Starting From Scratch learning the Fat Engine. A few questions. — Parallax Forums
T ChapT Chap Posts: 4,249
edited 2013-12-30 15:48 in Propeller 1
I have been going through the app notes on the Fat engine(S35390A_SD-MMC_FATEngine) all weekend and have just now made some progress being able to write and read data to the drive so that it is starting to make sense. There are few questions that I can't solve. I will also use this thread to post a schematic for a board design using the RTC and SD card(same idea as the Spinneret components). The new board will be dedicated to the RTC, SD card, SD wav playback with Line Outs + speaker outs to free up the main Prop board.
In the PST display below, no matter what gets written to the card, the Free and Used never changes. Does anyone see what would cause this to display values that are the same every time I append? In the app notes:
The default allocation unit for the FAT16/32 file system is the cluster, and files or folders span one or more clusters. This means a one-byte file takes up an entire cluster.
. I don't think a byte will take up an entire cluster, so maybe this is the confusion.
17309
Mo: 12
Dt: 29
Day: 7
Hr: 19
Min: 27
mountPartition:  0
Mounted(T/F)  -1
Open For Write:  TEXT2.TXT
ReadByte  01234567893123123123123123
List entries:  TEXT.TXT
List entries:  TEXT2.TXT
List entries:
List entries:
CloseFile:  0
Free:  7721192
Used:  8
UNmountPartition:  0
Below is the scratchpad of test code:
PUB Init  | aa, counter, buffer[128]
    pst.Start(115200)
    pst.Clear
    pst.str(string("Start PST"))
    pst.LineFeed
    pst.LineFeed
    pst.LineFeed
   'pst.dec(sd.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, -1, -1, {
   ' } I2C_DATA, I2C_CLOCK, -1))     'wrap long line to here
         'this returns a -1  for true = success
    StartFatWithLEDStatus
    dira[_statuspin]~~
    repeat 5
      outa[_statuspin]~~
      waitcnt(5_000_000 + cnt)
      outa[_statuspin]~
    waitcnt(1000000 + cnt)
    pst.dec(sd.readTime)    ' returns combined time  Initite the read before gettin the time
    pst.LineFeed
    pst.str(string("Mo: "))
    pst.dec(sd.getmonth)
    pst.LineFeed
    pst.str(string("Dt: "))
    pst.dec(sd.getDate)
    pst.LineFeed
    pst.str(string("Day: "))
    pst.dec(sd.getDay)
    pst.LineFeed
    pst.str(string("Hr: "))
    pst.dec(sd.getHour)
    pst.LineFeed
    pst.str(string("Min: "))
    pst.dec(sd.getMinute)
    pst.LineFeed
    'pst.dec(sd.formatPartition(0))
    'pst.LineFeed
    'repeat
    'pst.str(string("UNmountPartition:  "))
    'pst.dec(sd.unmountPartition)
    'pst.LineFeed
    pst.str(string("mountPartition:  "))    '0 - false   -1 = true
    pst.dec(sd.mountPartition(0))
    pst.LineFeed
    pst.str(string("Mounted(T/F)  "))
    pst.dec(sd.partitionMounted)    '0 - false   -1 = true
    pst.LineFeed    'partitionCardNotDetected
    'pst.str(string("CloseFile:  "))
    'pst.dec(sd.closefile)
    'pst.LineFeed
    'pst.str(string("Open For Write:  "))
    'pst.str(sd.openFile(string("text.txt"), "W")) ' Open text.txt for appending.
    'pst.LineFeed
    pst.str(sd.openFile(string("text2.txt"), "W")) ' Open text.txt for appending.
    pst.LineFeed
    'pst.str((sd.openFile(sd.newFile(string("text2.txt")), "W")))    '00000000
    'pst.LineFeed
    'pst.LineFeed
    sd.writeString(string("0123456789"))
    pst.LineFeed
    'pst.str(string("openFile:  "))
    'pst.str(sd.openFile(string("text.txt"), "R")) ' Open text.txt.    '00000000
    'pst.LineFeed
    'sd.writeString(string("0123456789"))
    'pst.LineFeed
    'pst.str(string("Readstring  "))
    sd.fileSeek(0)
    'sd.Readstring(@buffer, 512)
    pst.str(string("ReadByte  "))
    'pst.dec(sd.ReadByte)
    pst.str(@buffer)
    pst.LineFeed
    'pst.str(string("writeString:  "))
    'pst.dec(sd.writeString(string("Appended Data")  )   )      '00000000
    'pst.LineFeed
    'pst.str(string("FlushData:  "))
    'pst.dec(sd.flushData)
    'pst.LineFeed
    repeat 6
      pst.str(string("List entries:  "))
      pst.str(sd.listentries("/"))
      pst.LineFeed
    pst.LineFeed
    ''pst.str(sd.readString("text.txt"))  '??
    pst.LineFeed
    pst.str(string("Free:  "))
    pst.dec(sd.partitionFreeSectorCount("F"))
    pst.LineFeed
    pst.str(string("Used:  "))
    pst.dec(sd.partitionUsedSectorCount("F"))
    pst.LineFeed
    pst.LineFeed
    repeat
  • ElectrodudeElectrodude Posts: 1,680
    You're calling sd.partitionFreeSectorCount and sd.partitionUsedSectorCount in fast mode by passing it "F" instead of 0. Doing this just returns the old value instead of calculating the new, updated one. Try:
        pst.LineFeed
        pst.dec(sd.partitionFreeSectorCount(0))
        pst.LineFeed
        pst.dec(sd.partitionUsedSectorCount(0))
        pst.LineFeed
