Can i combine nrf24l01 with eddie control board ?
i want to use NRF24L01( RF) to control eddie robot control board by personal NB.
Does it gonna Compatibility NRF24L01 with eddie robot control board?
Eddie Control Board : http://www.parallax.com/product/28993
Which experts can help me?
One problem with using the nRF24L01+ is the device requires a lot of I/O pins to communicate with it. My driver requires six of the Propeller I/O pins. I'm pretty sure the interrupt line isn't necessary since incoming messages could be detected by polling the module. If the software were altered, the number of pins needed could probably be reduced to five.
It should be possible to share the clock, MISO and MOSI pins with other SPI devices. My driver doesn't release these pins automatically but I'm pretty sure I included a method which will instruct the PASM cog to release the I/O pins (set them as inputs and low). I'm not sure if I've tested this feature of not.
I'm not aware of anyone having used these modules with the Eddie Control Board. Merging the Nordic (nRF24L01+) modules with the standard Eddie software shouldn't be too hard but I also doubt it's a trivial task.
