Help with Wheel Speed Sensor design
I am working on a small project to create a dynamically adjustable wing for an automobile based on several data variables. The idea is to get the wing to reduce its angle of attack when the wing is not needed, and to dynamically adjust when it is needed. I've separated the project in to a couple phases, the first being a much simpler design which only looks at vehicle speed to actuate the wing.
I would like to derive the speed by reading in the period of rotation for one of the vehicle's wheels. I am using my old SumoBot BS2 board for this, as of now I think it is capable of handling the job, but I am not certain.
I've been researching how to do this and right now I am a little confused and I'd like to see if someone may be able to point me in the right direction.
Initially I came up with the idea to use a hall-effect sensor at the wheel to deliver a clock signal to a JK flip-flop. The toggling HIGH output duration from the flip-flop could be read in to the BS2 w/ PULSIN. From there I have a time for the period of wheel rotation and derive a speed. I'm having trouble with the following:
1. Finding a hall-effect sensor which simply sends pulses (maybe I need a coil instead of hall-effect?)
2. Figuring out if I need a low-pass filter or not.
3. PULSIN for the BS2 is only good for pulses < ~130ms, which may cause problems when vehicle at low speed.
4. Possible sampling rate problem.
What do you guys think?
If I were building this, I would either try out Hal Albach's Hall-Effect switch idea using 2 or more magnets attached
either to the drive shaft, or one of the wheels.
A year or so, I built a tach to monitor the speed of several motors in a robot project I was doing.
I used a 555 timer circuit to make a good square wave consistent pulse that fed my BS2 microcontroller.
my sensor was a PhotoDiode and my reflector was white duct tape.
When using two duct tape reflectors, I was able to read a motor shaft speed of 4200RPM consistently.
Just some food for thought
Garyg
Multiple ways to skin that poor cat!
