Problem with BOE-BOT servomotors
Dear all,
I have a problem with the servomotors of my Boe Bot.
I explain my issue;
I tryied to test my servomotors with this command:
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
when I test one servomotor with this command "PULSOUT 13, 650 or 850" it works! but when I try both servomotors together, one of them turns only in one way even if I change the pulses (650 clockwise, 850 counterclockwise)
I hope you can help me
I explain my issue;
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
Also be sure you're running your BOE Bot with a fresh set of batteries in the 6V battery pack. Old/weak batteries, or trying to use a 9V "transistor" battery, won't deliver enough current to run two servos at once.
At least Gordon and I are trackin'.
Sorry for double post
how many current needs the boe-bot in order to work properly?
Try swapping the servos and associated output pins to see if the problem follows the pins or
stays with the servo.
I tried to change the pins (before Left = pin13, after Left = pin12) but nothing changed.
42.
Okay, old Hitchhiker's Guide joke. Don't worry about the current numbers. Just use fresh AAs batteries, and not old ones, and certainly not a 9V battery.
Like Erco sez, be sure to calibrate those motors. They don't always come from the box calibrated.
Now i use a fresh AAs rechargeable batteries and i tried to calibrate both motors with this code:
Left motor
DEBUG "Program Running"
DO
PULSOUT 13, 750
PAUSE 20
LOOP
Right motor
DO
PULSOUT 12, 750
PAUSE 20
LOOP
now they seems to work!!!
Therein lies the rub. NiMH cells are lower voltage than alkalines. Are you using 4 or 5 cells?
See http://www.parallax.com/search?search_api_views_fulltext=boe+boost
5 AA cell battery holder
http://www.parallax.com/product/753-00007
