Board, both SOT-23 and SO-64? Having that ability on the Project Board has opened up a wide range of possibilities for using SMD devices that are not available in thru-hole. Since the Project Board has the Quickstart header one could use the same Project Board with several different Proto Boards for developing various projects. Maybe even expand the Proto Board size to match the Project board.
Hal
Hal
