Looking for an Ethernet to USB adapter
I am wanting to make a USB-only printer Ethernet-capable -- e.g. a simple print server. The USB/Ethernet adapters I'm finding seem to be for going from a host (with USB power) to Ethernet, and/or are very poorly rated. I need the other way around, not just in the gender of the USB connection, but also self-powered, etc.
Anyone have any ideas who sells one of these that isn't junk, but also doesn't cost a king's ransom?
http://www.amazon.com/s/?ie=UTF8&keywords=usb+ethernet+print+server&tag=googhydr-20&index=electronics&hvadid=18889882075&hvpos=1t2&hvexid=&hvnetw=g&hvrand=1789187661151374669&hvpone=&hvptwo=&hvqmt=e&hvdev=c&ref=pd_sl_5i0fqkjtc5_e
However, if it's just distance that's an issue, you might also consider a USB extender:
http://www.amazon.com/s/?ie=UTF8&keywords=usb+extender+over+cat5&tag=googhydr-20&index=aps&hvadid=35057397204&hvpos=1t3&hvexid=&hvnetw=g&hvrand=1072153763548977325&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_5itrovqac4_b
Anyway, if anyone has a specific recommendation that might save me from the same hassles these other poor souls seem to be having.
Marty
But it is a very different configuration than what Windows printer drivers normally want, a bit of ancient Hewlett/Packard magic with internet ports. And I suspect that is where the bad reviews come into play. The vast majority of people just can't quite grasp LAN ports and sockets or having to install a non-standard driver set up.
I guess what I am saying is that the hardware is good. It is just the installation that throws people for a loop. I suggest you take a look at a brand such as D-Link AND download the installation manual before you purchase. ;If you can follow the instructions, it can be done.
The only thing I suspect of being a snag is if you want to install one of those FAX/Printer combos. They tend to refuse to accept generic drivers.
The machine is but a few feet away from either PC that would use it, but I was hoping for a more seamless solution, to keep cables neat and tidy. I'm known for devolving into cable madness.
I do have a router with a USB slot, but current plans don't place the router in the same area as the cutter. So I'll probably end up just unplugging the cutter from one machine to the other if I need to switch things out, which may not be often. The cutter is only used a few times a week.
Now to search Amazon for a decent external battery charger for a Samsung Galaxy S...
That's the way I operate my Roland vinyl printer/cutter. It's connected to a parallel port on an old Gateway Win98 box, from which I share it over the local network. The cutting is just HPGL, but the printing is some proprietary Roland format.
http://www.amazon.com/s/?ie=UTF8&keywords=usb+switch+for+printer&tag=googhydr-20&index=aps&hvadid=34105899671&hvpos=1t2&hvexid=&hvnetw=g&hvrand=20510513461528544680&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_1cbg8fqz33_b
You need to get a Linux HOWTO document for install USB over LAN
Maybe here... http://usbip.sourceforge.net/ seek out the USP/iP Project
It is not that difficult. It is just very different to install. And the only hazard are those copier/fax/printer devices will NOT work as nobody but the original vendor knows how to write a driver for them. And so there are NO Linux drivers for these multi-function devices.
In general, if I cannot find what i want within SourceForge or the Linux docs, I go to both Ubuntu and Debian user groups to find known successful users. I don't use Red Hat or Fedora, so these communities are most helpful to me.
