is there a C library that hasfunctions to save and run programs from SD card?
In the propeller BOE tutorials, there are Spin objects for loading Spin programs to the SD card and then have an object in a Spin program load and run a program from the SD card (which in turn can load and run another program etc.)
Is there a C library that has functions that would do that? (load and run a C program) Or if not can you give any suggestions on how that would be done?
Tom
Tom
There are several posts here that talk about using Spinix: http://forums.parallax.com/showthread.php/148959-Getting-started-with-Spinix?p=1193830&viewfull=1#post1193830
