ADC recomendation — Parallax Forums
ADC recomendation
JavalinJavalin Posts: 892
edited 2014-01-03 01:08 in Propeller 1
Happy new year all,
Ignore
Many Thanks
James
  • JavalinJavalin Posts: 892
    edited 2014-01-02 05:20
    scratch that - just found one. (finally!)
    edited 2014-01-02 05:45
    What part did you settle on?
    edited 2014-01-02 05:49
    Actually once I'd written it out the issue, I realized that (a) the MCP3208 has enough resolution (5/4096 = 0.001v per bit) so increasing to 0-10v on 12bits wouldn't help (10/8192 = 0.002v per bit), and (b) I think the accuracy of the system is lost elsewhere.
    Additionally I'd probably lose a fair bit of resolution with 14bit/16bit due to noise.
    edited 2014-01-02 08:54
    Yes, the MCP3208 makes it all very easy with the Propeller's 3.3 volt.
    I just finished a build for the ADC8032 which requires 5.0 power and is only 8 bits. I had to add three 2N700 level shifters to get it all working -- lots of extra work. I only did so because I had the chip here.
    edited 2014-01-02 09:46
    Javalin wrote: »
    Google Bonnie Baker and ADC; will return a pile of good stuff.
    FF
