Solve and display Floating Point Values like 3.222 x 23.378E3 in a FIfth Order Poly
Hi Propeller Wizards!
Happy New Year yall!
I made a video explaining what I am trying to do...
http://www.screencast.com/t/KHeWitl10
(It is also attached in the zipped file FifthOrder.mp4.zip (8.02 MB) case you do not have the BW to view..)
In short I want to be able to multiply floating point numbers and display them.. I am sure what I want is not the best in programming practices but I want to be able to multiply numbers like 3.123 E 5 * 21.345 which is the same as 312300 * 21.345 as an example...
For example, a Polynomial curve fit such as this....
I want to see how to solve a fifth order polynomial with Spin...I have the Coefficients A, B, C, D, E and F
for a fifth order and want to find y for a given value of x:
y = -3.467E+0 + 150.429E+4x - 136.520E-3x^2 + 247.626E+0x^3 - 71.985E+0x^4 + 7.264E+0x^5.
The code I attached is a good example of using many elements of the Propeller with the serial port, floats, Saving to EE and more.
I hope to see a number of forum Black Belt Wizards do some AWESOME stuff so we all can learn lots of cool stuff!
Here is the code I am using (Also attached in the ZIP file):
I would LOVE to see how to output floating point numbers for display. I am so spoiled with LabVIEW that all this is automatic and I am also driving a DAC to drive a 0-5 Output for a linear representation of the input variable, X, that drives the Polynomial scaled to 0-4096 that is scaled to drive a 12 bit DAC.
I have absolutely no pride of authorship on any of my code and TOTALLY welcome anyone to make it all it can be so everyone can benefit.
DAT programName byte "_TestFifthOrderFit_DriveDAC 01234567", 0 {Keep versions up here, last 7 CHRS}
Polynomial curve fit..
Seems there are LOTS of FP Objects but I must say a
polynomial would be an EXCELLENT one for folks to deal with nasty transfer functions and drive those oh so common non-linear
systems!
CON 'Constants. Set up pin assignments
'_clkmode = xtal1 + pll16x 'Config for Parallax demo boards using 5 MHz Xtals.. '
'_xinfreq = 5_000_000
_clkmode = xtal1 + pll8x ' For 10 MHZ Xtal div by 8 on xtal1
_xinfreq = 10_000_000
' _clkmode = xtal1 ' For 10 MHZ Xtal div by 8 on xtal1
' _clkfreq = 10_000_000 ' From Pg 66/399 of Propeller Manual Not sure why this does not work.
RED_1 = 17 ' Any LED may be set to any pin. Just replace "led + 1" with the pin number.
VERSION_SIZE = 7 ' Last characters of "ProgramName" string used as
' version ID at line 1 of DAT above.
'serial port pins
RX_PIN = 31
TX_PIN = 30
MODE = 0
BAUDRATE = 115200
CS = 16 'CHr 16 to Clear Screen
QUOTE = 34 'Chr 34 for "
' 12 Bit DAC using 4822 or 4922.. Woth work GREAT!
DAC_CS = 2 ' 12 Bit DAC Chip Sel
DAC_SCK = 1 ' 12 Bit DAC SCK
DAC_SDI = 0 ' 12 Bit DAC SDI
coeff = 0.7 ' coeff = 0.07 DMK.. Why can not get 0.07 to work?
dkval = 144
ZeroVal = 0
SpanVal = 4096 '4096
SenserionSpan = 32700
' iA = -3.467 ' In the end I want to store these in EE and then read these out of EE
' iB = 150429.0 ' I want to store big numbers in here.. Know how to do that??
' iC = -0.13652
' iD = 247.626
' iE = -71.985
' iaF = 7.264
' Constants here cuz I could not figure out how to get LONGS anywhere else...
iA = 2.0 ' In the end I want to store these in EE and then read these out of EE
iB = 2.0 ' I want to store big numbers in here.. Know how to do that??
iC = 2.0 ' All 2's -> 126
iD = 2.0
iE = 2.0
iaF = 2.0
' B = 4000000.0 'Floating-point constants
' C = 4414442.5
' D = 4414442.5
B = 7.6654 'Floating-point constants
C = 38.7544
D = 12.5333
MIN_PERIOD = 5 ' for blinkrate.. should be 100??
MAX_PERIOD = 2000 ' for blinkrate.. Should be 1000??
MAX_STRING_SIZE = 40 'set the maximum string length to be sent using terminal
OBJ ' External routines called by this program Must be in the same directory as this program
Serial : "Serial4PortFlag131029a" 'Serial that Smart guys LOVE! Supports <CR> termination
Tv : "Mirror_TV_Text" ' Echo
F : "Float32" ' 32 bit floats
DAC : "MCP4922" ' 2 Chan 12 bit DAC
FTS : "FloatString" ' Float routines
Eeprom : "dwd_PropellerEeprom"
VAR 'GLOBALS
long t100, RawTick, LSmooth, Smooth, FitVal, OutZS 'Global RawTick
long rxFlag, previousRxFlag
long ms ' delay in ms
long periodAddress, countAddress
long commandPtr
long FirstFit, SecondFit, ThirdFit, FourthFit, FifthFit , SixthFit
long Scratch, Scratch1, Scratch2, Scratch3, Scratch4, Scratch5 , Scratch6 , ShowMe , SHowMeF
byte parameterReceivedFlag
byte keyBdLine[MAX_STRING_SIZE + 1] 'this is the line that holds the final info
byte rawParameter[MAX_STRING_SIZE + 1]
PUB Main | coefficient
Initialize
Serial.Str(0, string(13, "I Love Amara Dec 25, 2013 Line 103 Main"))
' Pause(3000) 'HOW LONG IS THIS???It is 3 seconds in NORMAL time...
LSmooth := 2000 ' Init with something..
RawTick := 3000 ' Init value
repeat
'RawTick := 30000 'Stub in value...
'Serial.Str(0, string(16, QUOTE, "CLS Issued.... ", QUOTE)) ' <<<CLEAR SCREEN>>>>
if rxFlag <> previousRxFlag 'every time a CR is recd this executes
previousRxFlag++
'DisplayFlags("0")
GetTermCmd
Smooth := F.Fadd(F.Fmul(coeff,(F.Fsub(RawTick,LSmooth))),LSmooth)
LSmooth := Smooth
'FitVal := FifthOrder(Smooth) 'FitVal := FifthOrder(f.ffloat(11))
FitVal := FifthOrder(F.FFloat(Smooth)) 'FitVal := FifthOrder(f.ffloat(11))
' FItVal := fahrenheit(100.00978)
OutZS := F.FMul(F.Fsub(Smooth,ZeroVal),F.Fdiv(SpanVal,SenserionSpan)) ' Drive 0-4096
if OutZS > 4096
OutZS :=4096
if OutZS < 0
OutZS := 0
' DAC.Set(0, 4095) ' Channel A 0-5 VDC half-range 2048 = 2.5V with 5V reference)
' DAC.Set(1, 4095)
DAC.Set(0, OutZS) ' Channel A 0-5 VDC half-range 2048 = 2.5V with 5V reference)
DAC.Set(1, OutZS) ' Channel B 4-20 mA half-range 2048 = 2.5V with 5V reference)
DisplayDMK
DisplayValues
waitcnt(80_000_000 + cnt) ' waitcnt(80_000_000 + cnt) 1 second
PUB GetTermCmd | tCommandChr, characterCount, negativeFlag, commandLong[2], longCount
'' commandLong will hold the first for non-numeric characters of the command.
'' This value will be used in various case statements to find the desired
'' branch of the program to follow.
'' This method converts uppercase characters to lowercase and the
'' method also extracts numeric characters to use as the command's
'' parameter.
'' "result" is a local variable cleared to zero no other locals are cleared
parameterReceivedFlag := 0 'Local flags.. Need to know if parameters received cuz 0 is valid
negativeFlag := 0 'if neg character cuz number may be 0.. wait till get all even though we do not use -
characterCount := 0 'We are interested in first 4 characters of commands
longfill(@commandLong, 0, 2) ' so string has a terminating zero local.. Threy do not get cleared.. So need to clear
longCount := 0 ' clear local var
repeat
tCommandChr := Serial.rxcheck(0) 'We strip out the chrs...
if tCommandChr == -1 'This should never happen.. Only if a bug...
Serial.Str(0, string(13, "Input error characters expected."))
Serial.Str(0, string(13, "No carriage return received."))
return 0
elseif tCommandChr == 13 'Now we have a CR
KeyBdLine[characterCount++] := 0 'Storing message in KeyVdLine
'Serial.Str(0, string(13, "String received = ", QUOTE))
'Serial.Str(0, @KeyBdLine)
'Serial.Str(0, string(13, "Command received = ", QUOTE))
'Serial.Str(0, @commandLong)
'Serial.Tx(0, QUOTE)
elseif tCommandChr => "A" and tCommandChr =< "Z" 'to lowercase while we're looking anyway
KeyBdLine[characterCount++] := tCommandChr + 32 'adding 32 goes to lowercase.. adding and convert to lc
if longCount < 4 'adding to see if we are at a long yet.
commandLong.byte[longCount++] := tCommandChr + 32 'this gets them in the right position to display long as string.
elseif tCommandChr => "0" and tCommandChr =< "9" 'Checking for numbers 0-9 extract and parameters values
result *= 10 'to shift over one digiit
result += tCommandChr - "0" 'this converts from ASCII to numeric..
parameterReceivedFlag := 1 ' now we have a number so set flag
KeyBdLine[characterCount++] := tCommandChr 'add this to our KeyBdLine string...
elseif tCommandChr == "-" ' check for neg flag to make a neg number later if we need
negativeFlag := 1 'a negative sign anywhere in string will set flag
elseif tCommandChr > 32 and tCommandChr =< 127 'ignore space and non-printable ASCII
if longCount < 4 'only want letters a space will mess it up . 32 cuz 32 is a space
{else
Serial.Str(0, string(13, "Unexpected character = $"))
Serial.Hex(0, tCommandChr, 2)
Serial.Str(0, string(13, "The character has been ignored."))}
if characterCount > MAX_STRING_SIZE 'make sure we do not blow up stringsize..
tCommandChr := DumpRxBuffer 'we show this in the rxbuffer...
Serial.Tx(0, $0D)
Serial.Dec(0, tCommandChr)
Serial.Str(0, string(" additional characters received."))
Serial.Str(0, string(13, "Terminal command not executed."))
return 0
while tCommandChr <> 13 'while tCommandChr not CR cuz we do not need this...
if negativeFlag 'got in line 487
-result 'this NEGATES the result with -result..
'Serial.Str(0, string(13, "Parameter received = "))
'Serial.Dec(0, result)
ExecuteCmd(commandLong, result)
PUB DumpRxBuffer | tCommandChr
'' Used to help track down bugs.
'' This method will only be used if a
'' string longer than "MAX_STRING_SIZE" is entered.
Serial.Str(0, string(13, "DumpRxBuffer method"))
Serial.Str(0, string(13, "rxFlag = "))
Serial.Dec(0, rxFlag)
Serial.Str(0, string(13, "previousRxFlag = "))
Serial.Dec(0, previousRxFlag)
repeat
Serial.Str(0, string(13, "Rx buffer is now empty."))
quit ' quit loop
Serial.Str(0, string(13, "Carriage return found at last."))
result++
quit
else
Serial.Tx(0, tCommandChr)
result++
PUB ExecuteCmd(localCommand, parameter) | index, compare 'LocalC0mmand are letters Param is the number - or not
' Below is the current list of commands.
' redOn, greenOn, redAll, greenAll, bothOn, bothAll, altAll, allAlt, off, allOff, offAll
' rblink, gblink, rgblink, altblink, cmdL, setperiod
commandPtr := FindCommandPtr(localCommand) 'This goes through and finds the string associated with command in DAT below.
if commandPtr == @cmdNotFound
Serial.Str(0, @cmdNotFound)
Cmd
return
Serial.Str(0, string(13, "Command ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Str(0, commandPtr)
Serial.Str(0, string(QUOTE, " received."))
case localCommand
ledon,ledoff, {
} cmdL, help, dispdmk, version: 'A line break may be hidden in a comment.
' commands for all those don't require a parameter
'Serial.Str(0, string(13, "Parameter not needed for this command."))
' make sure it's not evaluated with parameter equals zero batch
' All the which don't apply to individual commands
other:
if parameterReceivedFlag
'Serial.Str(0, string(13, "Parameter included with command = "))
'Serial.Dec(0, parameter)
else
parameter := GetParameter(localCommand)
ifnot parameterReceivedFlag
DisplayParameterError(localCommand)
Cmd
return
Serial.Dec(0, parameter) 'turn all on with 0...
if parameter == 0 and parameterReceivedFlag 'parameterReceivedFlag is global
case localCommand 'CMDS with params Local Command no parameter. if typed ron may need to add it.
setperiod: 'We set the period for the heartbeat LED
Serial.Str(0, string(13, "Zero is not a valid heartbeat period."))
Serial.Str(0, string(13, "Setting period to MINIMUM value..."))
Serial.Str(0, string(13, "MIN_PERIOD = "))
Serial.Dec(0, MIN_PERIOD)
' Led.SetPeriod(MIN_PERIOD)
' Eeprom.FromRam(@decLedMs, @decLedMs + 3, @decLedMs)
Serial.Str(0, string(13, "Blink period has been backed up to EEPROM."))
other:
Serial.Str(0, string(13, "Command with parameter of zero not found."))
Cmd
else
case localCommand 'These are have no param or param that has been set to 0 Most will be here
cmdL, help:
Cmd
dispdmk: ' must be lc by golly!!
DisplayDMK
version:
DisplayVersion
setrawtick:
SetRawTickVal(parameter)
RawTick := parameter
setperiod:
SetPeriods(parameter)
'Eeprom.FromRam(@decLedMs, @decLedMs + 3, @decLedMs)
Serial.Str(0, string(13, "Blink period has been backup to EEPROM."))
other:
Cmd
PUB SetRawTickVal(count)
''How do I stub in a RawTick value??
long[countAddress] := count
PUB SetPeriods(timeInMs)
'' Set the half period of the LED flashing.
'' Use timeInMs for both on time and off time.
long[periodAddress] := timeInMs
PUB Cmd : localPtr
Serial.Str(0, string(13, 13, "This is the Cmd method."))
Serial.Str(0, string(13, "List of possible commands:", 13))
localPtr := @ledon
repeat
if byte[localPtr]
Serial.Tx(0, byte[localPtr++])
else
Serial.Tx(0, ",")
Serial.Tx(0, " ")
repeat while byte[localPtr] == 0
localPtr++
while localPtr < @setperiod + strsize(@setperiod)
Serial.Tx(0, $0D)
PUB Initialize 'I start ALL the cogs in here
Serial.Init(@rxFlag)
Serial.AddPort(0, RX_PIN, TX_PIN, -1, -1, -1, MODE, BAUDRATE)
Serial.Start
' waitcnt(clkfreq + cnt ) 'Wait 1 sec.
Serial.Str(0, String(13, "serial port started"))
Serial.Str(0, String(13, "programName = "))
Serial.Str(0, @programName)
Serial.Tx(0, $0D )
' Show the version of the program that is currently
' loaded into the Propeller
F.Start 'Start FP Cog
'Pause(100)
' Tv.start(TvBasepin) 'Start TV Cog
' Tv.out( $00 ) 'Clear Screen
'Init DAC
DAC.Init(DAC_CS, DAC_SCK, DAC_SDI) 'CS, SCK, SDI respectively
DAC.Set(0, 1) 'Set Channel A to 0 half-range 2048 (2.5V with 5V reference)
DAC.Set(1, 1) 'Stub in values for test
PUB DisplayVersion
'' Use the last 7 characters of the program name
'' as the version ID from the DAT on line 1 above..
'' Is there a way to use actual spin name??
result := strsize(@ProgramName)
Serial.Str(0, string(13,13, "Program Version = "))
Serial.Str(0, @ProgramName + result - VERSION_SIZE)
PUB DisplayDMK 'use dispdmk to invoke...
Serial.Str(0, string(16, QUOTE, "CLS Issued.... ", QUOTE, "Hi Amara!")) ' <<<CLEAR SCREEN>>>>
Serial.Str(0, string(13, "RawTick ", QUOTE)) 'QUOTE = constant 34 for " QUOTE character..
Serial.Decl(0, RawTick,8,1)
' RawTick := ReadRawPressureHold
Serial.Str(0, String(13, "Line 132 Versuion below..", 13))
' DisplayVersion
Serial.Str(0, String(13,QUOTE, "Serial.Decl(0,clkfreq,8,1 =", QUOTE))
Serial.Decl(0,clkfreq,8,1)
Serial.Str(0, String(13, " coeff = 0.07 -> 1 sec "))
Serial.Decl(0, Coeff,8,8)
'Pause(1_000) 'HOW LONG IS THIS???It is 3 seconds in NORMAL time...
'waitcnt(80_000_000 + cnt)
Serial.Str(0, string(QUOTE, " ...1 Sec..", 13))
' Pause(1_000) 'HOW LONG IS THIS???It is 3 seconds in NORMAL time...
Serial.Str(0, string(13, "Smooth ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, Smooth,8,1)
Serial.Str(0, string(13, "LSmooth ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, LSmooth,8,1)
Serial.Str(0, string(13, "SpanVal ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, SpanVal,8,1)
ms := 1000
FitVal := clkfreq/1000*ms 'FitVal "10_000_000
Serial.Str(0, string(13, "FitVal ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, FitVal,8,1)
Serial.Str(0, string(13, "Out ZS Before ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, OutZS,8,1)
Scratch := F.Pow(2,2) 'How can I print out a number line 2.32984 or 0.00002938
Serial.Str(0, string(13, " Scratch ", QUOTE)) 'QUOTE = constant 34 for "
Serial.Decl(0, Scratch,8,1)
return
PUB FifthOrder(InVal)
ShowMe := InVal ' TEST.. Replace InVal with the iB..iaF
ShowMeF := F.FFloat(InVal)
FirstFit := (iA) ' the A constant adder
SecondFit := F.Fmul(iB,InVal) ' Should be B * X iB = 150429.0 >>OK!!
Scratch := F.Pow(InVal,2.0)
'ThirdFit := F.FMul( iC, Scratch) ' Should be C * X^2 iC := -0.13652 0.0186377104 -> -0.00254442 >>OK
' ThirdFit :=Tv.Str(FTS.FloatToString(F.FMul( iC, Scratch)))
Scratch := F.Pow(InVal,3.0)
FourthFit := F.FMul( iD, Scratch) ' Should be D * X^3 iD := 247.626 15,184,088.5274
Scratch := F.Pow(InVal,4.0)
FifthFit := F.FMul( iE, Scratch) ' Should be E * X^4 iE = -71.985 26,851,468.117
Scratch := F.Pow(InVal,5.0)
SixthFit := F.FMul( iaF, Scratch) ' Should be F * X^5 iaF := 7.264 22,224.5644
Scratch1 := F.Fadd(FirstFit,SecondFit) ' Smarter way?
Scratch2 := F.Fadd(Scratch1,ThirdFit) ' Should I use result like this?
Scratch3 := F.Fadd(Scratch2,FourthFit) ' Am I doing the right thing in indentation?
Scratch4 := F.Fadd(Scratch3,FifthFit)
Scratch5 := F.Fadd(Scratch4,SixthFit)
result := Scratch5 ' Need RESULT!
return ' Do I need Return?
PUB DisplayValues
Serial.Str(0,string(13, "Display Values for Fifth Order Fit..)"))
Serial.decl(0,RawTick,8,1)
Serial.Str(0,string(13, "Serial.decl(0,RawTick,8,1)"))
Serial.decL(0,Smooth,8,1)
Serial.Str(0, string(13, "Serial.decL(0,Smooth,8,1)"))
Serial.decl(0,FitVal,8,1)
Serial.Str(0, string(13, "Serial.decl(0,FitVal,8,1")) 'display Raw Value
Serial.decl(0,OutZS,8,1)
Serial.Str(0,string(13, "Serial.decl(0,OutZS,8,1) "))
Serial.decl(0,ThirdFit,8,1)
Serial.Str(0,string(13, "Serial.decl(0,ThirdFit,8,1) "))
Serial.decl(0,ShowMe,8,1)
Serial.Str(0,string(13, "Serial.decl(0,ShowMe,8,1) "))
return
PUB fahrenheit(t) 'Showing math works
' fahrenheit = (celsius * 1.8) + 32
return f.FAdd(f.FMul(t, 1.8), 32.0)
PUB Pause(xms) ' waitcnt(80_000_000 + cnt) = 1 sec FitVal "80_000_000
waitcnt(clkfreq/1000*ms+cnt) 'waitcnt(clkfreq/8000*ms+cnt) 80,000,000/1000 *1000
PUB GetParameter(parameterType) | characterCount, negativeFlag, tCommandChr
negativeFlag := 0
Serial.Str(0, string(13, "Please enter parameter for this command."))
case parameterType
ledon, ledoff:
Serial.Str(0, string(13, "Please enter parameter for individual puck control."))
Serial.Str(0, string(13, "Enter ID of puck to control."))
Serial.Str(0, string(13, "(", QUOTE, "1", QUOTE, " - ", QUOTE, "6", QUOTE, ")"))
Serial.Str(0, string(13, "Or enter ", QUOTE, "0", QUOTE))
Serial.Str(0, string(" to apply command to all pucks.", 13))
result := ReceiveNumber
result := 0 #> result <# 4 ' Led#PUCKS_IN_USE
setperiod:
Serial.Str(0, string(13, "Please enter Heartbeat blink time in milliseconds."))
Serial.Str(0, string(13, "Please enter a number between ", QUOTE))
Serial.Str(0, string( QUOTE, " and ", QUOTE))
Serial.Dec(0, MAX_PERIOD)
Serial.Str(0, string(QUOTE, ".", 13))
result := MIN_PERIOD #> result <# MAX_PERIOD
PUB DisplayParameterError(localCommand)
''if they type something illegal...
Serial.Str(0, string(13, "You entered ", QUOTE))
Serial.Str(0, @rawParameter)
Serial.Str(0, string(QUOTE, " which is not a valid parameter"))
Serial.Str(0, string(13, "for the command ", QUOTE))
Serial.Tx(0, QUOTE)
Serial.Str(0, string(13, "Terminating Command"))
Serial.Str(0, string(13, "Please enter new command."))
PUB FindCommandPtr(localCommand) : localPtr
'' Finds the command string associated with the
'' first four bytes having a value equal to
'' that of "localCommand". ie ron
localPtr := @ledon 'Start looking.. ledon first command.. Check lonng or bytes.. if the same
repeat
if byte[localPtr]
if long[localPtr] == localCommand
quit
else
localPtr++
else
localPtr++
while localPtr =< @setperiod ' the last in the DAT array..
if localPtr > @setperiod
localPtr := @cmdNotFound
PUB ReceiveNumber | localCharacter, characterCount, negativeFlag, rawCount
characterCount := 0
negativeFlag := 0
rawCount := 0
repeat while rxFlag == previousRxFlag
previousRxFlag++
repeat
localCharacter := Serial.rxcheck(0)
if localCharacter == -1
DisplayFlags("3") ' Used to aid in debugging. If this portion of the code
' is used, something is wrong.
return 0
elseif localCharacter == 13
quit
elseif localCharacter == "-"
negativeFlag := 1 ' a negative sign anywhere in string will set flag
KeyBdLine[characterCount++] := localCharacter
elseif localCharacter => "0" and localCharacter =< "9" ' extract and parameters values
result *= 10
result += localCharacter - "0"
rawParameter[rawCount++] := localCharacter
while localCharacter <> 13
if negativeFlag
-result
rawParameter[rawCount] := 0
PRI DisplayFlags(locationId)
'' Used for debugging...
'' I should have a debug boolean to turnt hese on and off...
Serial.Tx(0, $0D)
Serial.Tx(0, QUOTE)
Serial.Tx(0, locationId)
Serial.Str(0, string(QUOTE, " rxFlag = "))
DAT
'' The first four characters of each string needs to be unique.
'' Strings should be at least three characters long. If
'' a string is less than three characters add additional
'' zeros so each string has at least four bytes when
'' terminating zero are included in the count.
ledon long 'Because we need to use a CASE we need to create a long aligned string
byte "lon", 0 'Character strings in byte arrays.. use 1 char after another. Use 2 different types with same variable
ledoff long
byte "ledoff", 0 'the 0 is a terminating tring for the string.
cmdL long
byte "cmd", 0
help long
byte "help", 0
version long
byte "version", 0
setrawtick long
byte "setrawtick" , 0
dispdmk long
byte "dispdmk" , 0
setperiod long
byte "setperiod", 0
'' If commands are added before "redOn" or after "setperiod" the method "Cmd"
'' and the method "FindCommandPtr" will need to be modified.
'' Commands entered between "redOn" and "setperiod" will be included in the
'' list generated by "Cmd".
' ledon, ledoff, cmdL, help, version, dispdmk, setperiod
cmdNotFound byte "Command Not Found", 0
I watched your video. What stuck out to me is you mixed integers with floats. The example of two squared had "2" instead of "2.0". You either need a decimal point included with the constant (2.0) or use the float command (float(2)).
It really important not to mix integers and floating point numbers (if you want correct results).
Once I saw this common error I didn't keep looking.
There's a better floating point object called "F32". It looks like the OBEX does have the latest version.
Holler back if using "2.0" instead of "2" doesn't fix things.
I don't know if you're aware of a math coprocessor that does 64-math or not.
I haven't used the 64-bit version but the 32-bit coprocessor wasn't too hard to use. I know there's an object to make it easier to interface with the 64-bit version. If you're interested in it, I could help you find the object (if you have trouble finding it yourself).
I did try the 2.0 by golly... I think I hamburgured more up than just that.
I will work within whatever the 32 bit can do without the coprocessor. I remember having to use those for the old IBM PC when I had to do nasty hard math!
I think I will be able to figure it out and will post how to do it...
Not sure on the polynomial but working on it!
