compile problem with EEPROM instruction
Hi All,
I'm starting a project using a Homework Board to drive a 12 character 5x7 display. I want to use EEPROM to store text. When I compile I get an error message "Label Is missing ':'"
EEPROM 0, ("Parallax Basic Stamp Homework Board") When I click Syntax Check or Run EEPROM is highlighted and I get an error window that says " Label is missing ':' " The symble looks like a colon. I've checked and rechecked but I can't find any problem with this statment.
comments please,
Wayne
' {$STAMP BS2}
' {$PBASIC 2.5}
Dpin PIN 4
Clk PIN 5
Red PIN 8
Yel PIN 9
Green PIN 10
Avar VAR Byte
Bvar VAR Byte
Cvar VAR Byte
counter VAR Byte
EEPROM 0,("Parallax Basic Stamp Homework Board")
Start:
comments please,
Wayne
Looks like you've mixed BS1 commands with the BS2 directive - {$STAMP BS2}.
The EEPROM command is for the BASIC Stamp 1.
I believe the DATA command would be equivalent for the BS2.
Should it work, consider marking this thread as solved.
