Looking for a pump
Circuitsoft
I want to build a teapot with settable temperature and brew time. My idea is to have a tea-strainer above the pot, and a pump to pump water/infusion (40-80GpH) from the heated pot on the bottom into the tea strainer, but only for the duration specified in the brewing recipe.
The challenge is finding a pump that can tolerate water up to boiling temperature. Does anyone know where I could find such a thing?
- Alex
- Alex
its only 15gph but runs on 6v good to 212f
I beg to differ on the accuracy of the flow rate. Peristaltic pumps are used in hospitals because they have precise flow rates.
You can probably convert an inexpensive coffee maker hot plate to do that. The tube under the hot plate has a fixed volume, and each time the water gets hot enough to vaporize it forces that volume up into the filter basket. Count the number of times that happens to get the volume you want.
Erlend
https://www.sparkfun.com/search/products?term=pump
Tim
http://www.sciplus.com/
That looks about perfect. Thanks!
That's another fantastic idea. As mentioned above, though, I do want sub-boiling water, but your suggestion does allow for that. For flow rate, I just want to make sure I don't overflow the container I hold the tea leaves in. The challenge will be to find the thermoblock.
Maybe a hot glue gun from the dollar store? Take the heater out and wrap it around a small copper tube?
Erlend
