Can't load an empty board type. ERROR with SimpleIDE
I am attempting to use the "SimpleIDE" with my new Propeller Education Kit. However, I am getting the following error when connecting my mac to my kit and running a test app. I am not sure how to proceed.
Error Message:
I noticed in the board type pulldown under project options there isn't anything there. It does not contain any options to select either. Another issue I am having is with the project properties; clicking the OK in this window doesn't do anything. The window just stays opened.
Any suggestions on how to proceed with these issues? Thanks.
Error Message:
Project Directory: /Users/smacri/Documents/SimpleIDE/My Projects/
propeller-elf-gcc -v GCC 4.6.1 (propellergcc_v1_0_0_2224)
propeller-elf-gcc -I . -L . -I /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Utility/libsimpletools -L /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Utility/libsimpletools/lmm/ -I /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Text Devices/libsimpletext -L /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Text Devices/libsimpletext/lmm/ -I /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Protocol/libsimplei2c -L /Users/smacri/Development/business/propeller/Learn/Simple Libraries/Protocol/libsimplei2c/lmm/ -o lmm/Welcome.elf -Os -mlmm -m32bit-doubles -fno-exceptions -std=c99 Welcome.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
propeller-load -s lmm/Welcome.elf
propeller-elf-objdump -h lmm/Welcome.elf
Done. Build Succeeded!
propeller-load -Dreset=dtr -I /opt/parallax/propeller-load/ -b ACTIVITYBOARD lmm/Welcome.elf -r -p /dev/cu.usbserial-A801ZSH0
error: no propeller chip on port '/dev/cu.usbserial-A801ZSH0'
Sorry you're having trouble.
Which instructions have you followed so far?
Which product are you trying to use? ActivityBot or other?
Thanks.
--Steve
If so you might want to start out the Prop Tool to minimize the unknowns.
DIP
Prop Tool does not run on Mac.
The Prop Tool won't work there.
Addendum: Oh, sorry, a Mac.
I ran the software installs here:
http://learn.parallax.com/propeller-c-set-simpleide/mac
If it's the PEKit, verify you have everything connected up through page 32 of the text. Ensure you have a fresh battery. The text I'm looking at is here: http://www.parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
A picture can be worth a lot. Maybe if you can upload one to the forum one of the many eyes here will see a problem. Use something you already know and post a link to a picture here or use the "Go Advanced" button to show the forum uploader.
Puppy Linux is probably the better choice for actually running Linux on a LiveCD only. The Linux Mint LiveCD is set up for merely a demonstration with the expectation that the user will install to hard disk for committed use.
http://parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
This happens to all of us, so remember that message indicates the Propeller is either not connected, OR not powered.
Congratulations.
