Ran into a great discussion involving assembly language, and want your thoughts. — Parallax Forums
potatoheadpotatohead Posts: 10,267
edited 2013-12-21 12:15 in General Discussion
The question was, "What 5 programming languages should every programmer know?"
Assembly language did not get in the mention, so I tossed it in there. Everyone was pretty good about the 5 need to include one scripting language, one core like C, etc...
The reasons for assembly that I gave were the usual things: ability to do low level tasks, understand what the higher level languages boil down to, etc...
Got the most interesting comment: Assembly language isn't a language, but more of a description language for a binary.
What do you guys say to that? I'm very curious to read your thoughts on the matter.
«13
  • LeonLeon Posts: 7,620
    edited 2013-12-17 07:20
    The term "machine code " is often used for the executable binary.
    edited 2013-12-17 07:23
    With very few exceptions, assembly language is indeed simply a notation for an instruction set (not necessarily binary). It's the instruction set that's important to learn, partly because it represents the underlying hardware, partly because the other languages often are intended specifically to isolate the programmer and the task at hand from the underlying hardware. Sometimes that's good and sometimes that's not good. That depends on the problem, the problem domain, and how well matched the hardware is to it.
    edited 2013-12-17 07:36
    Assembly being a language or not strikes me as semantics. It's still important to know at least one assembly language well to truly understanding how computers work. Two's compliment arithmetic, bit shifting, and bit testing are hidden in most high level languages, but are fundamental to how conditional branching and looping works. It's also probably worth hand assembling one program just to really get a feel for hex and two's compliment.
    Kids these days. Back in the old days we had to key our programs directly into a microprocessor via a hex pad, and read the output on seven segment displays! But we liked it, we liked it just fine.
    edited 2013-12-17 08:27
    "Assembly language" isn't a language, but a class of languages that includes 8x86 assembly, PASM, etc. In the same way "natural language" isn't a language, but a class of languages that includes English, French, Mandarin, etc.
  • bill190bill190 Posts: 769
    There are those who understand hardware and those who do not!
    Those who do not understand hardware are probably best to stay away from assembly language.
    But if you need to have full access and control of the hardware - everything, nothing better than assembly language. Note that higher level languages sometimes do not allow the full implementation of the hardware's capabilities or don't do things right. A common "brain damaged" set of higher level instructions is with serial communications for example. Do it yourself with assembly language and you can get it right or do what you want.
    edited 2013-12-17 09:00
    potatohead,
    What is a "language"?
    That is one of those eternal and pointless debates in computing and elsewhere. Clearly assembler programs are using abstract symbols to represent something and there are rules about what valid symbols are and what sequences they can be arranged in. Such arrangements of symbols can be used to convey meaning from one programmer to another as well as being used to program a machine. Sounds like a language to me.
    Programmers are kind of snotty about this idea that a programmer should know this or that many different languages. I'm coming to the conclusion that its a silly proposition. I have had to learn many languages over the years, for a long while it looked like every new project I did would require learning a new language. Mostly it was a big waste of time and my mental capacity (which is in short supply) because they were mostly the same idea, only the details differed. For example: Algol, Ada, PL/M. Coral 66, Pascal, C are all the same stuff. Things start to look up with C++, Java, C# and such that offer object oriented programming. Then we have the wonderful world of languages like JavaScript with it's first class functions, closures, prototypical inheritance. In many ways a more advanced language that the C++/Java group at least it includes some concepts that are very different.
    All in all a programmer should not have to be learning loads of languages. They should be able to master one and use their energies solving problems in their problem domain with it. They should not have to be language experts but experts in their chosen domain.
    One of the happiest programmers I ever met only ever new one language, COBOL. What on earth would she want to care about how the machine works, or two's comp arithmetic or bit shifting etc.
    Martin_H,
    You were lucky. When I were a lad we used to dream of hex pads and seven segment displays. We had to program by welding diodes to circuit boards. Tell kids that today and they just won't believe you.
    http://www.cca.org/blog/20120222-Diode-Matrix.shtml
    P.S. Such diode matrix boards are still in use to define the conflict matrices in traffic light controllers around the world.
  • trookstrooks Posts: 228
    edited 2013-12-17 09:09
    The question as posed is way too comprehensive of 'programming' as it has become. - I started my career with a trade school education in electronics. - The first language I used was 'Basic' because I was doing the first testing of newly refurbished systems as they were released from manufacturing. - The 'core' processor of these systems was 256 bytes and was formed using diode arrays. - These systems were built using vacuum tubes. 'Basic' at that time was the actual binary code that ran the 'processing'. - What most people call 'Basic' these days is actually BAL or 'Basic Assembly Language'. - BAL was one of the programs I learned when I got a technical certificate in programming to advance with the company I was working for at the time. - These days once you know an 'application' well enough to string together macros to do work with that application you become a programmer. - All this having been said, Basic is still the most useful language for dedicated nuts-and-bolts builders of 'gee whiz golly' new and unusual electro-mechanical contraptions. - Of course all this is IMNSHO<G>. - - tim rooks
    edited 2013-12-17 09:23
    @Heater, Martin:
    Yes!
    potatohead,
    Absolutely. That was the interesting part of it. I never thought of assembly as a description of a binary, but I do agree with that in that is precisely what happens on a good assembler. Heck, on the Apple, an assembler can be used to author a disk image directly bootable on the machine. One nice bit stream containing what is needed to read the disk and run "the program", which kind of blurs things somewhat. A disk can simply contain a program, no DOS, etc... and the developer can do whatever they want to with that diskette... Of course, one can boot the standard stuff, run an assembler and produce just a binary to be placed into the filesystem on the disk too.
    @Martin, you said about what I did.
    About that happy COBOL programmer... yeah, exactly. She's got her problem domain, appropriate skills and that mastery makes the work enjoyable, productive, etc... no worries at all.
    Now this:
    Is worth some discussion. Chip and I were having a discussion about SPIN some time back. The root of that discussion was C of course, and all the dialog surrounding whether or not it makes sense to use, is necessary, etc...
    Now I'm not taking a position on that, better or worse, other than to say C has a level of interest sufficient to warrant getting good tools bootstrapped onto Propeller chips. We've got it, and it's improving, great!
    Chip said the most interesting thing: "Why not simply use the optimized tools?" Those are the best ones anyway, and bending things into tools that one knows can make sense, but not always. Of course, SPIN + PASM on this chip is brilliant. It takes similar amounts of learning to figure out how to best express C for a Prop as it does to express it in SPIN + PASM.
    So then, this becomes a discussion of intent, which is nearly always missing from the question, but often supplied in the answers.
    Re: Understanding hardware and assembly language.
    Well, maybe. For things like drivers and such, sure! I think it makes sense to couple both domains and understand the hardware and the CPU. However, there are lots of places where assembly can do great things without getting too much into the hardware. Depends on the problem domain and where hardware may intersect that IMHO.
    And Mike mentioned the instruction set is really the target... Yeah. agreed.
    Honestly, one thing not mentioned yet is the nature of the abstractions. Translating higher order tasks to assembly language is a special skill. When I see people able to really do that, I'm amazed at how many abstractions they can work with at one time. However, even at a basic level, the special insight I think is most important is to realize computers really just process information. What that information means is up to those using the computer and factoring that meaning down to structures, etc... that the computer is particularly adept at handling is at the core of what computing really is, IMHO of course.
    Great thoughts guys. Appreciated. Please feel free to continue to riff on the thread. I just thought I would like this discussion and hoped a few of you would too.
  • Too_Many_ToolsToo_Many_Tools Posts: 765
    edited 2013-12-17 09:24
    bill190 wrote: »
    If you want to know hardware, you use machine code.
    Anything else is a language that insulates the user from the hardware.
    FWIW..anyone who suggests assembly language as the primary software approach to accomplishing a task has no business doing a software project since it will adversely affect scheduling and maintainance of the project.
    edited 2013-12-17 09:33
    Again, this depends on the project.
    Is the project firmware of some sort? What resources is it operating on? Scope of functionality? Etc...
    I don't disagree with you in general principle, but there are plenty of cases where well commented, documented assembly language makes perfect sense.
    A computer BIOS would be one case that's super easy to identify. Those embedded controls on your microwave may be another extreme the other direction.
  • jazzedjazzed Posts: 11,803
    edited 2013-12-17 09:42
    Using assembly language is a matter of choice. Knowing one assembly language (usually x86) is important in school.
    Other than that, most software engineers I know only look at assembly language when it's required. It's ok to have a passion for it, but such a passion is definitely not required.
    To think that everyone should be excited about assembly is a total disconnect with the rest of the programming universe.
    edited 2013-12-17 09:54
    potatohead wrote: »
    I disagree.
    Assembly language makes projects a nightmare for making timely schedule deadlines and future project maintainance.
    I have seen countless programs suffer because assembly language was used to make up for poor hardware design selections.
    Many times hardware is underpowered and the assembly language is used to patch over the poor system choices.
    It can also be "I know assembly language" so why would I want to use a language that I have to learn.
    It is the same human condition where you find hardware types who would rather built the project out of all hardware instead of a more suitable hardware/software combo...when you have a hammer every problem looks like a nail mentality.
    In the realm of microcontrollers, we see the overuse of assembly language because of the underpowered hardware platforms selected being overtasked and use of a higher level language requires resources the project is unwilling to commit.
    Many times the "cost" of a project is calculated by its hardware component alone..with no thought given to the larger overall cost to using inadequate software.
    edited 2013-12-17 09:58
    jazzed wrote: »
    Well said.
    It has been said tongue in cheek that those who advocate extensive use of assembly language suffer from the computer science equivalent of OCD similar to the TV detective Monk focus on detail.
    Lots of embedded 6502 code out there with developers who disagree.
    Now I agree with you in terms of something like a BIOS. Newer ones may well be developed with an HDL. The PC ones were always annoying to me coming from something nice like ARC (SGI)
    I would not agree for something small in scope, such as that microwave.
    edited 2013-12-17 10:05
    potatohead wrote: »
    You probably know a lot more 6502 code developers than I do :)
    You're one of the only two 6502 programmer enthusiasts I've met in person.
    I don't have enough fingers, toes, etc... to count the number of other programmers I've met :)
    edited 2013-12-17 10:06
    potatohead wrote: »
    There is lots of embedded code out there...just because assembly language was the ONLY choice long ago does not make it a realistic choice now.
    Any analysis of a project's lifetime cost shows that software maintainance is THE major cost.
    Many product lines are scrapped because the software cannot be maintained...the developers have left the building.
    edited 2013-12-17 11:15
    Well someone had better learn machine architecture and assembler. Otherwise we are not going to have any high level language compilers :)
    edited 2013-12-17 12:15
    Heater. wrote: »
    Agreed.
    Knowledge of the hardware is essential.
    But that does not make assembly the first choice for any serious product.
    Making the product delivery deadline and subsequent product maintainance are the big cost factors in a program. Anything that affects them...hardware or software...are the ecomonic lynch pins of the development.
    I have been on programs where the engineering staff want only hardware..no software..and not surprisely none of the engineers knew how to code...so surprise, surprise...they recommended what they knew and were comfortable with.
    While on others they wanted software...software that had no possible platform to ever run on...so it was just two sides of the same problem..the designers could not design or innovate.
    One of the big problems is that engineering does not accurately estimate the cost of software, when it is needed or not.
    edited 2013-12-17 12:37
    and
    Fit the subject well. Yes, I don't think many programmers get excited about assembler. But, if they have some desire to understand the voodoo behind the code they write, they may well find the experience worth their time.
    I did say it's entirely appropriate for a software project given good alignment on requirements, etc... That has little to do with historical things.
    BTW: 6502 code is out there today. Many use C, and that's practical on the 10-14-20Mhz chips out there today. Many use assembly language too. Chances are you have one somewhere nearby. They do lots of little, highly specific things today. Think components and sub-systems with well defined control and performance requirements.
    There are more of us than you think. But, not as many as I would like. :) I find it worth it to remember my roots and stay fairly well grounded as far as overall expectations go. Case in point, SPIN = slow. Well? Relative to a COG, yeah. Relative to many tasks? Absolutely not.
    So far, the thread equates to assembly not being one of the core things people need to know. Not sure I disagree.
    If somebody asked me this and they were programming now, I would qualify it. For somebody starting out on this stuff in general? Absolutely they should know. Way too many basic, core skills linked to assembly language not to. And it's not like they need to reach mastery to gain the benefit either.
    Re: Excited about assembly language.
    Well, I love it personally. Love a lot of things. But, I really only like it in smaller contexts. I've no interest at all in assembly for an X86 PC or system on a board, etc... On this chip? Assembly is a freaking playground. Lots of fun. Will be on the next one too. It really depends.
    edited 2013-12-17 14:00
    potatohead wrote: »
    and
    Well said.
    A language is just a tool...so one uses the right tool for the right job.
    I personally like strongly typed languages like Pascal...let the complier do the busy work.
    Meanwhile I have seen lots of trash design written in C which costs a company a support nightmare.
    My opinion of C has been borne out by the subsequent versions (C++, Csharp,etc.) where typing is tightened up.
    One of observation I have seen is that good programmers want strong compliers that type strongly...it frees them up for working the design, not the problems.
    edited 2013-12-17 14:54
    I think that whether or not assembly is appropriate depends upon the hardware resources available in the target machine. As an example, I've done several projects using the the Atmel ATTiny-13. Even with assembly code, the onboard flash got filled to within a few bytes of the end. Fat chance that with Atmel's C compiler I could have completed the project at all.
    'Same applies to the Propeller. For tight video timing loops and real-time signal processing, PASM is the only way to go.
    OTOH, if you're programming a PC, there probably isn't a need for most programmers to know x86 assembly. (Still, though, there's the Spin compiler which Chip wrote in assembly for the PropTool, and it's damn fast! 'Haven't compared compilation speed with Roy's OpenSpin compiler, however.)
    edited 2013-12-17 15:52
    Too_Many_Tools,
    This may be your observation but it's almost certainly not true in general.
    It's also a bit of a put down to all those really good programmers who use weakly of dynamically typed languages. Many gurus of Lisp, Scheme even Forth could give you a lecture on that.
    I also observe that Ada, a very strongly typed language, has been resoundingly rejected by pretty much the entire programming community.
    potatohead
    Optimized tools? Yes. The question then is what are wanting to optimize for: execution, speed, size, programmer productivity, maximal cross platform support, correctness/security, profit, etc?
  • rod1963rod1963 Posts: 752
    edited 2013-12-17 17:23
    Does inside the box still matter(to borrow a phrase from Steve Ciarcia), that should be the question.
    For most coders the answer would be no.
    It's just a black box that you code on.
    Inside the box only matters to designers, bit bangers and hackers who want to know what goes on. Your average code monkey doesn't need to know if the box is a PPC or x86 or one of the Apple hygene products.
    Micro-controllers seem to be the only hold out. Even coding on the Arduino you still have to know something about hardware to interface to the various boards.
    Assembly? It really depends if you're writing a BIOS, writing virtual peripherals on the Prop, start-up/initialiation code, run-times for compilers. Or simply the joy of it. I like writing assembly on Z-80's and 68k/ColdFire. I wouldn't touch it on a x86, ARM or MIPS.
    Programming Languages? They are really personal preference thing for non-professionals. I personally like Free Pascal, Oberon and BASIC. Mbed's online C++ compiler for ARM's micros is quite nice for hobbyists like myself.
  • RossHRossH Posts: 5,713
    edited 2013-12-17 17:46
    Ada was not rejected by the programming community. It was rejected by the defense companies who saw it would dramatically reduce their profits. And they were quite right.
    edited 2013-12-18 03:49
    RossH,
    Hmm...OK we are going to have to define what this "programming community" might mean.
    Of course there are many programming communities...
    During Ada's brief period of fame the defence industry was a substantial part of the programming population. There were a lot less computers and a lot less programmers then.
    Then there is the Windows world. No take up there. How come Windows is not written on Ada, or any of the millions of Windows applications?
    Then there is the Apple world...same story.
    Then the huge and sprawling conurbations of the Free and Open Source software world. How come Richard Stallman created a C compiler not an Ada compiler? How come Linus did not write the Linux kernel in Ada? What about all the thousands of programs that support the Linux/Unix infrastructure. No take up there either.
    Is there even one program in common use that is written in Ada?
    This all looks like a major rejection from all quarters of the "community".
    So Ada is now confined to a small pockets of resistance hiding away in gehttos in places where normal people don't dare to go. It's still in use in an ever decreasing number of industries where it is perceived as offering the possibility of more robust and reliable software. Which is of course an illusion.
    edited 2013-12-18 04:36
    Don't be obtuse, Heater.
    Ada could not be rejected from all quarters of the community because 95% of the programming community never knew much more about it than the name. Still don't, obviously.
    Ada was a specific language for a specific purpose, and was very popular in the community for which it was intended. Of which I was a part at the time.
    Nobody in their right minds would attempt to write a graphical operating system in Ada. Or a mobile phone app. Or a web site. Or a microwave oven controller.
    But if you wanted a nuclear missile launch system, or a radar tracking system, or an air traffic control system, or a spacecraft navigation system, or a submarine combat system, then Ada could not be beat.
    It was reliable, portable, and cheap - yes cheap. Sure, the compilers cost a lot initially, but the prices soon came down to where you could buy a fully validated compiler for the PC for a few hundred dollars - much less than you now pay for Micro$oft rubbish. And debugging and maintenance costs were massively reduced. And did you get that "validated" bit? That meant that code written for one compiler was guaranteed to run on any other - even if that compiler was written by a different company, and intended to run on different hardware. Unix, Windows, DOS, IBM Mainframe, various supercomputers, embedded chipsets, etc etc. No learning curve for programmers moving companies or hardware platforms.
    Hardware manufacturers hated it. They could no longer sell you their "proprietary" languages written for their "proprietary" hardware. Whole projects could be migrated from IBM to VAX to PC by a simple recompile. And often were, if it proved that the hardware was not up to the task, or better and cheaper hardware came along.
    Software manufacturers hated it. They could no longer count on lucrative "maintenance" contracts for software that was deliberately written in obscure languages so that no-one other than the original company could ever maintain or modify it.
    Training companies hated it. The entire Ada LRM was smaller than your average "Dummies Guide to <insert your favorite dingbat language here>" book - and about a 10th the size of the equivalent documentation set required to learn to use C++ or Java effectively.
    But many software engineers loved it - not least because having once learned it, their skills were applicable to just about every company in the industry. They could move at will anywhere they liked and be productive the day they arrived.
    And so Ada had to go.
    Ross.
    edited 2013-12-18 06:13
    I remember back in 1990, when I was learning Programming.
    We used Digital VAX machines running VMS and VT220 terminals, mostly.
    (There was a few other machines, one of which allowed us to copy files from a PC-formatted 3.5" to the VAX)
    The hall was always crowded...
    Then a set of disks appeared With a PC/DOS Version of an ADA Compiler...
    And suddenly the hall was half-empty.
    There was as far as I know, ONE difference between the VAX and DOS Version Compilers.
    The VAX Version didn't have a 'long integer'. This we solved by adding a single line of code that we commented away when compiling on a PC.
    Those were the times...
    I think I still have a copy of those bootleg disks somewhere...
    edited 2013-12-18 06:16
    I've never even seen an Ada compiler to reject it. I haven't even written "hello world" in Ada. Ada might be the perfect programming language and I'd never know it.
    The problem with computer languages is that they depend greatly on network effects. The C and C++ languages are not great and the anti-C/C++ camp have good arguments that I agree with. For example:
    Why can't the compiler emit the header file?
    Why am I constantly typing '!', '', '{', '}', '(', or ')'? This language is impossible to touch type because of an over reliance on characters accessed via the little fingers.
    There are syntax landmines like the assignment within a conditional (e.g. "if (foo = bar)" instead of "if (foo == bar)") which create hard to find bugs.
    The unchecked arrays may be fast, but enable buffer overflows which are the cause of many security flaws.
    I flat out hated the language for a year, but eventually gave in. So why did C/C++ become so influential? The answer's simple, Unix was written in C, Unix included a C compiler, and Unix was the OS of choice in most C departments. So any company in the 80's looking to start a new software development had a pool of talent that knew C, while no one knew Ada.
    tl;dr no one got fired for choosing C.
  • AleAle Posts: 2,363
    edited 2013-12-18 09:21
    What I find a bit ironic is that some advantages of Ada are needed but not available in C. The MISRA (rules) try to force programmers to sort of "behave" (strong types, for instance)... but that is a post write problem!. Instead of modifying the language (and the compilers!), something beneficial, third-party tools have to be used to make the code "conform". The rules at least shouldn't be contradictory....
    The new languages are flow-diagrams and graphical representations of state-machines... sad... (Rhapsody, I'm looking at you)
    edited 2013-12-18 10:27
    Your examples demonstrate what I am saying..assembly is needed and used when either inadequately hardware platforms are used or the project is cutting edge using hardware that is trying to accomplish the "impossible"...all at the expense of project schedule, project cost and future software maintainance.
    FWIW..hardware is a small cost of a total project expenditure...software development and maintainance is much larger. Now whether a company adequately judges those costs is another matter.
    One case I have seen repeatily is if a company favors (for a number of political reasons) a specific processor (i.e. Parallax mandating Propeller) there by forcing software to be Propeller specific...and thereby forcing "10 pounds of software into a 5 pounds of hardware"...and the subsequent need for assembly language. I have seen that business decision kill companies as they miss new project deadlines and not fix program bugs.
    Again I have nothing against assembly language..it is just rarely the right choice for today's projects.
