Free CAD software?
Hello All:
I have a Probotix CNC set-up.(All most...waiting for Christmas day to have the driver boards)
I have the software loaded and the simulate G-Code works great.
I've imported Diptrace Gerber files that run in the simulate mode.
I want to make a more simple G-Code to start out with.
I'm looking for a free CAD software.
Just a simple version.
It does reliable Gerber files. But I suspect that others will chime in and say it is so hard to learn and there are better packages now available. Since I did figure it out, I just keep using it.
Are you looking for CAD software to do other things besides circuit boards? Try LInux.... there are a lot of free CAD applications. And many also have a Windows version.
I want to run the CNC router from an RPi in the end. It's the learning curve with Python 3 that I'm working on. I need something that I can make some really simple g-codes with. Like a circle or a square. From this I will know exactly what the end result should be.
A forum friend of mine showed me how to parse out g-code with the Prop. I plan to reuse this method with a Prop.as a interface.
Thanks again and happy holidays
But by searching for applications in Linux, you will find excellent open-source free applications. And in many cases they have a free version in Windows as well. Even if they do not, you can use a LiveCD version of Linus to just run the application on Windows machine for your CAD work and then remove the CD and revert to normal Windows use.
IOW, I always start looking for new software in Linux to get an honest survey of the array of choices.
http://www.3ds.com/products-services/draftsight/
http://www.freecadweb.org/
http://www.emachineshop.com/machine-shop/Download/page100.html
The info is Great.
I guess you would need http://www.ncplot.com/ to use some of the programs I mentioned to produce the G Code. I have never actually had to do this so I'm not sure. Seems there's a way to get G Code from just about anything with some converter if the application doesn't support it.
I wasn't seeing any g-code from the cad-cam software you posted.
http://www.ncplot.com/ ...This might do what I need.
https://store.solidworks.com/veteran/default.php?command=Step1
Then you can get HSMXpress CAM for free.
http://www.hsmworks.com/hsmxpress/
I just saw free CAD and started typing... I usually wait a few days after writing a response to read the full original post. I would love to build a CNC, such a small bill of materials for almost endless possibilities. Seems like a better deal than any 3D printer.
.dfx to G Code, less complaints, hopefully worth a try. Wish I had something to offer from experience with this kind of thing it looks like a lot of fun.
have fun
