Multiple cog access to a ADC routine issue — Parallax Forums
DiverBobDiverBob Posts: 1,127
edited 2014-01-06 14:01 in Propeller 1
I discussed an issue I'm having in the robotics forum but I think I have a better chance for success here.
I am running 3 DC motors with feedback via potentiometers for each motor via an MCP3208, 8 channel ADC chip. Additionally, each motor control routine is in a seperate cog so each motor can run independently from the others. There is an ADC routine in the main cog that takes an average of ten readings and returns the ADC value back to the calling routine. The problem is that each motor cog is calling the ADC routine at the same time and this results in bad data being returned
I got a suggestion to use Spin locks but after reading the manual I don't see how they could help in this instance. Does anyone have some suggestions on how to resolve this problem or is there a way to use locks to provide a more orderly access to the ADC routine?
Thanks for the help!
  • JonnyMacJonnyMac Posts: 9,835
    edited 2014-01-03 08:01
    For one of my projects I created a cog that read and averaged the ADC inputs, then wrote them to a known location in the hub. Other cogs would read these locations instead of calling the ADC directly.
    I think the easiest way to do this would be to have one cog continually refresh the ADC values which would be stored in a global variable. The other cogs would then access the variable to learn the latest ADC value.
    edited 2014-01-03 08:30
    I don't know if I have the code anymore but I had built an I2C driver that uses locking to make it safe to use one bus for multiple cogs doing multiple things. The idea was that when a cog called START a lock was obtained. That lock was released only when a STOP or ABORT was issued. That allowed for the cogs to call on the I2C bus as a shared resource and a bus transaction could not be interrupted by another cog calling START. It seemed to work pretty well but was not something found in most off-the-shelf I2C objects. I had modified a PASM I2C implementation for this purpose so it handled clock stretching and repeated starts. I was going to add timeouts to the implementation but then I switched to C++ development for my robot and I2C activity moved to the BeagleBone Black so I never developed it more.
    I would think a similar approach could work in this case. Jhonny+Duane's idea is valid too. One cog is reading the beJesus out of the ADC and storing the results where any other cog can come and get it. You can then use filtering on the results too. This works fine as long as that SPI bus is dedicated to the ADC.
  • DiverBobDiverBob Posts: 1,127
    edited 2014-01-03 09:43
    JonnyMac wrote: »
    That was the idea one of the guys in the office had. I could run the ADC routine in a seperate cog, read all 8 inputs and store them in global variables. I already have the motor cogs monitoring variables for determining when to take action. The only disadvantage of this is that I'll have 4 cogs dedicated to the motors and reading ADC values, a cog for floating Point calcs, a cog for serial comms, and one cog for the main loop. This only leaves 1 cog for any other functionality. First time I've come this close to running out of processors!
    I'll give this a shot tonight and see how well it works. Should I do anything to 'lock' a global variable just prior to reading it in case the ADC routine is trying to update it while the motor routine is reading the value?
    Bob
    edited 2014-01-03 10:03
    DiverBob wrote: »
    Bob
    So long as the whole value you need is stored in a single LONG there is no need. Hub round robin means that only one cog can be reading or writing that LONG at each access window.
    edited 2014-01-03 12:22
    Good point, I didn't put 2 and 2 together, forgot about the hub configuration means there can't be a conflict. Thanks for the reminder.
    edited 2014-01-03 19:44
    Each cog has two counters that you can use for motor control; you could squeeze four cogs down to two, use one more for the ADC reading/averaging and still net one more cog for the project.
    edited 2014-01-04 05:15
    JonnyMac wrote: »
    I'm not sure I'm following your logic on this. This is a general description of how the code is designed right now.
    I output a PWM to a HB25 to control speed and direction of the motor. A potentiometer provides the feedback mechanism. The code for this receives an angle input. The software then translates the angle to a value. The actual ADC value is compared to the desired position to determine direction. Next it starts the motor at full speed in that direction while watching the changing ADC values. Once it gets close to the desired value, the speed is gradually reduced and the stopped at the desired ADC value. That's the basic operation, a series of repeats while testing for specific conditions.
    I'll post my current motor control code when I get back to my other computer so you can see how it works. I didn't get an opportunity to work on the code last night but we are in a winter storm warning for the next two days so I should have lots of time to experiment!
    Bob
    edited 2014-01-04 09:05
    If your motors are being controlled by HB25s you could easily squeeze that into a single cog -- you've just gone from four cogs down to one for motor controller.
    As I read your post, though, I'm thinking "HB25s are set-and-forget" -- why use a cog at all? I coded a pan/zoom controller for a friend that uses an MCP3204 and two servos (to drive the lens rings). The code is setup to run in a 20ms loop. In the top of the loop I read the ADC four times and do an average, then I drop through and create pulses for the servos using one of the counters. Easy-peasy.
    The real question is: Are you connecting a pot to a motor that could be programmed to run past its limit? This could result in damage. What I would suggest is attaching an encoder to the motor shaft. On another project for the same friend, we control three DC motors on a pan/tilt/trolley camera rig. We need two cogs for motors (because we're providing signals to the H-Bridge) and one cog for the encoders. There is another cog that is used for speed and location management. We know from empirical testing the how to convert encoder counts in a given period to speed. We can also use the encoder value for location. In the end that lets the user create a camera movement that we can record and playback.
    This is the product.
    -- http://cameraturret.com/genesis.htm
    This company started doing camera controls with the BASIC Stamp, migrated to the SX (with my help), and is now using the Propeller (also with my help).
    edited 2014-01-04 16:50
    JonnyMac wrote: »
    Two of the motors are linear actuators with integral limit switches and potentiometer. Since their is no output from the limit switches I have an error check that sees if the ADC value is static, this lets me know if it's at a limit. The third motor uses a reduction gear train and the output gear is programmatically limited to a swing of 120 degrees. No limit switches on this item yet. The feedback pot is directly connected to the output gear and it uses the same routine to stop the motor if the ADC is not changing so the motor can be stopped. Other than the third motor encoders can't be used on the linear actuators.
    I would be interested in seeing the code loop you used for controlling multiple DC motors if possible. Thanks for the good ideas. I've already had some success with putting the ADC routine in its own cog and having it continuously updating the position variables.
    edited 2014-01-04 18:32
    Here is a copy of the test code I'm working with right now. It is working but not very well behaved. The test now is to enter 3 angle values and have the motors move the robot leg to those angles. I'm getting excessive overshoot which causes hunting and it appears to be hanging up on one of the motor routines. I need to test each individually, I'm testing the tibia with this version. My brain is fried from looking at code most of the day so I'm missing something, will have to try again in the morning. Let me know if you see anything obvious! Thanks!
    ''   File....... Hexapod IK Test 1.spin
    ''   Purpose.... Create series of test routines for leg control using IK
    ''   Author..... Bob Sweeney
    ''   Started.... 12/29/13
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
      MS_001   = CLK_FREQ / 1_000
    con
      #1, HOME, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR, #16, CLS      ' PST formmatting control
    con
      RX1 = 31
      TX1 = 30
      SDA = 29
      SCL = 28
      CS  =  7
      CLK =  8
      DIO =  9
      femur = 16
      tibia = 17
      coxa = 18
      Degrees       = (180.0/pi)
      Radians       = (pi / 180.0)
      TravelDeadZone = 0.5
      Trigger5      = 0
      CoxaLength    = 2.5
      FemurLength   = 6.0
      TibiaLength   = 20.625
      CoxaAngle     = 90.0
    obj
      adc           : "jm_mcp3208_ez"
      motor         : "Servo32v9.spin"
      F             : "Float32Full"
      pst           : "Parallax Serial Terminal"
    var
      word  Femurcounter, TibiaCounter, CoxaCounter
      long CoxaAngle1, FemurAngle1, TibiaAngle1
      long VPosX, VPosY, VPosZ
      long femurStack[200], tibiaStack[200], coxaStack[200], adcstack[100]
      word FemurADC, TibiaADC, CoxaADC
      word FemurDone, TibiaDone, CoxaDone
    pub Start | angle1, angle2, angle3
      F.Start
      pst.Start(115200)                                                             ' Start the Parallax Serial Terminal cog
      motor.start
      cognew(GetADC, @adcstack)
      dira[femur] := 0        'femur motor output
      dira[tibia] := 0        'tibia motor output
      dira[coxa] := 0        'coxa motor output
      repeat until ina[femur] == 1
      repeat until ina[tibia] == 1
      repeat until ina[coxa] == 1
      waitcnt(MS_001 + cnt)                                                         ' let objects load
      FemurDone := 0
      TibiaDone := 0
      CoxaDone := 0
      IKFemurAngle := 90
      IKTibiaAngle := 90
      IKCoxaAngle := 0
    '  cognew(FemurMotorRun, @femurStack)
      cognew(TibiaMotorRun, @tibiaStack)
    '  cognew(CoxaMotorRun, @coxaStack)
      waitcnt(100000 + cnt)                                                         'let objects load
      repeat
        repeat while FemurDone == 1 AND TibiaDone == 1 AND CoxaDone == 1              'wait for motor move to complete
        EnterAngle
    pub EnterAngle | a1, a2, a3
      a1 := 0
      a2 := 0
      a3 := 0
    '  pst.Str(String(pst#NL, "Enter Coxa angle: "))                                    ' Prompt user to enter value
    '  pst.Dec(a1)
    '  a1 := pst.DecIn
      pst.Str(String(pst#NL, "Enter Tibia angle: "))                                    ' Prompt user to enter value
      pst.Dec(a2)
      a2 := pst.DecIn                                                          ' Get value
    '  pst.Str(String(pst#NL, "Enter Femur angle: "))                                    ' Prompt user to enter value
    '  pst.Dec(a3)
    '  a3 := pst.DecIn                                                          ' Get value
    '  IKCoxaAngle := a1
      IKTibiaAngle := a2
    '  IKFemurAngle := a3
      repeat while (coxadone == 0) OR (femurdone == 0) OR (tibiadone == 0)
    pub FemurMotorRun | TargetADC, ActualADC, initialADC, t1, t2, error, speed
     ' input ADC value via PST and the motor moves to that angle
      dira[femur] := 1        'femur motor output
      repeat
        Femurcounter := 1
        error := 0
        waitcnt(200000 + cnt)                                                         'let objects load
        FemurDone := 0
        'convert angle to ADC value and return result
        if IKFemurAngle < femurMinAngle                                'setup default min and max angles
          IKFemurAngle := femurMinAngle
        elseif IKFemurAngle > femurMaxAngle
          IKFemurAngle := femurMaxAngle
        t1 := (femurMaxADC - femurMinADC) * (IKFemurAngle - femurMinAngle)
        t2 := t1 / (femurMaxAngle - femurMinAngle)
        TargetADC := ||t2 '+ femurMinADC
        ActualADC := femurADC
        initialADC := ActualADC
      {  pst.Str(String(pst#NL, "Input Angle: "))
        pst.Dec(inputAngle)
        pst.Str(String(pst#NL, "Start Femur ADC: "))
        pst.Dec(ActualADC)
        pst.Str(String(pst#NL, "Target ADC: "))
        pst.Dec(TargetADC)}
        t1 := ||(TargetADC - ActualADC)
        if t1 > 30        'get absolute value of change
          if TargetADC < ActualADC                                                    'determine movement direction, move up
            speed := 2000
            repeat until ||(TargetADC - ActualADC) =< 50                                                     'repeat full speed until ramp down
              motor.Set(femur, speed)
      '        pst.Str(String(pst#NL, "Max Femur up speed: "))
      '        pst.Dec(ActualADC)
      '        pst.Str(String("  - speed: "))
      '        pst.Dec(speed)
              if FemurStopError(initialADC, ActualADC)                            'stop if ADC not changing
                motor.Set(femur, 1500)
                error := 1
                quit
            repeat until TargetADC => (ActualADC - 25)                                      'start down ramp
              if error == 1
                quit
              ActualADC := FemurADC
      '        pst.Str(String(pst#NL, "Move Femur up - Ramping down: "))
      '        pst.Dec(speed)
              speed := speed - 50                                                     'decrement count
              t2 := speed
              t2 <#= 2000                                                             'max speed 2000
              speed := t2 #>= 1550                                                    'min speed 1600
                quit
              if (ActualADC == 0)                                                     'stop motor
                quit
          else        'move down
            speed := 1000                                                             'set start speed
      '        pst.Str(String(pst#NL, "Max Femur down speed: "))
      '        pst.Dec(speed)
                error :=1
                quit
            repeat until TargetADC =< (ActualADC)                                       'start down ramp
              if error == 1
                quit
      '        pst.Str(String(pst#NL, "Move Femur down - Ramping down: "))
      '        pst.Dec(speed)
              speed := speed + 50                                                     'decrement count
              t2 := speed
              t2 #>= 1000                                                             'min speed 1000
              speed := t2 <#= 1450                                                    'max speed 1400
                quit
              if (ActualADC == 0)                                                     'error catch - stop motor
                quit
        FemurDone := 1        'ready to continue
      {  pst.Str(String(pst#NL, "STOP Femur "))
        pst.Str(String(pst#NL, "Entered angle: "))
        pst.Dec(inputangle)
        pst.Dec(TargetADC)
        pst.Str(String( "  - Final ADC: "))
        pst.Dec(ActualADC)
        pst.Chars(pst#NL, 2)
    pub FemurStopError(iADC, aADC)
      FemurCounter := FemurCounter + 1        'count to 5
      if FemurCounter == 1        'at start get ADC value
        iADC := aADC
      if FemurCounter == 5        'max count 5
        FemurCounter := 0
        if iADC == aADC                                                             'error, ADC not changing
          Result := true
    pub TibiaStopError(iADC, aADC)
      TibiaCounter := TibiaCounter + 1        'count to 5
      if TibiaCounter == 1        'at start get ADC value
        iADC := aADC
      if TibiaCounter == 5        'max count 5
        TibiaCounter := 0
          Result := true
    pub CoxaStopError(iADC, aADC)
      CoxaCounter := CoxaCounter + 1        'count to 5
      if CoxaCounter == 1        'at start get ADC value
        iADC := aADC
      if CoxaCounter == 5        'max count 5
        CoxaCounter := 0
          Result := true
    pub TibiaMotorRun | TargetADC, ActualADC, initialADC, t1, t2, error, speed
      dira[tibia] := 1        'femur motor output
      repeat
        TibiaCounter := 1
        error := 0
        TibiaDone := 0
        if IKTibiaAngle < tibiaMinAngle                                'setup default min and max angles
          IKTibiaAngle := tibiaMinAngle
        elseif IKTibiaAngle > tibiaMaxAngle
          IKTibiaAngle := tibiaMaxAngle
        t1 := (tibiaMaxADC - tibiaMinADC) * (IKTibiaAngle - tibiaMinAngle)
        t2 := t1 / ||(tibiaMaxAngle - tibiaMinAngle)
        TargetADC := ||t2  '+ tibiaMinADC
        ActualADC := TibiaADC
        pst.Dec(IKTibiaAngle)
        pst.Str(String(pst#NL, "Start Tibia ADC: "))
        pst.Dec(ActualADC)
        pst.Dec(TargetADC)}
        if t1 > 40        'get absolute value of change
            speed := 2000                                                             'set start speed
            repeat until ||(TargetADC - ActualADC) =< 75                               'repeat full speed until ramp down
              Motor.Set(tibia, speed)
              pst.Str(String(pst#NL, "Max Tibia speed in: "))
              pst.Dec(ActualADC)
              pst.Dec(speed)
              if TibiaStopError(initialADC, ActualADC)                            'stop if ADC not changing
                Motor.Set(tibia, 1500)
                error := 1
                quit
            repeat until TargetADC => (ActualADC - 75)                                'start down ramp
              if error := 1
                quit
              pst.Str(String(pst#NL, "Move Tibia in - Ramping down: "))
              pst.Dec(ActualADC)
              pst.Dec(speed)
              t2 := speed
                quit
                quit
          else        'move down
              pst.Str(String(pst#NL, "Max Tibia speed out: "))
              pst.Dec(ActualADC)
              pst.Dec(speed)
                error := 1
                pst.Str(String(pst#NL, "Tibia Error: "))
                pst.Dec(initialADC)
                quit
            repeat until TargetADC =< (ActualADC + 50)                                'start down ramp
              if error == 1
                quit
              pst.Str(String(pst#NL, "Move Tibia out - Ramping down: "))
              pst.Dec(ActualADC)
              pst.Dec(speed)
              t2 := speed
                quit
                quit
        TibiaDone  := 1
      {  actualADC := TibiaADC
        pst.Str(String(pst#NL, "STOP Tibia"))
        pst.Dec(TargetADC)
        pst.Dec(ActualADC)
        actualADC := tibiaADC
        pst.Str(String(pst#NL, "Final ADC: "))
        pst.Dec(ActualADC)
    pub CoxaMotorRun | TargetADC, ActualADC, initialADC, t1, t2, error, speed
      dira[coxa] := 1                                                               'coxa motor output
      repeat
        CoxaCounter := 1                                                            'used for error catching
        error := 0
        CoxaDone := 0                                                               'flag when move is complete
        IKCoxaAngle := IKCoxaAngle + 90                                               'convert from range +60 - -60 degrees
        if IKCoxaAngle < coxaMinAngle                                                 'setup default min and max angles
          IKCoxaAngle := coxaMinAngle
        elseif IKCoxaAngle > coxaMaxAngle
          IKCoxaAngle := coxaMaxAngle
        t1 := (coxaMaxADC - coxaMinADC) * (IKCoxaAngle - coxaMinAngle)                'calculate ADC target based on
        t2 := t1 / ||(coxaMaxAngle - coxaMinAngle)                                    'slope of line; dY/dX
        TargetADC := ||t2 + coxaMinADC                                                'add in minimum adc value
        ActualADC := CoxaADC                                                        'get current ADC value
        initialADC := ActualADC                                                     'save starting valve
        t1 := ||(TargetADC - ActualADC)                                             'setup deadzone value
          if TargetADC > ActualADC                                                  'determine movement direction, move up
            speed := 1800                                                           'set start max speed
              Motor.Set(coxa, speed)
              ActualADC := CoxaADC                                                  'get adc value
              if CoxaStopError(initialADC, ActualADC)                               'stop if ADC not changing
                Motor.Set(coxa, 1500)
                error := 1                                                          'error occurred
                quit        'exit loop
              if error == 1
                quit
              t2 := speed
              speed := t2 #>= 1550                                                  'min speed 1550
                quit
                quit
          else        'move down
            speed := 1200                                                           'set start max speed
                error := 1
                quit
            repeat until TargetADC =< (ActualADC + 25)                              'start down ramp
              if error == 1
                quit
              t2 := speed
                quit
                quit
        CoxaDone := 1
    pub GetADC | i, n, ch
      adc.start(CS, CLK, DIO)                                                       ' start adc driver
      repeat
        repeat ch from 0 to 2
          i := 0
          repeat n from 0 to 9                                                     'average readings over 10 cycles
            i := i + adc.read(ch, 1)
          case ch
            0: femurADC := i/10
            1: tibiaADC := i/10
            2: coxaADC := i/10
    dat
    femurMinAngle word 35
    femurMaxAngle word 142
    femurMinADC word 0
    femurMaxADC word 3650
    tibiaMinAngle word 86
    tibiaMaxAngle word 143
    tibiaMinADC word 3840
    tibiaMaxADC word 70
    coxaMinAngle word 30
    coxaMaxAngle word 150
    coxaMinADC word 1440
    coxaMaxADC word 2235
    edited 2014-01-04 18:57
    The code loop I discussed works with devices like servos or the HB-25; the DC motor controller requires a separate cog to run two motors (the code use the counters in a timed loop for precise pwm frequency and duty cycle control).
    It would have been useful to see your code. As that's not available yet, I knocked up this little demo to give you some ideas. This program uses just the main cog. The ADC is read and averaged at the top of the loop, those values are converted to speed/direction values (in microseconds), then the motors are updated. The loop runs every 50ms (20x/second).
    Tip: For averaging it's useful to select a loop count that's a power of 2 (I used 4); this lets you divide by using a right shift which is much faster than division.
    [Edit] You posted your code while I was posting -- I'll have a look and update my suggestion if warranted.
    edited 2014-01-04 20:01
    Wow... that's, ummm... okay, my eyes are bleeding.
    Question: With the pots tied to the motors you know what the range limits are, correct?
    While working on the pan/tilt/trolley project I called on one of my friends here in Hollywood as he had built a lot of motorized camera rigs for Disney. He explained an easy way to accelerate from a starting point and then decelerate into a target point. This works when you have absolute position values (as we did using the encoders, and you should with the pots).
    In simple terms the move is divided into four phases:
    -- A: Accelerate up to desired max speed, then calculate delta to mid-point
    -- B: Run to mid-point of move
    -- C: Run to deceleration point (value calculated from end of phase A)
    -- D: Decelerate into target
    In phase A of the move the speed is ramped up to the desired maximum. When this is reached, the distance between the current position and the mid-point of the move is calculated. The motor runs to the mid-point (phase B). In phase C the motor continues at max speed the same distance as phase B. In phase D the speed is ramped down until the target is reached.
    In practice I divided phase D into 3 sections: 80% of the phase D distance ran at the normal deceleration rate; then I slowed the rate for another 15%; the final 5% of the move ran very slowly. By doing this we never had overshoot and we were able to get the pan/tilt/trolley rig to hit marks dead on in multiple passes. The code was fairly simple using a state-machine for each motor, with phase D being divided into three sub-states.
    I've attached my servo object for your consideration: it has built in ramping (microseconds change per second of real time) and a method that will return true when a ramping channel is at the target position; this feature would be useful in implementing the trapezoidal move described above.
    Forgive me if this is overly simplistic for what you're doing; I'm only offering this up in the hopes of being helpful.
    776 x 391 - 29K
    edited 2014-01-05 08:35
    I appreciate any and all input! I know, the code is getting pretty complex, there are are a variety of ways to skin this cat. I've already gone through 4 very different motor control routines, this one has brought the most consistant results but there is bound to be a way to make it simpler.
    I want to give a go at coding using a single loop like your previous post example and see how well that responds. The acceleration/ deceleration process you described sounds good also, I'm not happy with what I have right now. I even removed the acceleration code to cut down on the complexity.
    Thank you, these are all good ideas that allow me to explore some different ways to implement the code.
    I tested a new version of the motor controller that is greatly simplified. However I haven't added any type of ramping speed control and minimal error checking to it just so I could concentrate on the basics. This last version has the motor swinging the leg back and forth in a 120 degree arc from -60 to +60 degrees reliably but with a lot of jerking at the start and stopping points.
    The CoxaMotorRun cog monitors the global value CoxaAngle. It determines the target ADC value and moves the motor until it gets within a deadzone around the value. The calculation for the targetADC is based on the assumption that the slope of the potentiometer output is linear. The routine GetTarget had some issues and wouldn't work right until I broke out the Y1, Y2, X1 and X2 values and converted them to float outside of the equation. Once I did that everything started working right. Haven't gone back to figure out what was happening there.
    Where the speed is manually set to 1300 and 1700 is where I need to add the ramping functions. I spent a few hours searching the forum for examples. I liked the sine wave and S curve approaches to ramping, just haven't figured out how to implement yet. I'll work on that later, I want to use this same layout for the Tibia motor and get both motors running together when sent angle commands. Its getting closer to what I am looking for.
    ''   File....... Hexapod Leg Test 2.spin
    ''   Purpose.... Create routines for leg control
    con
    con
    con
      RX1 = 31
      TX1 = 30
      SDA = 29
      SCL = 28
      CS  =  7
      CLK =  8
      DIO =  9
      femur = 16
      tibia = 17
      coxa  = 18
      stopmotor = 1500
    obj
    '  motor         : "Servo32v9.spin"
      F             : "Float32Full"
    var
      long CoxaAngle
      long coxaStack[200], adcstack[100]
      long pot[8]
      word CoxaADC, CoxaDone, CoxaCounter
    pub Start | n
      F.Start
      motor.start
      waitcnt(10000000 + cnt)                                                         ' let objects load
      CoxaDone := 0
      CoxaAngle := 0
      n := 0
      repeat
    '    EnterAngle
          case n
            0: coxaAngle := 0
            1: coxaAngle := -60
            2: coxaAngle := 60
            3: coxaAngle := 60
            4: coxaAngle := -60
            5: coxaAngle := 60
            6: coxaAngle := -60
            7: coxaAngle := 60
            8: coxaAngle := -60
          n++
          if n == 9
            n := 0
          waitcnt(320000000 + cnt)                                                         'let objects load
    pub EnterAngle
      CoxaAngle := pst.DecIn
      pst.Dec(CoxaAngle)
    pub CoxaMotorRun | TargetADC, ActualADC, speed, workangle
      repeat
    '    coxaangle := 60
        CoxaAngle := -60 #> CoxaAngle <# 60                                         'constrain input
        workangle := CoxaAngle + 90                                                 'convert from range +60 - -60 degrees
        'calculate ADC value for input angle
        TargetADC := GetTarget(workangle)
        if ||(ActualADC - TargetADC) > 10
          if (ActualADC - TargetADC) > 0                                          'determine motor direction
            speed := 1300
          else
            speed := 1700
          motor.Set(coxa, speed)
        else
          motor.Set(coxa, stopmotor)                                                    'stop motor, inside deadzone
    pub GetTarget(angle)| y1, y2, x1, x2, m, b
      'calculate ADC value using slope of line, y=mx+b where m = y1-y0/x1-x0
      y1 := f.ffloat(coxaMinADC)
      y2 := f.ffloat(coxaMaxADC)
      x1 := f.ffloat(coxaMinAngle)
      x2 := f.ffloat(coxaMaxAngle)
      m := f.fdiv(f.fsub(y2,y1), f.fsub(x2, x1))
      b := f.fsub(y2,f.fmul(x2, m))
      result := f.fTrunc(f.fadd(f.fmul(m, f.ffloat(angle)), b))
      repeat
        coxaADC := adc.read(2, 1)
    dat
    coxaMaxADC word 2240
    {{ Terms of Use: MIT License
      Permission is hereby granted, free of charge, to any person obtaining a copy of this
      software and associated documentation files (the "Software"), to deal in the Software
      without restriction, including without limitation the rights to use, copy, modify,
      merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
      permit persons to whom the Software is furnished to do so, subject to the following
      conditions:
      The above copyright notice and this permission notice shall be included in all copies
      or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
      INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
      PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
      HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
      CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
      OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
