So I downloaded the S2 Scribbler software and... — Parallax Forums
hapaluahapalua Posts: 149
edited 2014-01-03 15:43 in Robotics
I was wondering how do you get access to the SPIN code?
    edited 2014-01-03 10:26
    In the S2 Program Maker, click on the icon in the top bar with the white arrow pointed to the yellow legal pad. This will open up the S2 Spin source code in the Propeller Tool.
    edited 2014-01-03 10:28
    Do you want to see the Spin code generated by the GUI? If so, go to the top toolbar and select the item towards the middle that looks like a piece of notebook paper.
    If you hover over it, it will show "View the Propeller Program"
    EDIT: Ken types faster than me!
  • hapaluahapalua Posts: 149
    edited 2014-01-03 10:31
    hahahaha this is funny
    edited 2014-01-03 10:32
    hapalua wrote: »
    What's funny? That Ken types faster than me? :)
    edited 2014-01-03 10:36
    Wow thats a lot of code! Why is there so much?
    edited 2014-01-03 10:37
    Yeah it was hilarious
    edited 2014-01-03 11:09
    Nevermind I figured out the code... And finally ,on this subject, how do you revert back to the GUI?
    edited 2014-01-03 11:14
    hapalua wrote: »
    The GUI should still be open in a tab at the bottom, (Windows).
    edited 2014-01-03 12:31
    To get back to the GUI, you have to exit the Propeller Tool. Also, any changes you make to the Spin code will not be reflected in the GUI program.
    edited 2014-01-03 13:11
    Phil, I'm able to switch back and forth between the two.
    Of course the Spin code will not be updated with changes to the GUI.
    Maybe I misunderstood your response.
    (I've been know to do that. :)
    1024 x 624 - 95K
    edited 2014-01-03 14:46
    Wow. That's not supposed to happen -- and doesn't on my WinXP system. The idea was to prevent multiple instances of the PropTool being spawned by the GUI by hiding the GUI completely when the PropTool is open. Which version of Windows are you using?
    Windows XP SP 3.
    Jim
    EDIT: OK I tried to replicate it.
    Opened S2 GUI.
    Viewed Code from the toolbar.
    GUI disappeared.
    So it works as you say.
    I must have opened the GUI after the Prop tool was opened.
