CAD (eagle) files for single sided DIP board?
Hey All,
I was hoping that someone might have a simple DIP prop board, single sided, for a CAD like Eagle. I make my own boards and am hoping not to have to re-invent the wheel/ I looked around and found some ExpressPCB double sided files, but that was all.
Thanks!
Jonathan
Thanks!
Jonathan
http://www.leonheller.com/Propeller/
It was designed with Pulsonix, but you don't need it if you are just going to make your own board.
Thanks! That looks like a good place to start. I've been reading Chip's article on layout etc. too.
Jonathan
Here is a single sided design I was working on a while back. It has not been tested.
http://forums.parallax.com/showthread.php/143892-Great-Weekend-Project-For-The-Propeller-DIP-Plus-Kit?p=1143722&viewfull=1#post1143722
Jonathan
This allows the chip to be above the smd resisters and caps on same side of board.
prop board 10 headers only.zip
Jonathan
is two layered (two planes of traces).
I call your description a single sided assembly.
