controlling motorized valves
I'm beginning a project that will employ a heat pump, a water pump and two motorized three-way valves, and it will require some sort of controller that will turn the heat pump (20 amp, 230 VAC), the water pump (5 amp, 230 VAC) and the motorized valves on and off in a timed sequence that depends on the call for heat from a thermostat. I'm about to purchase the motorized valves, and they can be operated by 110 or 230 VAC current or 5, 12 or 24 VDC. They have a feed back circuit that allows a controller to know which of the two positions they have is the current position, but the motor that drives the valve and the feed back circuit must be the same sort of current. Which of the above choices will make my life in designing and building the controlling circuitry the easiest? Any advice?
Michael Moreland
Mendocino, CA
Michael Moreland
Mendocino, CA
I.e. do you have to maintain power to the actuation motors continuously, or once activated will the valves keep their position after power is removed?
Duane J
After moving to the new position, the power is turned off, and the valve remains in that position until power is applied again. The power to move the valve is applied from an external source, but the action to shut off the power to the motor is done within the valve motor's circuitry. Michael
