Propeller Project Board Pinouts
On the Propeller Project board I am trying to learn which Propeller pins are connected to the data pins on the 3.3 VDC header (section 16 in documentation) and the VIN header. I haven’t been able to find it in the docs or schematics or by looking at the pictures in the docs. On the old Proto Boards the 3-pin headers section had a fourth row with a trace to the data pin. Does anyone know where I can find this information or where it is in the docs.. If there isn't a direct connection to Propeller pins through traces (as it appears in the pictures I've looked at on the website and in the docs) then how are you to connect the data pins from the header sections to the Propeller pins?
Tony
Tony
