Compiling rewritten Tachyon Forth kernel on C vs Spin? — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2015-07-11 23:15 in Propeller 1
As you know the very kernel of Tachyon Forth is initially compiled through the Spin compiler and I use BST because it generates a listing that I can use to make sure things are where they need to be and compiled as I expect them to be. But Spin is not very friendly towards compiling kernels of this nature and what I really wanted was just a macroassembler.. But I notice these C compilers, perhaps even Catalina (which I'm playing with) and I got to wondering if it might be better to rewrite the kernel so that it could compile in one of these and perhaps also craft some hooks to access library functions etc. I would still have the cog kernel functions written in PASM though as they need to be super-optimized.
Would any of you C gurus be able to comment on the feasibility of this approach?
  • jmgjmg Posts: 15,183
    edited 2013-12-10 19:56
    ... and what I really wanted was just a macroassembler..
    The Assembler part of GCC is a macro Assembler...,
    http://203.64.187.42/99-B/GAS-MACRO/GAS-Macro-Note.htm
    and GCC can create small code pieces, as COG native. (ie PASM)
    That should also move to P2 with relative ease.
  • ersmithersmith Posts: 6,089
    edited 2013-12-11 05:00
    Converting code from Spin to C is usually not too difficult -- the languages are quite similar. In fact there's an automated tool (spin2cpp) that can do much of the work for you.
    You should certainly see a performance improvement in the non-PASM portions of your code. The tradeoff is that C code usually takes more space. There's a continuum of performance/size tradeoffs available; Spin is the smallest, slowest code, CMM (compressed memory model) C gives more performance with bigger code, and LMM C gives the fastest performance but with the biggest code. (CMM is implemented with a byte-code interpreter, LMM loads individual PASM instructions into COG memory and executes them one at a time. PropGCC also supports loading small loops and functions into COG memory and executing them as a whole, which the compiler can do automatically.)
    I think PropGCC would be a good choice for implementing Tachyon Forth, since they both share an emphasis on high performance. I am biased though :-).
    As jmg mentioned, a macro assembler comes with PropGCC. The syntax is slightly different from PASM -- the most recent PropGCC version has a .pasm directive that makes GAS much more PASM compatible, so you may want to get that if you're doing a lot of PASM programming in GAS.
    edited 2013-12-11 06:57
    Peter,
    Are suggesting a utility that would compile Forth code into Spin DAT code? It would take something like this
    : here dp @ ;
    : allot dp @ + dp ! ;
    : , here ! 4 allot ;
    and compile it into this.
                  ' : here dp @ ;
    here_L        word      @cmove_L+Q
                  byte      FLAG_DEF, 4, "here"
                  long
    here_X        word      execlistfunc, 0
                  word      @dp_X+Q, @fetch_X+Q, 0
                  long
                  ' : allot dp @ + dp ! ;
    allot_L       word      @here_L+Q
                  byte      FLAG_DEF, 5, "allot"
                  long
    allot_X       word      execlistfunc, 0
                  word      @dp_X+Q, @fetch_X+Q, @plus_X+Q, @dp_X+Q, @store_X+Q, 0
                  long
                  ' : , here ! 4 allot ;
    comma_L       word      @allot_L+Q
                  byte      FLAG_DEF, 1, ","
                  long
    comma_X       word      execlistfunc, 0
                  word      @here_X+Q, @store_X+Q, @_lit_X+Q, 4, @allot_X+Q, 0
                  long
    That should be fairly easy to write. I've thought about doing that for pfth. It would need to know the dictionary format and the alignment requirements. pfth uses the convention that the label for the starting address has an "_L" suffix, and the label for the XT uses an "_X" suffix. "Q" is the object offset, which is 16 for the top object. I think Tachyon uses "s" for the offset.
    There would need to be a way to define an alias for words like "," and "@", where "comma" and "fetch" would be used instead.
    Dave
    edited 2013-12-11 07:29
    I just realized it might be better for the utility to generate hex data. It would need to know the starting address, but it wouldn't need to generate aliases. From my previous example the generated code would look like this.
    ' : here dp @ ;
      byte $28, $0f, $80, $04, $68, $65, $72, $65, $0b, $00, $00, $00, $ac, $0d
      byte $88, $0c, $00, $00, $00, $00
      byte $3c, $0f, $80, $05, $61, $6c, $6c, $6f, $74, $00, $00, $00, $0b, $00
      byte $00, $00, $ac, $0d, $88, $0c, $c4, $0c, $ac, $0d, $7c, $0c, $00, $00
      byte $50, $0f, $80, $01, $2c, $00, $00, $00, $0b, $00, $00, $00, $44, $0f
      byte $7c, $0c, $54, $0c, $04, $00, $5c, $0f, $00, $00
    edited 2013-12-11 18:33
    I don't need Spin converters as no Spin cogs are used at runtime, it's only a few lines of init code that happens to be written in Spin. All of the code is either written in PASM or as DAT blocks mostly with "byte" directives. That is why a macroassembler would be fine but C might have an advantage and certainly if there were a way for libraries to be compiled. So the language that is used to compile the kernel is not that important, it is a tool to compile an application which in this case the application is also a resident interactive language that can compile further applications.
    EDIT: that's why I wrote on C vs Spin rather than in C vs Spin
  • MJBMJB Posts: 1,235
    edited 2013-12-12 08:34
    Peter,
    I actually like the way you do it now.
    PropTool or BST is there anyhow and no additional tools required.
    Reading your Tachyon kernel was very helpful &B fun to me in
    a) learning PASM
    b) understand how Tachyon really works internally
    c) even making slight kernel modifications ;-)
    Of course it takes a while to be able ro read the precompiled forth -
    but then - those are the actual bytes executed and much more readable than:
    ' : here dp @ ;   byte $28, $0f, $80, $04, $68, $65, $72, $65, $0b, $00, $00, $00, $ac, $0d   byte $88, $0c, $00, $00, $00, $00  ' : allot dp @ + dp ! ;   byte $3c, $0f, $80, $05, $61, $6c, $6c, $6f, $74, $00, $00, $00, $0b, $00   byte $00, $00, $ac, $0d, $88, $0c, $c4, $0c, $ac, $0d, $7c, $0c, $00, $00  ' : , here ! 4 allot ;   byte $50, $0f, $80, $01, $2c, $00, $00, $00, $0b, $00, $00, $00, $44, $0f   byte $7c, $0c, $54, $0c, $04, $00, $5c, $0f, $00, $00
    and having to install a C compiler toolchain to run Tachyon is not s.th. I would like to do.
    And just taking the kernel as a fixed prefabed module that I could only use, but not look inside
    would take out a lot of the fun it currently is.
    Do you expect so many kernel changes, that this is worth it?
    P2 Tachyon maybe??
    You have started to move code from the kernel out to EXTEND.
    I am sure there is some more, that can be moved, so what's left is not very big any more.
    Edit: and being able to include SPIN objects is sure a plus as well
    edited 2013-12-12 14:27
    MJB wrote: »
    Peter,
    a) learning PASM
    P2 Tachyon maybe??
    I definitely would not make it harder to write or read, it would never be hex and by using a macroassembler instead of writing:
    byte ZEQ,_IF,@lab1-lab2
    I could instead write:
    0=
    _IF lab1
    as the macros for _IF allow me to use them as a directive or instruction and the macro can calculate the displacement to lab1.
    The PASM part should be much the same though. Anyway, just toying with the idea.
