Intel Galileo board size compared to Propeller activity board on Bo bot chassis. — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2014-01-02 17:21 in General Discussion
It's just a little bit narrower by about 10 mm and longer by about 5 mm.
1024 x 765 - 129K
1024 x 765 - 126K
1024 x 765 - 127K
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-12-22 19:29
    So has anyone here used the Galileo yet? It looks quite promising.
    edited 2013-12-22 21:04
    http://www.intel.com/content/www/us/en/do-it-yourself/galileo-maker-quark-board/inspirational-video.html
    This video shows how only two Galileo are required to control each hifi wifi Bluetooth smartphone GPS i2c smt RGB LED PWM touch sensitive ambient lighting column.
    I better get on board quickly since incandescent bulbs are outlawed starting Jan 1. I had it made and didn't know it!
  • jdoleckijdolecki Posts: 726
    edited 2013-12-23 05:38
    Im more intrested in its ability to run Open CV. So I can run a camera on my bot.
    The board also has a pci-e slot on the bottom. So i ordered the 6235AN.HMWWB Centrino WiFi Card Advanced-N 6235 Dual Band Bluetooth, antenas and card adaptor.
    Im looking at the Parallax Propeller shields but they seem to be backordered? Im not sure if the Prop Shield has the same pin layout.(physical pin layout as the newer boards seem to have a different layout)
    So I got somemore thinking to do.
    The ASC board came today. Still have to figure what pins I will connect for comm power and I/O.
    I will get some Arduino shield header pins and solder them to the propeller shield so it can plug into the
    Galileo board once I figure out what pins to transfer over.
    Any ideas.?
    The Galileo board currently runs a modified version of the Arduino IDE to run sketches
    Additionally it can run and boot Linux from the SD card.
    While the Galileo has no video out if need the propeller can do that.
    My goal is to run open cv on the Galileo.
    They do seem to make a nice package together.
    1024 x 765 - 129K
    1024 x 765 - 127K
