Alkaline vs. Rechargeable Batteries
I am considering a switch from a 4-battery alkaline pack to a 5-battery rechargeable pack for powering the Boe-Bots for my classes of high school students. I notice that the brownout level is reached when my 5-battery rechargeable pack drops to about 6.3 v but the Boe-Bot is still running when the 4-battery alkaline voltage has dropped to 5.8 v. Sorry if this is an elementary question, but why is the brownout level different for rechargeables and alkalines?
Thank you,
Susan Jenny
Thank you,
Susan Jenny
We'll receive some qualified replies on this issue aside from mine, as I'm only speculating because I've never seen this exact question before but found it interesting. I'm wondering if the rechargeable batteries are unable to source the current at 6.3V, as if they're on the steeper side of their discharge curve. If this is the case, maybe you could experience a brownout reset with a higher voltage.
By the way, have you ever seen the Boe-Bot Lithium Ion Power Pack? At $50 it's sorta expensive but it'll have many other benefits to your class. The storage capacity of these two 18650 Li-on batteries is significant, so you'll be able to get through many more sessions without recharging. http://www.parallax.com/product/28988
Let's wait for some others to chime in.
Also, are you using a BOE-Boost (30078) with the rechargeables?
Please be careful with battery chargers! I would recommend having two sets of batteries and charge them only when you're in the classroom. IOW, don't leave batteries to charge overnight. And don't scrimp when it comes to purchasing a battery charger. I say this because I used a cheap charger from RadioShack once that melted, smoked, and nearly caught fire while charging some NiMH AA's. Had I not been there to catch it, the collateral damage could have been extensive.
I currently use an Ansmann charger, but I've heard that chargers from Maha are also good.
In my case it was powering headset mic belt packs. Even though each pack would have it' batteries replaced before each performance som batteries were failing during the performance.
On the upside, the supplier was more than happy to replace/refund any batteries that had underperformed and for the season this was some 20+ batteries out of approx. 300.
http://www.ebay.com/itm/AC-US-Plug-Wired-Dual-Charger-for-18650-3-7v-Li-ion-Rechargeable-Battery-Cell-/310739121220?pt=Battery_Chargers&hash=item48597eb444#ht_4477wt_1366
http://www.ebay.com/itm/Black-Plastic-Battery-Storage-Case-Box-Holder-for-2-x-18650-with-6-Wire-Leads-/300836544851?pt=LH_DefaultDomain_0&hash=item460b416153
http://www.ebay.com/itm/UltraFire-18650-3-7v-3000mAh-Protected-Rechargeable-Battery-for-Flashlight-HE-/141081173579?pt=US_Rechargeable_Batteries&hash=item20d917de4b#ht_2334wt_1366
US seller. 4 cells: http://www.ebay.com/itm/4x-Ultrafire-18650-3-7v-4000mah-Rechargeable-Flashlight-Li-ion-Battery-fast-ship-/151176971883?pt=US_Rechargeable_Batteries&hash=item2332d9866b#ht_1082wt_1108
Don't believe any claims of 3000-4000 mAH. Expect 800-1000 mAH.
Thanks again.
Everyone has pretty much covered the salient points.
A. The brown out point is the same, regardless of what you think your are getting as different results
B. The rechargible batteries tend to have much flatter curves with steeper tails at each end.
I would go with the 5 cell holder as you will recapture your expenses from the change-over more quickly than buying lithium cell systems. Plus, you can use a variety of rechargeable cells. You can buy NiCd or NiMH or whatever is on sale at any given time. You have a lot more leeway in economizing on your future battery purchases.
Why are you getting different readings for these?
It might be your procedure, or it might be that the rechargable cells 'bounce back' quickly from a deep discharge. Just about any battery will 'bounce back' from a low discharge.. but they all do so at different rates. The alkaline might just not bounce as quickly or as much.
The Lithium cells are a much nicer system. Parallax has a holder with built in charger, so cells do not have to be removed. You don't have to buy a separate charger, and the Lithium cells do indeed recharge must faster. You can possibly recharge between lessons that are scheduled for the same day. The NiCd and NiMH tend to require an overnight charge. You end up with buying more cells and having boxes of extras. Some one constantly has to sort out which are good, which need recharge, and which are defective trash.
mechanical contact between a spring and a rivet - the result is a much larger contact resistance than the
internal resistance of most batteries.
I guess this means check that the voltage at the battery matches that at the holder terminals when under
load.
I've been caught out by this before - I will not trust battery bolders unless soldered or welded contacts
are used throughout.
